Documentation #426
closed
KH
Feature #420: Use standard format of TPM event log
Document existing and added TPM event log formats and PCR usage
Documentation #426:
10/12/2022
Documentation should mention at least:
- what formats are available and where they are described
- what are possible consumers of each format
- which hashing algorithms can be used
- what additional info is added to that required by specification, if any
- which component is extended to which PCR for each of supported scheme (may be in form of example event log)
Additionally, existing vboot documentation should be fixed, especially parts describing SRTM and DRTM.
MŻ Updated by Michał Żygowski about 4 years ago
- Related to Feature #420: Use standard format of TPM event log added
- Parent task set to #420
MR Updated by Martin Roth almost 3 years ago
Fixed.
https://review.coreboot.org/c/coreboot/+/68752 - Documentation/measured_boot.md: document new TPM options
https://review.coreboot.org/c/coreboot/+/68751 - Documentation/measured_boot.md: fix SRTM/DRTM explanations
