Feature #422
open
KH
Feature #420: Use standard format of TPM event log
Create Kconfig menu for TPM event log format
Feature #422: Create Kconfig menu for TPM event log format
Added by Krystian Hebel about 4 years ago. Updated about 4 years ago.
New
10/12/2022
New entries should default to one of TCG formats, depending on selected TPM family. Choice of other format shouldn't be restricted. Use of current proprietary format should be explicitly selected by boards that depend on it.
Additionally, config menu should allow to choose at compilation time the hashing algorithms that are to be used. This would allow for limiting size of code for cases with restricted available space.
MŻ Updated by Michał Żygowski about 4 years ago Actions #1
  • Related to Feature #420: Use standard format of TPM event log added
MŻ Updated by Michał Żygowski about 4 years ago Actions #2
  • Parent task set to #420
