Feature #420
open
KH
Use standard format of TPM event log
Feature #420: Use standard format of TPM event log
Added by Krystian Hebel about 4 years ago. Updated over 2 years ago.
New
10/12/2022
33%
(Total: 0.00 h)
Currently coreboot uses proprietary format for TPM event log. TCG has standardized log formats, differently for TPM1.2 (aka legacy or SHA1) [1] and TPM2.0 (aka crypto agile) [2], both of which can be parsed by Linux kernel and exposed in sysfs. I don't know of any tool outside of cbmem which can parse coreboot format; this includes payloads which may be interested in continuing chain of trust started by coreboot.
Another incompatibility is caused by vboot's assignment of PCRs. Roles of PCRs are roughly specified by TCG in both of mentioned documents, they are more or less compatible with each other, but not with current coreboot code.
These changes could break assumptions made by existing platforms, so they should be made as Kconfig options.
This is a tracking issue to collect subtasks that need to be done in order to support standard event log formats.
Subtasks 6 (4 open — 2 closed)
Cleanup #421: Change API of functions taking hash as an argumentNew10/12/2022
Feature #422: Create Kconfig menu for TPM event log formatNew10/12/2022
Feature #423: Implement legacy and crypto agile TPM event log formatsNew10/12/2022
Feature #424: Create and implement option to choose either TCG or vboot PCR assignmentNew10/12/2022
Feature #425: Add parsing of new TPM event log formats to cbmem utilityResolved10/12/2022
Documentation #426: Document existing and added TPM event log formats and PCR usageResolved10/12/2022
KH Updated by Krystian Hebel about 4 years ago Actions #1
  • Related links updated (diff)
AH Updated by Arthur Heymans about 4 years ago Actions #2
https://review.coreboot.org/c/coreboot/+/51710 Implements the TCG one. The coreboot implementation is not a 'proprietary' format. That would imply that there is a license restriction on using it which there is not.
A lot of the TCG spec simply does not make a lot of sense for coreboot which is why it's not implemented.
MŻ Updated by Michał Żygowski about 4 years ago Actions #3
Arthur Heymans wrote in #note-2:
Yes, it is not "proprietary", "custom" would be a better word here. Anyway, having an option for TCG compliant event log will not hurt.
Thank you for pointing the patch, adding to Related Links.
MŻ Updated by Michał Żygowski about 4 years ago Actions #4
  • Related to Cleanup #421: Change API of functions taking hash as an argument added
MŻ Updated by Michał Żygowski about 4 years ago Actions #5
  • Related to Feature #422: Create Kconfig menu for TPM event log format added
MŻ Updated by Michał Żygowski about 4 years ago Actions #6
  • Related to Feature #423: Implement legacy and crypto agile TPM event log formats added
MŻ Updated by Michał Żygowski about 4 years ago Actions #7
  • Related to Feature #424: Create and implement option to choose either TCG or vboot PCR assignment added
MŻ Updated by Michał Żygowski about 4 years ago Actions #8
  • Related to Feature #425: Add parsing of new TPM event log formats to cbmem utility added
MŻ Updated by Michał Żygowski about 4 years ago Actions #9
  • Related to Documentation #426: Document existing and added TPM event log formats and PCR usage added
MŻ Updated by Michał Żygowski about 4 years ago Actions #10
Adding subtask seems to be a new issue creation. In order to avoid duplication, I have added these issues from related links to the Related Issues section.
MŻ Updated by Michał Żygowski about 4 years ago Actions #11
Michał Żygowski wrote in #note-10:
NVM, I can assign Parent Task to the other issues and it will automatically link as subtask.
SD Updated by Sergii Dmytruk over 2 years ago Actions #12
2 out of 6 subtasks are closed, but really all of them are done by now, including this one.
