Feature #425
closed
KH
Feature #420: Use standard format of TPM event log
Add parsing of new TPM event log formats to cbmem utility
Feature #425:
10/12/2022
All existing and newly implemented formats must be parse-able by cbmem. It should be able to automatically recognize used format and parse it accordingly, so there are no significant differences in invocation of this tool by end users. Crypto agile format will require implementation of additional unmarshaling.
MŻ Updated by Michał Żygowski about 4 years ago
I have already started some work for parsing TCG compliant event log from DRTM event log area reserved in cbmem. It should be relatively simple to propagate to other cbmem regions if needed. Relevant patchset linekd in the Related links section.
- Related to Feature #420: Use standard format of TPM event log added
- Parent task set to #420
MR Updated by Martin Roth almost 3 years ago
Fixed: https://review.coreboot.org/c/coreboot/+/68749 - util/cbmem: add parsing of TPM logs per specs
