Bug #565
open
VM
Wifi card not recognized (not enumerated) at all, Lenovo M700 tiny
Bug #565: Wifi card not recognized (not enumerated) at all, Lenovo M700 tiny
Added by Vittorio Mori about 2 years ago. Updated about 2 years ago.
New
board support
10/03/2024
Lenovo M700 tiny
ANY
Hello, I've compiled coreboot for my Lenovo M700 Tiny, to have other processor support (Kaby Lake/Coffee Lake).
The ed2k payload works correctly, I can successfully boot a Kaby Lake and Coffee lake CPU with Coreboot (original Lenovo BIOS is Skylake-only).
I report two annoying issues:
  • wif card pci-e slot is not working, the card is not enumerated at all. ASPM on or off, no difference (with ASPM ON I get continous AER errors in dmesg on Linux). With original OEM BIOS the wifi (Intel 8260 wifi5 chipset) 100% works. On coreboot I get only the bluetooth part working (I know it's on the USB bus, so I think it's normal).
  • I use libgfxinit for graphics part: works correctly at boot, Linux booting always OK, but Windows 11 fails to initialize the displayport output i.e. it gets TURNED OFF for some reason when windows starts. I have to unplug and plug the cable back to have display back ON. This also does not happen with original OEM firmware. Maybe I must use a GOP ? I could not find a clear guide on how to compile/initialize coreboot w GOP into coreboot. Maybe I can run it into an .efi binary (I have all .efi GOPs somewhere..) ?
Here is the cbmem log:
`[NOTE ] coreboot-24.08-272-g735ca7f24ad4 Tue Sep 24 05:19:22 UTC 2024 x86_32 bootblock starting (log level: 7)...
[DEBUG] CPU: Intel(R) Core(TM) i3-7100 CPU @ 3.90GHz
[DEBUG] CPU: ID 906e9, Kabylake H B0, ucode: 000000f7
[DEBUG] CPU: AES supported, TXT NOT supported, VT supported
[DEBUG] MCH: device id 590f (rev 06) is Kabylake-S
[DEBUG] PCH: device id a148 (rev 31) is B150
[DEBUG] IGD: device id 5912 (rev 04) is Kaby Lake DT GT2
[DEBUG] FMAP: Found "FLASH" version 1.1 at 0x850000.
[DEBUG] FMAP: base = 0xff000000 size = 0x1000000 #areas = 8
[DEBUG] FMAP: area COREBOOT found @ 850200 (8060416 bytes)
[INFO ] CBFS: mcache @0xfef04f00 built for 16 files, used 0x364 of 0x4000 bytes
[INFO ] CBFS: Found 'fallback/romstage' @0x9d1c0 size 0xb9a0 in mcache @0xfef04f8c
[DEBUG] BS: bootblock times (exec / console): total (unknown) / 78 ms
[NOTE ] coreboot-24.08-272-g735ca7f24ad4 Tue Sep 24 05:19:22 UTC 2024 x86_32 romstage starting (log level: 7)...
[DEBUG] pm1_sts: 0000 pm1_en: 0000 pm1_cnt: 00000000
[DEBUG] gpe0_sts[0]: 00000000 gpe0_en[0]: 00000000
[DEBUG] gpe0_sts[1]: 00000000 gpe0_en[1]: 00000000
[DEBUG] gpe0_sts[2]: 00000000 gpe0_en[2]: 00000000
[DEBUG] gpe0_sts[3]: 00000002 gpe0_en[3]: 00000000
[DEBUG] TCO_STS: 0000 0001
[DEBUG] GEN_PMCON: e0850200 00001808
[DEBUG] GBLRST_CAUSE: 00000400 00010001
[DEBUG] prev_sleep_state 0 (S0)
[INFO ] CBFS: Found 'fspm.bin' @0xcadc0 size 0x63000 in mcache @0xfef0513c
[DEBUG] FMAP: area RW_MRC_CACHE found @ 800000 (65536 bytes)
[DEBUG] SPD @ 0x50
[INFO ] SPD: module type is DDR4
[INFO ] SPD: module part number is 4ATF51264HZ-2G3E2
[INFO ] SPD: banks 8, ranks 1, rows 16, columns 10, density 8192 Mb
[INFO ] SPD: device width 16 bits, bus width 64 bits
[INFO ] SPD: module size is 4096 MB (per channel)
[DEBUG] SPD @ 0x52
[DEBUG] CBMEM:
[DEBUG] IMD: root @ 0x7afff000 254 entries.
[DEBUG] IMD: root @ 0x7affec00 62 entries.
[DEBUG] External stage cache:
[DEBUG] IMD: root @ 0x7b3ff000 254 entries.
[DEBUG] IMD: root @ 0x7b3fec00 62 entries.
[DEBUG] MRC: Checking cached data update for 'RW_MRC_CACHE'.
[DEBUG] MRC: 'RW_MRC_CACHE' does not need update.
[DEBUG] 2 DIMMs found
[DEBUG] SMM Memory Map
[DEBUG] SMRAM : 0x7b000000 0x800000
[DEBUG] Subregion 0: 0x7b000000 0x200000
[DEBUG] Subregion 1: 0x7b200000 0x200000
[DEBUG] Subregion 2: 0x7b400000 0x400000
[DEBUG] top_of_ram = 0x7b000000
[DEBUG] Normal boot
[INFO ] CBFS: Found 'fallback/postcar' @0x151e40 size 0x6808 in mcache @0xfef051b0
[DEBUG] Loading module at 0x7abce000 with entry 0x7abce031. filesize: 0x6208 memsize: 0xc5a0
[DEBUG] Processing 368 relocs. Offset value of 0x78bce000
[DEBUG] BS: romstage times (exec / console): total (unknown) / 226 ms
[NOTE ] coreboot-24.08-272-g735ca7f24ad4 Tue Sep 24 05:19:22 UTC 2024 x86_32 postcar starting (log level: 7)...
[DEBUG] Normal boot
[INFO ] CBFS: Found 'fallback/ramstage' @0xa8bc0 size 0x1d278 in mcache @0x7abdc0ec
[DEBUG] Loading module at 0x7aa7f000 with entry 0x7aa7f000. filesize: 0x3a428 memsize: 0x14d908
[DEBUG] Processing 4860 relocs. Offset value of 0x76a7f000
[DEBUG] BS: postcar times (exec / console): total (unknown) / 43 ms
[NOTE ] coreboot-24.08-272-g735ca7f24ad4 Tue Sep 24 05:19:22 UTC 2024 x86_32 ramstage starting (log level: 7)...
[DEBUG] Normal boot
[DEBUG] microcode: sig=0x906e9 pf=0x2 revision=0xf7
[INFO ] CBFS: Found 'cpu_microcode_blob.bin' @0x80 size 0x9d000 in mcache @0x7abdc02c
[DEBUG] Skip microcode update
[INFO ] CBFS: Found 'fsps.bin' @0x12de00 size 0x23ff2 in mcache @0x7abdc27c
[DEBUG] Detected 2 core, 4 thread CPU.
[DEBUG] Setting up SMI for CPU
[DEBUG] IED base = 0x7b400000
[DEBUG] IED size = 0x00400000
[INFO ] Will perform SMM setup.
[INFO ] CPU: Intel(R) Core(TM) i3-7100 CPU @ 3.90GHz.
[INFO ] LAPIC 0x0 in XAPIC mode.
[DEBUG] CPU: APIC: 00 enabled
[DEBUG] CPU: APIC: 01 enabled
[DEBUG] CPU: APIC: 02 enabled
[DEBUG] CPU: APIC: 03 enabled
[DEBUG] Loading module at 0x00030000 with entry 0x00030000. filesize: 0x178 memsize: 0x178
[DEBUG] Processing 16 relocs. Offset value of 0x00030000
[DEBUG] Attempting to start 3 APs
[DEBUG] Waiting for 10ms after sending INIT.
[DEBUG] Waiting for SIPI to complete...
[INFO ] LAPIC 0x1 in XAPIC mode.
[DEBUG] done.
[INFO ] AP: slot 3 apic_id 1, MCU rev: 0x000000f7
[DEBUG] done.
[INFO ] LAPIC 0x3 in XAPIC mode.
[INFO ] LAPIC 0x2 in XAPIC mode.
[INFO ] AP: slot 1 apic_id 3, MCU rev: 0x000000f7
[INFO ] AP: slot 2 apic_id 2, MCU rev: 0x000000f7
[DEBUG] Loading module at 0x00038000 with entry 0x00038000. filesize: 0x1b0 memsize: 0x1b0
[DEBUG] Processing 9 relocs. Offset value of 0x00038000
[DEBUG] smm_module_setup_stub: stack_top = 0x7b002000
[DEBUG] smm_module_setup_stub: per cpu stack_size = 0x800
[DEBUG] smm_module_setup_stub: runtime.smm_size = 0x10000
[DEBUG] SMM Module: stub loaded at 38000. Will call 0x7aa98de3
[DEBUG] Installing permanent SMM handler to 0x7b000000
[DEBUG] HANDLER [0x7b1fe000-0x7b1ffe8f]
[DEBUG] CPU 0
[DEBUG] ss0 [0x7b1fdc00-0x7b1fdfff]
[DEBUG] stub0 [0x7b1f6000-0x7b1f61af]
[DEBUG] CPU 1
[DEBUG] ss1 [0x7b1fd800-0x7b1fdbff]
[DEBUG] stub1 [0x7b1f5c00-0x7b1f5daf]
[DEBUG] CPU 2
[DEBUG] ss2 [0x7b1fd400-0x7b1fd7ff]
[DEBUG] stub2 [0x7b1f5800-0x7b1f59af]
[DEBUG] CPU 3
[DEBUG] ss3 [0x7b1fd000-0x7b1fd3ff]
[DEBUG] stub3 [0x7b1f5400-0x7b1f55af]
[DEBUG] stacks [0x7b000000-0x7b001fff]
[DEBUG] Loading module at 0x7b1fe000 with entry 0x7b1ff81b. filesize: 0x1db0 memsize: 0x1e90
[DEBUG] Processing 149 relocs. Offset value of 0x7b1fe000
[DEBUG] FMAP: area SMMSTORE found @ 810000 (262144 bytes)
[DEBUG] smm store: 4 # blocks with size 0x10000
[DEBUG] Loading module at 0x7b1f6000 with entry 0x7b1f6000. filesize: 0x1b0 memsize: 0x1b0
[DEBUG] Processing 9 relocs. Offset value of 0x7b1f6000
[DEBUG] smm_module_setup_stub: runtime.smm_size = 0x200000
[DEBUG] SMM Module: placing smm entry code at 7b1f5c00, cpu # 0x1
[DEBUG] SMM Module: placing smm entry code at 7b1f5800, cpu # 0x2
[DEBUG] SMM Module: placing smm entry code at 7b1f5400, cpu # 0x3
[DEBUG] SMM Module: stub loaded at 7b1f6000. Will call 0x7b1ff81b
[DEBUG] Clearing SMI status registers
[DEBUG] TCO_STS: INTRD_DET
[DEBUG] GPE0 STD STS: HOTPLUG
[INFO ] smm_do_relocation : curr_smbase 0x30000 perm_smbase 0x7b1ee000, cpu = 0
[DEBUG] In relocation handler: CPU 0
[DEBUG] New SMBASE=0x7b1ee000 IEDBASE=0x7b400000
[DEBUG] Writing SMRR. base = 0x7b000006, mask=0xff800800
[DEBUG] Relocation complete.
[INFO ] smm_do_relocation : curr_smbase 0x30000 perm_smbase 0x7b1ed800, cpu = 2
[DEBUG] In relocation handler: CPU 2
[DEBUG] New SMBASE=0x7b1ed800 IEDBASE=0x7b400000
[INFO ] smm_do_relocation : curr_smbase 0x30000 perm_smbase 0x7b1edc00, cpu = 1
[DEBUG] In relocation handler: CPU 1
[DEBUG] New SMBASE=0x7b1edc00 IEDBASE=0x7b400000
[INFO ] smm_do_relocation : curr_smbase 0x30000 perm_smbase 0x7b1ed400, cpu = 3
[DEBUG] In relocation handler: CPU 3
[DEBUG] New SMBASE=0x7b1ed400 IEDBASE=0x7b400000
[INFO ] Initializing CPU #0
[DEBUG] CPU: vendor Intel device 906e9
[DEBUG] CPU: family 06, model 9e, stepping 09
[DEBUG] Clearing out pending MCEs
[DEBUG] cpu: energy policy set to 6
[INFO ] Turbo is unavailable
[INFO ] CPU #0 initialized
[INFO ] Initializing CPU #3
[INFO ] Initializing CPU #1
[INFO ] Initializing CPU #2
[INFO ] CPU #1 initialized
[INFO ] CPU #2 initialized
[INFO ] CPU #3 initialized
[INFO ] bsp_do_flight_plan done after 420 msecs.
[DEBUG] Enabling SMIs.
[DEBUG] Locking SMM.
[DEBUG] VMX status: enabled
[DEBUG] IA32_FEATURE_CONTROL status: locked
[DEBUG] BS: BS_DEV_INIT_CHIPS entry times (exec / console): 204 / 381 ms
[DEBUG] WEAK: src/soc/intel/skylake/chip.c/mainboard_silicon_init_params called
[INFO ] FSPS, status=0x00000000
[INFO ] ITSS IRQ Polarities Before:
[INFO ] IPC0: 0x00ff4000
[INFO ] IPC1: 0x00000007
[INFO ] IPC2: 0x00000000
[INFO ] IPC3: 0x00000000
[INFO ] ITSS IRQ Polarities After:
[INFO ] Found PCIe Root Port #7 at PCI: 00:1c.0.
[NOTE ] pcie_rp_update_dev: Couldn't find PCIe Root Port #17 (originally PCI: 00:00:1b.0) which was enabled in devicetree, removing and disabling.
[INFO ] Remapping PCIe Root Port #7 from PCI: 00:00:1c.6 to new function number 0.
[DEBUG] BS: BS_DEV_INIT_CHIPS run times (exec / console): 56 / 73 ms
[INFO ] Enumerating buses...
[INFO ] Board ID: ThinkCentre M700 Tiny
[INFO ] Serial header unpopulated
[INFO ] PS/2 header unpopulated
[INFO ] USB header unpopulated
[INFO ] DisplayPort header populated
[INFO ] PCIe / SATA header unpopulated
[DEBUG] Root Device scanning...
[DEBUG] CPU_CLUSTER: 0 enabled
[DEBUG] DOMAIN: 00000000 enabled
[DEBUG] DOMAIN: 00000000 scanning...
[DEBUG] PCI: pci_scan_bus for segment group 00 bus 00
[DEBUG] PCI: 00:00:00.0 [8086/590f] enabled
[DEBUG] PCI: 00:00:02.0 [8086/5912] enabled
[DEBUG] PCI: 00:00:04.0 [8086/1903] enabled
[DEBUG] PCI: 00:00:08.0 [8086/1911] enabled
[DEBUG] PCI: 00:00:14.0 [8086/a12f] enabled
[DEBUG] PCI: 00:00:14.2 [8086/a131] enabled
[DEBUG] PCI: 00:00:16.0 [8086/a13a] enabled
[DEBUG] PCI: 00:00:17.0 [8086/a102] enabled
[DEBUG] PCI: 00:00:19.0 [8086/a166] disabled
[DEBUG] PCI: 00:00:1c.0 [8086/a116] enabled
[DEBUG] PCI: 00:00:1f.0 [8086/a148] enabled
[DEBUG] PCI: 00:00:1f.1 [8086/a120] enabled
[DEBUG] PCI: 00:00:1f.2 [8086/a121] enabled
[DEBUG] PCI: 00:00:1f.3 [8086/a170] enabled
[DEBUG] PCI: 00:00:1f.4 [8086/a123] enabled
[DEBUG] PCI: 00:00:1f.6 [8086/15b8] enabled
[DEBUG] GPIO: 0 enabled
[WARN ] PCI: Leftover static devices:
[WARN ] PCI: 00:00:01.0
[WARN ] PCI: 00:00:01.1
[WARN ] PCI: 00:00:01.2
[WARN ] PCI: 00:00:05.0
[WARN ] PCI: 00:00:07.0
[WARN ] PCI: 00:00:13.0
[WARN ] PCI: 00:00:14.1
[WARN ] PCI: 00:00:14.3
[WARN ] PCI: 00:00:15.0
[WARN ] PCI: 00:00:15.1
[WARN ] PCI: 00:00:15.2
[WARN ] PCI: 00:00:15.3
[WARN ] PCI: 00:00:16.1
[WARN ] PCI: 00:00:16.2
[WARN ] PCI: 00:00:16.3
[WARN ] PCI: 00:00:16.4
[WARN ] PCI: 00:00:19.1
[WARN ] PCI: 00:00:19.2
[WARN ] PCI: 00:00:1e.0
[WARN ] PCI: 00:00:1e.1
[WARN ] PCI: 00:00:1e.2
[WARN ] PCI: 00:00:1e.3
[WARN ] PCI: 00:00:1e.4
[WARN ] PCI: 00:00:1e.5
[WARN ] PCI: 00:00:1e.6
[WARN ] PCI: 00:00:1f.5
[WARN ] PCI: 00:00:1f.7
[WARN ] PCI: Check your devicetree.cb.
[DEBUG] PCI: 00:00:02.0 scanning...
[DEBUG] scan_bus: bus PCI: 00:00:02.0 finished in 0 msecs
[DEBUG] PCI: 00:00:14.0 scanning...
[DEBUG] scan_bus: bus PCI: 00:00:14.0 finished in 0 msecs
[DEBUG] PCI: 00:00:1c.0 scanning...
[DEBUG] PCI: pci_scan_bus for segment group 00 bus 01
[DEBUG] GENERIC: 0.0 enabled
[INFO ] PCI: 00:00:1c.0: Setting Max_Payload_Size to 128 for devices under this root port
[DEBUG] scan_bus: bus PCI: 00:00:1c.0 finished in 18 msecs
[DEBUG] PCI: 00:00:1f.0 scanning...
[DEBUG] PNP: 002e.1 disabled
[DEBUG] PNP: 002e.2 enabled
[DEBUG] PNP: 002e.3 disabled
[DEBUG] PNP: 002e.5 disabled
[DEBUG] PNP: 002e.6 disabled
[DEBUG] PNP: 002e.7 disabled
[DEBUG] PNP: 002e.8 disabled
[DEBUG] PNP: 002e.9 disabled
[DEBUG] PNP: 002e.a enabled
[DEBUG] PNP: 002e.b enabled
[DEBUG] PNP: 002e.c disabled
[DEBUG] PNP: 002e.d disabled
[DEBUG] PNP: 002e.e enabled
[DEBUG] PNP: 002e.f disabled
[INFO ] Found TPM 1.2 NPCT420AA V2 (0x00fe) by Nuvoton (0x1050)
[DEBUG] PNP: 0c31.0 enabled
[DEBUG] scan_bus: bus PCI: 00:00:1f.0 finished in 59 msecs
[DEBUG] PCI: 00:00:1f.2 scanning...
[DEBUG] scan_bus: bus PCI: 00:00:1f.2 finished in 0 msecs
[DEBUG] PCI: 00:00:1f.3 scanning...
[DEBUG] scan_bus: bus PCI: 00:00:1f.3 finished in 0 msecs
[DEBUG] PCI: 00:00:1f.4 scanning...
[DEBUG] scan_bus: bus PCI: 00:00:1f.4 finished in 0 msecs
[DEBUG] scan_bus: bus DOMAIN: 00000000 finished in 336 msecs
[DEBUG] scan_bus: bus Root Device finished in 354 msecs
[INFO ] done
[DEBUG] BS: BS_DEV_ENUMERATE run times (exec / console): 10 / 391 ms
[INFO ] MRC: Could not find region 'UNIFIED_MRC_CACHE'
[INFO ] MRC: NOT enabling PRR for 'RW_MRC_CACHE'.
[DEBUG] BS: BS_DEV_ENUMERATE exit times (exec / console): 0 / 18 ms
[DEBUG] found VGA at PCI: 00:00:02.0
[DEBUG] Setting up VGA for PCI: 00:00:02.0
[DEBUG] Setting PCI_BRIDGE_CTL_VGA for bridge DOMAIN: 00000000
[DEBUG] Setting PCI_BRIDGE_CTL_VGA for bridge Root Device
[INFO ] Allocating resources...
[INFO ] Reading resources...
[DEBUG] SA MMIO resource: PCIEXBAR -> base = 0xe0000000, size = 0x10000000
[DEBUG] SA MMIO resource: MCHBAR -> base = 0xfed10000, size = 0x00008000
[DEBUG] SA MMIO resource: DMIBAR -> base = 0xfed18000, size = 0x00001000
[DEBUG] SA MMIO resource: EPBAR -> base = 0xfed19000, size = 0x00001000
[DEBUG] SA MMIO resource: GDXCBAR -> base = 0xfed84000, size = 0x00001000
[DEBUG] SA MMIO resource: EDRAMBAR -> base = 0xfed80000, size = 0x00004000
[DEBUG] SA MMIO resource: GFXVTBAR -> base = 0xfed90000, size = 0x00001000
[DEBUG] SA MMIO resource: VTVC0BAR -> base = 0xfed91000, size = 0x00001000
[INFO ] Available memory above 4GB: 6112M
[INFO ] Done reading resources.
[INFO ] === Resource allocator: DOMAIN: 00000000 - Pass 1 (relative placement) ===
[DEBUG] PCI: 00:00:1c.0 io: size: 0 align: 12 gran: 12 limit: ffff
[DEBUG] PCI: 00:00:1c.0 io: size: 0 align: 12 gran: 12 limit: ffff done
[DEBUG] PCI: 00:00:1c.0 mem: size: 0 align: 20 gran: 20 limit: ffffffff
[DEBUG] PCI: 00:00:1c.0 mem: size: 0 align: 20 gran: 20 limit: ffffffff done
[DEBUG] PCI: 00:00:1c.0 prefmem: size: 0 align: 20 gran: 20 limit: ffffffffffffffff
[DEBUG] PCI: 00:00:1c.0 prefmem: size: 0 align: 20 gran: 20 limit: ffffffffffffffff done
[INFO ] === Resource allocator: DOMAIN: 00000000 - Pass 2 (allocating resources) ===
[DEBUG] DOMAIN: 00000000 io: base: 0 size: 0 align: 0 gran: 0 limit: ffff
[DEBUG] avoid_fixed_resources: PCI: 00:00:1f.0 00 base 00000000 limit 00000fff io (fixed)
[DEBUG] avoid_fixed_resources: PCI: 00:00:1f.0 84 base 00000080 limit 0000008f io (fixed)
[DEBUG] avoid_fixed_resources: PNP: 002e.2 60 base 000003f8 limit 000003ff io (fixed)
[DEBUG] avoid_fixed_resources: PNP: 002e.a 60 base 00000a10 limit 00000a17 io (fixed)
[DEBUG] avoid_fixed_resources: PNP: 002e.b 60 base 00000a20 limit 00000a27 io (fixed)
[DEBUG] avoid_fixed_resources: PCI: 00:00:1f.2 40 base 00001800 limit 000018ff io (fixed)
[DEBUG] avoid_fixed_resources: PCI: 00:00:1f.4 20 base 0000efa0 limit 0000efbf io (fixed)
[INFO ] DOMAIN: 00000000: Resource ranges:
[INFO ] * Base: 1000, Size: 800, Tag: 100
[INFO ] * Base: 1900, Size: d6a0, Tag: 100
[INFO ] * Base: efc0, Size: 1040, Tag: 100
[DEBUG] PCI: 00:00:02.0 20 * [0x1000 - 0x103f] limit: 103f io
[DEBUG] PCI: 00:00:17.0 20 * [0x1040 - 0x105f] limit: 105f io
[DEBUG] PCI: 00:00:17.0 18 * [0x1060 - 0x1067] limit: 1067 io
[DEBUG] PCI: 00:00:17.0 1c * [0x1068 - 0x106b] limit: 106b io
[DEBUG] DOMAIN: 00000000 io: base: 0 size: 0 align: 0 gran: 0 limit: ffff done
[DEBUG] DOMAIN: 00000000 mem: base: 7b000000 size: 0 align: 0 gran: 0 limit: dfffffff
[DEBUG] DOMAIN: 00000000 mem: base: 100000000 size: 0 align: 0 gran: 0 limit: 7fffffffff
[DEBUG] avoid_fixed_resources: PCI: 00:00:00.0 00 base e0000000 limit efffffff mem (fixed)
[DEBUG] avoid_fixed_resources: PCI: 00:00:00.0 01 base fed10000 limit fed17fff mem (fixed)
[DEBUG] avoid_fixed_resources: PCI: 00:00:00.0 02 base fed18000 limit fed18fff mem (fixed)
[DEBUG] avoid_fixed_resources: PCI: 00:00:00.0 03 base fed19000 limit fed19fff mem (fixed)
[DEBUG] avoid_fixed_resources: PCI: 00:00:00.0 04 base fed84000 limit fed84fff mem (fixed)
[DEBUG] avoid_fixed_resources: PCI: 00:00:00.0 05 base fed80000 limit fed83fff mem (fixed)
[DEBUG] avoid_fixed_resources: PCI: 00:00:00.0 06 base fed90000 limit fed90fff mem (fixed)
[DEBUG] avoid_fixed_resources: PCI: 00:00:00.0 07 base fed91000 limit fed91fff mem (fixed)
[DEBUG] avoid_fixed_resources: PCI: 00:00:00.0 08 base 00000000 limit 0009ffff mem (fixed)
[DEBUG] avoid_fixed_resources: PCI: 00:00:00.0 09 base 000c0000 limit 7affffff mem (fixed)
[DEBUG] avoid_fixed_resources: PCI: 00:00:00.0 0a base 7b000000 limit 7fffffff mem (fixed)
[DEBUG] avoid_fixed_resources: PCI: 00:00:00.0 0b base 100000000 limit 27dffffff mem (fixed)
[DEBUG] avoid_fixed_resources: PCI: 00:00:00.0 0c base 000a0000 limit 000bffff mem (fixed)
[DEBUG] avoid_fixed_resources: PCI: 00:00:00.0 0d base 000c0000 limit 000fffff mem (fixed)
[DEBUG] avoid_fixed_resources: PNP: 0c31.0 00 base fed40000 limit fed44fff mem (fixed)
[DEBUG] avoid_fixed_resources: PCI: 00:00:1f.1 10 base fd000000 limit fdffffff mem (fixed)
[DEBUG] avoid_fixed_resources: PCI: 00:00:1f.2 48 base fe000000 limit fe00ffff mem (fixed)
[INFO ] * Base: 80000000, Size: 60000000, Tag: 200
[INFO ] * Base: 27e000000, Size: 7d82000000, Tag: 200
[DEBUG] PCI: 00:00:02.0 18 * [0x80000000 - 0x8fffffff] limit: 8fffffff prefmem
[DEBUG] PCI: 00:00:02.0 10 * [0x90000000 - 0x90ffffff] limit: 90ffffff mem
[DEBUG] PCI: 00:00:1f.6 10 * [0x91000000 - 0x9101ffff] limit: 9101ffff mem
[DEBUG] PCI: 00:00:14.0 10 * [0x91020000 - 0x9102ffff] limit: 9102ffff mem
[DEBUG] PCI: 00:00:1f.3 20 * [0x91030000 - 0x9103ffff] limit: 9103ffff mem
[DEBUG] PCI: 00:00:04.0 10 * [0x91040000 - 0x91047fff] limit: 91047fff mem
[DEBUG] PCI: 00:00:1f.2 10 * [0x91048000 - 0x9104bfff] limit: 9104bfff mem
[DEBUG] PCI: 00:00:1f.3 10 * [0x9104c000 - 0x9104ffff] limit: 9104ffff mem
[DEBUG] PCI: 00:00:17.0 10 * [0x91050000 - 0x91051fff] limit: 91051fff mem
[DEBUG] PCI: 00:00:08.0 10 * [0x91052000 - 0x91052fff] limit: 91052fff mem
[DEBUG] PCI: 00:00:14.2 10 * [0x91053000 - 0x91053fff] limit: 91053fff mem
[DEBUG] PCI: 00:00:16.0 10 * [0x91054000 - 0x91054fff] limit: 91054fff mem
[DEBUG] PCI: 00:00:17.0 24 * [0x91055000 - 0x910557ff] limit: 910557ff mem
[DEBUG] PCI: 00:00:17.0 14 * [0x91056000 - 0x910560ff] limit: 910560ff mem
[DEBUG] PCI: 00:00:1f.4 10 * [0x91057000 - 0x910570ff] limit: 910570ff mem
[DEBUG] DOMAIN: 00000000 mem: base: 7b000000 size: 0 align: 0 gran: 0 limit: dfffffff done
[DEBUG] DOMAIN: 00000000 mem: base: 100000000 size: 0 align: 0 gran: 0 limit: 7fffffffff done
[INFO ] === Resource allocator: DOMAIN: 00000000 - resource allocation complete ===
[DEBUG] PCI: 00:00:02.0 10 <- [0x0000000090000000 - 0x0000000090ffffff] size 0x01000000 gran 0x18 mem64
[DEBUG] PCI: 00:00:02.0 18 <- [0x0000000080000000 - 0x000000008fffffff] size 0x10000000 gran 0x1c prefmem64
[DEBUG] PCI: 00:00:02.0 20 <- [0x0000000000001000 - 0x000000000000103f] size 0x00000040 gran 0x06 io
[DEBUG] PCI: 00:00:04.0 10 <- [0x0000000091040000 - 0x0000000091047fff] size 0x00008000 gran 0x0f mem64
[DEBUG] PCI: 00:00:08.0 10 <- [0x0000000091052000 - 0x0000000091052fff] size 0x00001000 gran 0x0c mem64
[DEBUG] PCI: 00:00:14.0 10 <- [0x0000000091020000 - 0x000000009102ffff] size 0x00010000 gran 0x10 mem64
[DEBUG] PCI: 00:00:14.2 10 <- [0x0000000091053000 - 0x0000000091053fff] size 0x00001000 gran 0x0c mem64
[DEBUG] PCI: 00:00:16.0 10 <- [0x0000000091054000 - 0x0000000091054fff] size 0x00001000 gran 0x0c mem64
[DEBUG] PCI: 00:00:17.0 10 <- [0x0000000091050000 - 0x0000000091051fff] size 0x00002000 gran 0x0d mem
[DEBUG] PCI: 00:00:17.0 14 <- [0x0000000091056000 - 0x00000000910560ff] size 0x00000100 gran 0x08 mem
[DEBUG] PCI: 00:00:17.0 18 <- [0x0000000000001060 - 0x0000000000001067] size 0x00000008 gran 0x03 io
[DEBUG] PCI: 00:00:17.0 1c <- [0x0000000000001068 - 0x000000000000106b] size 0x00000004 gran 0x02 io
[DEBUG] PCI: 00:00:17.0 20 <- [0x0000000000001040 - 0x000000000000105f] size 0x00000020 gran 0x05 io
[DEBUG] PCI: 00:00:17.0 24 <- [0x0000000091055000 - 0x00000000910557ff] size 0x00000800 gran 0x0b mem
[DEBUG] PCI: 00:00:1c.0 1c <- [0x000000000000ffff - 0x000000000000fffe] size 0x00000000 gran 0x0c seg 00 buio
[DEBUG] PCI: 00:00:1c.0 24 <- [0xffffffffffffffff - 0xfffffffffffffffe] size 0x00000000 gran 0x14 seg 00 buprefmem
[DEBUG] PCI: 00:00:1c.0 20 <- [0x00000000ffffffff - 0x00000000fffffffe] size 0x00000000 gran 0x14 seg 00 bumem
[DEBUG] PNP: 002e.2 60 <- [0x00000000000003f8 - 0x00000000000003ff] size 0x00000008 gran 0x03 io
[DEBUG] PNP: 002e.2 70 <- [0x0000000000000003 - 0x0000000000000003] size 0x00000001 gran 0x00 irq
[NOTE ] PNP: 002e.2 f0 irq size: 0x0000000001 not assigned in devicetree
[DEBUG] PNP: 002e.a 60 <- [0x0000000000000a10 - 0x0000000000000a17] size 0x00000008 gran 0x03 io
[NOTE ] PNP: 002e.a 70 irq size: 0x0000000001 not assigned in devicetree
[DEBUG] PNP: 002e.b 60 <- [0x0000000000000a20 - 0x0000000000000a27] size 0x00000008 gran 0x03 io
[NOTE ] PNP: 002e.b 70 irq size: 0x0000000001 not assigned in devicetree
[DEBUG] PNP: 002e.e e4 <- [0x0000000000000010 - 0x000000000000000f] size 0x00000000 gran 0x00 irq
[DEBUG] PNP: 002e.e e5 <- [0x0000000000000009 - 0x0000000000000008] size 0x00000000 gran 0x00 irq
[DEBUG] LPC: enabling default decode range LPC_IOE_COMA_EN
[DEBUG] LPC: Opened IO window LGIR1: base a10 size 8
[DEBUG] LPC: Opened IO window LGIR2: base a20 size 8
[DEBUG] PCI: 00:00:1f.2 10 <- [0x0000000091048000 - 0x000000009104bfff] size 0x00004000 gran 0x0e mem
[DEBUG] PCI: 00:00:1f.3 10 <- [0x000000009104c000 - 0x000000009104ffff] size 0x00004000 gran 0x0e mem64
[DEBUG] PCI: 00:00:1f.3 20 <- [0x0000000091030000 - 0x000000009103ffff] size 0x00010000 gran 0x10 mem64
[DEBUG] PCI: 00:00:1f.4 10 <- [0x0000000091057000 - 0x00000000910570ff] size 0x00000100 gran 0x08 mem64
[DEBUG] PCI: 00:00:1f.6 10 <- [0x0000000091000000 - 0x000000009101ffff] size 0x00020000 gran 0x11 mem
[INFO ] Done setting resources.
[INFO ] Done allocating resources.
[DEBUG] BS: BS_DEV_RESOURCES run times (exec / console): 3 / 961 ms
[INFO ] Enabling resources...
[DEBUG] PCI: 00:00:00.0 subsystem <- 17aa/30d0
[DEBUG] PCI: 00:00:00.0 cmd <- 06
[DEBUG] PCI: 00:00:02.0 subsystem <- 17aa/30d0
[DEBUG] PCI: 00:00:02.0 cmd <- 03
[DEBUG] PCI: 00:00:04.0 subsystem <- 17aa/30d0
[DEBUG] PCI: 00:00:04.0 cmd <- 02
[DEBUG] PCI: 00:00:08.0 subsystem <- 17aa/30d0
[DEBUG] PCI: 00:00:08.0 cmd <- 06
[DEBUG] PCI: 00:00:14.0 subsystem <- 17aa/30d0
[DEBUG] PCI: 00:00:14.0 cmd <- 02
[DEBUG] PCI: 00:00:14.2 subsystem <- 17aa/30d0
[DEBUG] PCI: 00:00:14.2 cmd <- 02
[DEBUG] PCI: 00:00:16.0 subsystem <- 17aa/30d0
[DEBUG] PCI: 00:00:16.0 cmd <- 02
[DEBUG] PCI: 00:00:17.0 subsystem <- 17aa/30d0
[DEBUG] PCI: 00:00:17.0 cmd <- 03
[DEBUG] PCI: 00:00:1c.0 bridge ctrl <- 0013
[DEBUG] PCI: 00:00:1c.0 subsystem <- 17aa/30d0
[DEBUG] PCI: 00:00:1c.0 cmd <- 00
[DEBUG] PCI: 00:00:1f.0 subsystem <- 17aa/30d0
[DEBUG] PCI: 00:00:1f.0 cmd <- 07
[DEBUG] PCI: 00:00:1f.2 subsystem <- 17aa/30d0
[DEBUG] PCI: 00:00:1f.2 cmd <- 06
[DEBUG] PCI: 00:00:1f.3 subsystem <- 17aa/30d0
[DEBUG] PCI: 00:00:1f.3 cmd <- 02
[DEBUG] PCI: 00:00:1f.4 subsystem <- 17aa/30d0
[DEBUG] PCI: 00:00:1f.4 cmd <- 03
[DEBUG] PCI: 00:00:1f.6 subsystem <- 17aa/30d0
[DEBUG] PCI: 00:00:1f.6 cmd <- 02
[INFO ] done.
[DEBUG] BS: BS_DEV_ENABLE run times (exec / console): 0 / 139 ms
[DEBUG] ME: Version: 11.0.2.1003
[DEBUG] BS: BS_DEV_ENABLE exit times (exec / console): 37 / 4 ms
[INFO ] Initializing devices...
[DEBUG] PCI: 00:00:00.0 init
[INFO ] CPU TDP = 51 Watts
[INFO ] CPU PL1 = 51 Watts
[INFO ] CPU PL2 = 65 Watts
[DEBUG] PCI: 00:00:00.0 init finished in 10 msecs
[DEBUG] PCI: 00:00:02.0 init
[INFO ] CBFS: Found 'vbt.bin' @0xca340 size 0x47e in mcache @0x7abdc1e4
[INFO ] Found a VBT of 4608 bytes
[INFO ] GMA: Found VBT in CBFS
[INFO ] GMA: Found valid VBT in CBFS
[INFO ] framebuffer_info: bytes_per_line: 7680, bits_per_pixel: 32
[INFO ] x_res x y_res: 1920 x 1200, size: 9216000 at 0x80000000
[DEBUG] PCI: 00:00:02.0 init finished in 178 msecs
[DEBUG] PCI: 00:00:04.0 init
[DEBUG] PCI: 00:00:04.0 init finished in 0 msecs
[DEBUG] PCI: 00:00:08.0 init
[DEBUG] PCI: 00:00:08.0 init finished in 0 msecs
[DEBUG] PCI: 00:00:14.0 init
[DEBUG] PCI: 00:00:14.0 init finished in 0 msecs
[DEBUG] PCI: 00:00:14.2 init
[DEBUG] PCI: 00:00:14.2 init finished in 0 msecs
[DEBUG] PCI: 00:00:16.0 init
[DEBUG] PCI: 00:00:16.0 init finished in 0 msecs
[DEBUG] PCI: 00:00:1c.0 init
[DEBUG] Initializing PCH PCIe bridge.
[DEBUG] PCI: 00:00:1c.0 init finished in 4 msecs
[DEBUG] PCI: 00:00:1f.0 init
[DEBUG] IOAPIC: Initializing IOAPIC at fec00000
[DEBUG] IOAPIC: ID = 0x00
[DEBUG] IOAPIC: 120 interrupts
[DEBUG] IOAPIC: Clearing IOAPIC at fec00000
[DEBUG] IOAPIC: Bootstrap Processor Local APIC = 0x00
[DEBUG] PCI: 00:00:1f.0 init finished in 23 msecs
[DEBUG] PCI: 00:00:1f.2 init
[DEBUG] RTC Init
[INFO ] Set power on after power failure.
[DEBUG] apm_control: Disabling ACPI.
[DEBUG] APMC done.
[DEBUG] Disabling Deep S3
[DEBUG] Enabling Deep S4
[DEBUG] Enabling Deep S5
[DEBUG] PCI: 00:00:1f.2 init finished in 35 msecs
[DEBUG] PCI: 00:00:1f.3 init
[DEBUG] azalia_audio: base = 0x9104c000
[DEBUG] azalia_audio: codec_mask = 0x06
[DEBUG] azalia_audio: initializing codec #2...
[DEBUG] azalia_audio: - vendor/device id: 0x8086280b
[DEBUG] azalia_audio: - no verb!
[DEBUG] azalia_audio: initializing codec #1...
[DEBUG] azalia_audio: - vendor/device id: 0x10ec0233
[DEBUG] azalia_audio: - verb size: 44
[DEBUG] azalia_audio: - verb loaded
[DEBUG] PCI: 00:00:1f.3 init finished in 48 msecs
[DEBUG] PCI: 00:00:1f.4 init
[DEBUG] PCI: 00:00:1f.4 init finished in 0 msecs
[DEBUG] PCI: 00:00:1f.6 init
[DEBUG] PCI: 00:00:1f.6 init finished in 0 msecs
[DEBUG] PNP: 002e.2 init
[DEBUG] PNP: 002e.2 init finished in 0 msecs
[DEBUG] PNP: 002e.a init
[INFO ] set power on after power fail
[DEBUG] PNP: 002e.a init finished in 5 msecs
[DEBUG] PNP: 002e.b init
[DEBUG] PNP: 002e.b init finished in 0 msecs
[DEBUG] PNP: 002e.e init
[DEBUG] PNP: 002e.e init finished in 0 msecs
[INFO ] Devices initialized
[DEBUG] BS: BS_DEV_INIT run times (exec / console): 155 / 307 ms
[DEBUG] TPM: Startup
[DEBUG] TPM: command 0x99 returned 0x0
[DEBUG] TPM: Asserting physical presence
[DEBUG] TPM: command 0x4000000a returned 0x0
[DEBUG] TPM: command 0x65 returned 0x0
[DEBUG] TPM: flags disable=0, deactivated=0, nvlocked=1
[INFO ] TPM: setup succeeded
[DEBUG] BS: BS_DEV_INIT exit times (exec / console): 3 / 31 ms
[INFO ] Finalize devices...
[DEBUG] PCI: 00:00:02.0 final
[DEBUG] PCI: 00:00:16.0 final
[DEBUG] PCI: 00:00:17.0 final
[DEBUG] PCI: 00:00:1f.2 final
[DEBUG] PCI: 00:00:1f.4 final
[INFO ] Devices finalized
[DEBUG] BS: BS_POST_DEVICE run times (exec / console): 0 / 25 ms
[INFO ] CBFS: Found 'fallback/dsdt.aml' @0xc73c0 size 0x2f48 in mcache @0x7abdc1b8
[WARN ] CBFS: 'fallback/slic' not found.
[INFO ] ACPI: Writing ACPI tables at 7aa00000.
[DEBUG] ACPI: * FACS
[DEBUG] SCI is IRQ 9, GSI 9
[DEBUG] ACPI: * FACP
[DEBUG] ACPI: added table 1/32, length now 44
[DEBUG] Found 1 CPU(s) with 2/4 physical/logical core(s) each.
[DEBUG] PSS: 3900MHz power 51000 control 0x2700 status 0x2700
[DEBUG] PSS: 3800MHz power 49077 control 0x2600 status 0x2600
[DEBUG] PSS: 3300MHz power 40212 control 0x2100 status 0x2100
[DEBUG] PSS: 2800MHz power 32105 control 0x1c00 status 0x1c00
[DEBUG] PSS: 2300MHz power 24812 control 0x1700 status 0x1700
[DEBUG] PSS: 1800MHz power 18221 control 0x1200 status 0x1200
[DEBUG] PSS: 1300MHz power 12329 control 0xd00 status 0xd00
[DEBUG] PSS: 800MHz power 7088 control 0x800 status 0x800
[DEBUG] PCI space above 4GB MMIO is at 0x27e000000, len = 0x7d82000000
[DEBUG] Empty min sleep state array returned
[INFO ] Returning default LPI constraint package
[INFO ] _SB.PCI0.PEPD: Intel Power Engine Plug-in
[INFO ] _SB.PCI0.RP01: WIFI Device GENERIC: 0.0
[DEBUG] PPI: Pending OS request: 0x78c18f7c (0x68f0031f)
[DEBUG] PPI: OS response: CMD 0x7081873c = 0x60f0021f
[INFO ] _SB_.PCI0.TPM: LPC TPM PNP: 0c31.0
[DEBUG] ACPI: * SSDT
[DEBUG] ACPI: added table 2/32, length now 52
[DEBUG] ACPI: * MCFG
[DEBUG] ACPI: added table 3/32, length now 60
[DEBUG] TCPA log created at 0x7a9f0000
[DEBUG] ACPI: * TCPA
[DEBUG] ACPI: added table 4/32, length now 68
[DEBUG] ACPI: * LPIT
[DEBUG] ACPI: added table 5/32, length now 76
[DEBUG] ACPI: * APIC
[DEBUG] ACPI: added table 6/32, length now 84
[DEBUG] ACPI: * SPCR
[DEBUG] ACPI: added table 7/32, length now 92
[DEBUG] current = 7aa047b0
[DEBUG] ACPI: * DMAR
[DEBUG] ACPI: added table 8/32, length now 100
[DEBUG] acpi_write_dbg2_pci_uart: Device not found
[DEBUG] ACPI: * HPET
[DEBUG] ACPI: added table 9/32, length now 108
[INFO ] ACPI: done.
[DEBUG] ACPI tables: 18560 bytes.
[DEBUG] smbios_write_tables: 7a9e8000
[DEBUG] SMBIOS firmware version is set to coreboot_version: '24.08-272-g735ca7f24ad4'
[INFO ] Create SMBIOS type 16
[INFO ] Create SMBIOS type 17
[INFO ] Create SMBIOS type 20
[INFO ] GENERIC: 0.0 (WIFI Device)
[DEBUG] SMBIOS tables: 1075 bytes.
[DEBUG] Writing table forward entry at 0x00000500
[DEBUG] Wrote coreboot table at: 0x00000500, 0x10 bytes, checksum 453c
[DEBUG] Writing coreboot table at 0x7aa24000
[DEBUG] 0. 0000000000000000-0000000000000fff: CONFIGURATION TABLES
[DEBUG] 1. 0000000000001000-000000000009ffff: RAM
[DEBUG] 2. 00000000000a0000-00000000000fffff: RESERVED
[DEBUG] 3. 0000000000100000-000000007a9e7fff: RAM
[DEBUG] 4. 000000007a9e8000-000000007aa7efff: CONFIGURATION TABLES
[DEBUG] 5. 000000007aa7f000-000000007abccfff: RAMSTAGE
[DEBUG] 6. 000000007abcd000-000000007affffff: CONFIGURATION TABLES
[DEBUG] 7. 000000007b000000-000000007fffffff: RESERVED
[DEBUG] 8. 00000000e0000000-00000000efffffff: RESERVED
[DEBUG] 9. 00000000fd000000-00000000fe00ffff: RESERVED
[DEBUG] 10. 00000000fed10000-00000000fed19fff: RESERVED
[DEBUG] 11. 00000000fed40000-00000000fed44fff: RESERVED
[DEBUG] 12. 00000000fed80000-00000000fed84fff: RESERVED
[DEBUG] 13. 00000000fed90000-00000000fed91fff: RESERVED
[DEBUG] 14. 0000000100000000-000000027dffffff: RAM
[DEBUG] Wrote coreboot table at: 0x7aa24000, 0x534 bytes, checksum 3a46
[DEBUG] coreboot table: 1356 bytes.
[DEBUG] IMD ROOT 0. 0x7afff000 0x00001000
[DEBUG] IMD SMALL 1. 0x7affe000 0x00001000
[DEBUG] FSP MEMORY 2. 0x7abfe000 0x00400000
[DEBUG] CONSOLE 3. 0x7abde000 0x00020000
[DEBUG] TIME STAMP 4. 0x7abdd000 0x00000910
[DEBUG] RO MCACHE 5. 0x7abdc000 0x00000364
[DEBUG] MEM INFO 6. 0x7abdb000 0x00000f48
[DEBUG] AFTER CAR 7. 0x7abcd000 0x0000e000
[DEBUG] RAMSTAGE 8. 0x7aa7e000 0x0014f000
[DEBUG] REFCODE 9. 0x7aa50000 0x0002e000
[DEBUG] SMM BACKUP 10. 0x7aa40000 0x00010000
[DEBUG] SMM COMBUFFER11. 0x7aa30000 0x00010000
[DEBUG] IGD OPREGION12. 0x7aa2c000 0x000030c8
[DEBUG] COREBOOT 13. 0x7aa24000 0x00008000
[DEBUG] ACPI 14. 0x7aa00000 0x00024000
[DEBUG] TCPA TCGLOG15. 0x7a9f0000 0x00010000
[DEBUG] SMBIOS 16. 0x7a9e8000 0x00008000
[DEBUG] IMD small region:
[DEBUG] IMD ROOT 0. 0x7affec00 0x00000400
[DEBUG] POWER STATE 1. 0x7affebc0 0x00000040
[DEBUG] FMAP 2. 0x7affea20 0x00000188
[DEBUG] FSP RUNTIME 3. 0x7affea00 0x00000004
[DEBUG] FSPM VERSION 4. 0x7affe9e0 0x00000004
[DEBUG] ROMSTAGE 5. 0x7affe9c0 0x00000004
[DEBUG] ROMSTG STCK 6. 0x7affe900 0x000000a8
[DEBUG] ACPI GNVS 7. 0x7affe8c0 0x00000038
[DEBUG] TPM PPI 8. 0x7affe760 0x0000015a
[DEBUG] BS: BS_WRITE_TABLES run times (exec / console): 3 / 682 ms
[DEBUG] MTRR: Physical address space:
[DEBUG] 0x0000000000000000 - 0x000000000009ffff size 0x000a0000 type 6
[DEBUG] 0x00000000000a0000 - 0x00000000000bffff size 0x00020000 type 0
[DEBUG] 0x00000000000c0000 - 0x000000007affffff size 0x7af40000 type 6
[DEBUG] 0x000000007b000000 - 0x000000007fffffff size 0x05000000 type 0
[DEBUG] 0x0000000080000000 - 0x000000008fffffff size 0x10000000 type 1
[DEBUG] 0x0000000090000000 - 0x00000000ffffffff size 0x70000000 type 0
[DEBUG] 0x0000000100000000 - 0x000000027dffffff size 0x17e000000 type 6
[DEBUG] apic_id 0x0: MTRR: Fixed MSR 0x250 0x0606060606060606
[DEBUG] apic_id 0x0: MTRR: Fixed MSR 0x258 0x0606060606060606
[DEBUG] apic_id 0x0: MTRR: Fixed MSR 0x259 0x0000000000000000
[DEBUG] apic_id 0x0: MTRR: Fixed MSR 0x268 0x0606060606060606
[DEBUG] apic_id 0x0: MTRR: Fixed MSR 0x269 0x0606060606060606
[DEBUG] apic_id 0x0: MTRR: Fixed MSR 0x26a 0x0606060606060606
[DEBUG] apic_id 0x0: MTRR: Fixed MSR 0x26b 0x0606060606060606
[DEBUG] apic_id 0x0: MTRR: Fixed MSR 0x26c 0x0606060606060606
[DEBUG] apic_id 0x0: MTRR: Fixed MSR 0x26d 0x0606060606060606
[DEBUG] apic_id 0x0: MTRR: Fixed MSR 0x26e 0x0606060606060606
[DEBUG] apic_id 0x0: MTRR: Fixed MSR 0x26f 0x0606060606060606
[DEBUG] apic_id 0x0 setup mtrr for CPU physical address size: 39 bits
[DEBUG] MTRR: default type WB/UC MTRR counts: 6/6.
[DEBUG] MTRR: UC selected as default type.
[DEBUG] MTRR: 0 base 0x0000000000000000 mask 0x0000007f80000000 type 6
[DEBUG] MTRR: 1 base 0x000000007b000000 mask 0x0000007fff000000 type 0
[DEBUG] MTRR: 2 base 0x000000007c000000 mask 0x0000007ffc000000 type 0
[DEBUG] MTRR: 3 base 0x0000000080000000 mask 0x0000007ff0000000 type 1
[DEBUG] MTRR: 4 base 0x0000000100000000 mask 0x0000007f00000000 type 6
[DEBUG] MTRR: 5 base 0x0000000200000000 mask 0x0000007f80000000 type 6
[DEBUG] apic_id 0x2: MTRR: Fixed MSR 0x250 0x0606060606060606
[DEBUG] apic_id 0x2: MTRR: Fixed MSR 0x258 0x0606060606060606
[DEBUG] apic_id 0x2: MTRR: Fixed MSR 0x259 0x0000000000000000
[DEBUG] apic_id 0x2: MTRR: Fixed MSR 0x268 0x0606060606060606
[DEBUG] apic_id 0x2: MTRR: Fixed MSR 0x269 0x0606060606060606
[DEBUG] apic_id 0x2: MTRR: Fixed MSR 0x26a 0x0606060606060606
[DEBUG] apic_id 0x2: MTRR: Fixed MSR 0x26b 0x0606060606060606
[DEBUG] apic_id 0x2: MTRR: Fixed MSR 0x26c 0x0606060606060606
[DEBUG] apic_id 0x2: MTRR: Fixed MSR 0x26d 0x0606060606060606
[DEBUG] apic_id 0x2: MTRR: Fixed MSR 0x26e 0x0606060606060606
[DEBUG] apic_id 0x2: MTRR: Fixed MSR 0x26f 0x0606060606060606
[DEBUG] apic_id 0x1: MTRR: Fixed MSR 0x250 0x0606060606060606
[DEBUG] apic_id 0x1: MTRR: Fixed MSR 0x258 0x0606060606060606
[DEBUG] apic_id 0x1: MTRR: Fixed MSR 0x259 0x0000000000000000
[DEBUG] apic_id 0x1: MTRR: Fixed MSR 0x268 0x0606060606060606
[DEBUG] apic_id 0x1: MTRR: Fixed MSR 0x269 0x0606060606060606
[DEBUG] apic_id 0x1: MTRR: Fixed MSR 0x26a 0x0606060606060606
[DEBUG] apic_id 0x1: MTRR: Fixed MSR 0x26b 0x0606060606060606
[DEBUG] apic_id 0x1: MTRR: Fixed MSR 0x26c 0x0606060606060606
[DEBUG] apic_id 0x1: MTRR: Fixed MSR 0x26d 0x0606060606060606
[DEBUG] apic_id 0x1: MTRR: Fixed MSR 0x26e 0x0606060606060606
[DEBUG] apic_id 0x1: MTRR: Fixed MSR 0x26f 0x0606060606060606
[DEBUG] apic_id 0x2 setup mtrr for CPU physical address size: 39 bits
[DEBUG] apic_id 0x3: MTRR: Fixed MSR 0x250 0x0606060606060606
[DEBUG] apic_id 0x3: MTRR: Fixed MSR 0x258 0x0606060606060606
[DEBUG] apic_id 0x3: MTRR: Fixed MSR 0x259 0x0000000000000000
[DEBUG] apic_id 0x3: MTRR: Fixed MSR 0x268 0x0606060606060606
[DEBUG] apic_id 0x3: MTRR: Fixed MSR 0x269 0x0606060606060606
[DEBUG] apic_id 0x3: MTRR: Fixed MSR 0x26a 0x0606060606060606
[DEBUG] apic_id 0x3: MTRR: Fixed MSR 0x26b 0x0606060606060606
[DEBUG] apic_id 0x3: MTRR: Fixed MSR 0x26c 0x0606060606060606
[DEBUG] apic_id 0x3: MTRR: Fixed MSR 0x26d 0x0606060606060606
[DEBUG] apic_id 0x3: MTRR: Fixed MSR 0x26e 0x0606060606060606
[DEBUG] apic_id 0x3: MTRR: Fixed MSR 0x26f 0x0606060606060606
[DEBUG] apic_id 0x1 setup mtrr for CPU physical address size: 39 bits
[DEBUG] apic_id 0x3 setup mtrr for CPU physical address size: 39 bits
[DEBUG] MTRR: TEMPORARY Physical address space:
[DEBUG] 0x000000007b000000 - 0x00000000ff7fffff size 0x84800000 type 0
[DEBUG] 0x00000000ff800000 - 0x00000000ffffffff size 0x00800000 type 5
[DEBUG] MTRR: default type WB/UC MTRR counts: 11/6.
[DEBUG] MTRR: 3 base 0x00000000ff800000 mask 0x0000007fff800000 type 5
[DEBUG] MTRR check
[DEBUG] Fixed MTRRs : Enabled
[DEBUG] Variable MTRRs: Enabled
[DEBUG] BS: BS_WRITE_TABLES exit times (exec / console): 205 / 308 ms
[INFO ] CBFS: Found 'fallback/payload' @0x1586c0 size 0x151e6b in mcache @0x7abdc2f4
[DEBUG] Checking segment from ROM address 0xff9a88ec
[DEBUG] Checking segment from ROM address 0xff9a8908
[DEBUG] Loading segment from ROM address 0xff9a88ec
[DEBUG] code (compression=1)
[DEBUG] New segment dstaddr 0x00800000 memsize 0x1000000 srcaddr 0xff9a8924 filesize 0x151e33
[DEBUG] Loading Segment: addr: 0x00800000 memsz: 0x0000000001000000 filesz: 0x0000000000151e33
[DEBUG] using LZMA
[DEBUG] Loading segment from ROM address 0xff9a8908
[DEBUG] Entry Point 0x008016da
[DEBUG] BS: BS_PAYLOAD_LOAD run times (exec / console): 135 / 60 ms
[DEBUG] Finalizing chipset.
[DEBUG] ME: Host Firmware Status Register 1 : 0x90000245
[DEBUG] ME: Host Firmware Status Register 2 : 0x83108106
[DEBUG] ME: Host Firmware Status Register 3 : 0x00000300
[DEBUG] ME: Host Firmware Status Register 4 : 0x00084000
[DEBUG] ME: Host Firmware Status Register 5 : 0x00000000
[DEBUG] ME: Host Firmware Status Register 6 : 0x40000000
[DEBUG] ME: FW Partition Table : OK
[DEBUG] ME: Bringup Loader Failure : NO
[DEBUG] ME: Firmware Init Complete : YES
[DEBUG] ME: Manufacturing Mode : NO
[DEBUG] ME: Boot Options Present : NO
[DEBUG] ME: Update In Progress : NO
[DEBUG] ME: D3 Support : NO
[DEBUG] ME: D0i3 Support : YES
[DEBUG] ME: Low Power State Enabled : NO
[DEBUG] ME: CPU Replaced : NO
[DEBUG] ME: CPU Replacement Valid : YES
[DEBUG] ME: Current Working State : Normal
[DEBUG] ME: Current Operation State : M0 with UMA
[DEBUG] ME: Current Operation Mode : Normal
[DEBUG] ME: Error Code : No Error
[DEBUG] ME: Progress Phase : Unknown (8)
[DEBUG] ME: Power Management Event : Global reset after an error
[DEBUG] ME: Progress Phase State : Unknown phase: 0x08 state: 0x10
[DEBUG] ME: Power Down Mitigation : NO
[DEBUG] ME: Firmware SKU : Unknown (0x0)
[DEBUG] ME: FPF status : fused
[DEBUG] apm_control: Finalizing SMM.
[DEBUG] APMC done.
[DEBUG] BS: BS_PAYLOAD_LOAD exit times (exec / console): 10 / 153 ms
[DEBUG] mp_park_aps done after 0 msecs.
[DEBUG] Jumping to boot code at 0x008016da(0x7aa24000)`
I tried many many parameters, but results are always the same.
VM Updated by Vittorio Mori about 2 years ago Actions #1
  • Category set to board support
  • Affected OS set to ANY
VM Updated by Vittorio Mori about 2 years ago Actions #2
New findings: it seems there's a switch(GPIO?) in the OEM/Lenovo BIOS on M700 Tiny that disables the wifi completely.
I've found it hidden into AMI BIOS Devices-> Network Setup -> Wireless LAN (enable/disable).
When I set it "disabled" it behaves as coreboot does i.e. NO CARD.
So my Intel 8260BGW wifi card gets disabled when I use coreboot.
I hope there's a fix.
MK Updated by Michał Kopeć about 2 years ago · Edited Actions #3
Hi!
The intel GOP driver is integrated into FSP. In make menuconfig, switch Devices -> Graphics Initialization to Run a GOP driver. This will enable the FSP GOP driver, no extra blobs are needed (apart from VBT but that is in tree and should be automatically added when you set the option to GOP).
Hmm I tested with Intel AX210 and currently have a Realtek RTL8125 card in there and it works for me without any apparent issues. Your logs show that the root port is enabled but nothing is detected at all which is weird.
  • Does the same issue happen with a Skylake processor, if you have one to test with?
  • Could you boot into stock BIOS with the wifi card enabled and do a dump of GPIOs using inteltool? (in coreboot repo's util/inteltool directory, run make and sudo ./inteltool -g)
VM Updated by Vittorio Mori about 2 years ago Actions #4
Michał Kopeć wrote in #note-3:
Hi!
I did it, but I get no display with this method. No display on VGA port, no display on DP1 port no display on DP2 port. I think machine is running, I get USB devices prepped, but no display. Works with default setting (libgfx). Will try again on a clean coreboot git clone.
My thoughts exactly.
Yes, both SKylake or KabyLake, slot is not enumerated. I get PCI AER errors on Linux, then "card present / no link" continous errors in dmesg.
Here it is (wifi working, Lenovo OEM software):
============= GPIOS =============
------- GPIO Community 0 -------
PCR Port ID: 0xaf0000
------- GPIO Group GPP_A -------
0x0400: 0x0000001884000502 GPP_A0 RCIN#
0x0408: 0x0000301984000402 GPP_A1 LAD0
0x0410: 0x0000301a84000402 GPP_A2 LAD1
0x0418: 0x0000301b84000402 GPP_A3 LAD2
0x0420: 0x0000301c84000402 GPP_A4 LAD3
0x0428: 0x0000001d84000600 GPP_A5 LFRAME#
0x0430: 0x0000001e84000402 GPP_A6 SERIRQ
0x0438: 0x0000001f84000502 GPP_A7 PIRQA#
0x0440: 0x0000002084000500 GPP_A8 CLKRUN#
0x0448: 0x0000102184000600 GPP_A9 CLKOUT_LPC0
0x0450: 0x0000102284000600 GPP_A10 CLKOUT_LPC1
0x0458: 0x0000002384000502 GPP_A11 PME#
0x0460: 0x0000002444000300 GPP_A12 GPIO
0x0468: 0x0000002544000600 GPP_A13 SUSWARN#/SUSPWRDNACK
0x0470: 0x0000002644000600 GPP_A14 SUS_STAT#
0x0478: 0x0000302744000502 GPP_A15 SUS_ACK#
0x0480: 0x0000002844000300 GPP_A16 GPIO
0x0488: 0x0000002984000201 GPP_A17 GPIO
0x0490: 0x0000002a44000300 GPP_A18 GPIO
0x0498: 0x0000002b84000102 GPP_A19 GPIO
0x04a0: 0x0000002c44000300 GPP_A20 GPIO
0x04a8: 0x0000002d44000300 GPP_A21 GPIO
0x04b0: 0x0000002e84000102 GPP_A22 GPIO
0x04b8: 0x0000002f84000201 GPP_A23 GPIO
------- GPIO Group GPP_B -------
0x04c0: 0x0000003044000200 GPP_B0 GPIO
0x04c8: 0x0000003144000200 GPP_B1 GPIO
0x04d0: 0x0000003284000502 GPP_B2 VRALERT#
0x04d8: 0x0000003384000102 GPP_B3 GPIO
0x04e0: 0x0000003484000102 GPP_B4 GPIO
0x04e8: 0x0000003544000300 GPP_B5 GPIO
0x04f0: 0x0000003684000102 GPP_B6 GPIO
0x04f8: 0x0000003744000300 GPP_B7 GPIO
0x0500: 0x0000003844000300 GPP_B8 GPIO
0x0508: 0x0000003944000300 GPP_B9 GPIO
0x0510: 0x0000003a84000102 GPP_B10 GPIO
0x0518: 0x0000003b44000200 GPP_B11 GPIO
0x0520: 0x0000003c44000600 GPP_B12 SLP_S0#
0x0528: 0x0000003d44000600 GPP_B13 PLTRST#
0x0530: 0x0000103e84000600 GPP_B14 SPKR
0x0538: 0x0000003f84000100 GPP_B15 GPIO
0x0540: 0x0000004084000100 GPP_B16 GPIO
0x0548: 0x0000004184000102 GPP_B17 GPIO
0x0550: 0x0000004284000200 GPP_B18 GPIO
0x0558: 0x0000004384000600 GPP_B19 GSPI1_CS#
0x0560: 0x0000004484000102 GPP_B20 GPIO
0x0568: 0x0000004584000102 GPP_B21 GPIO
0x0570: 0x0000004684000200 GPP_B22 GPIO
0x0578: 0x0000104784000500 GPP_B23 SML1ALERT#
------- GPIO Community 1 -------
PCR Port ID: 0xae0000
------- GPIO Group GPP_C -------
0x0400: 0x0000004844000502 GPP_C0 SMBCLK
0x0408: 0x0000004944000502 GPP_C1 SMBDATA
0x0410: 0x0000004a44000102 GPP_C2 GPIO
0x0418: 0x0000004b44000502 GPP_C3 SML0CLK
0x0420: 0x0000004c44000502 GPP_C4 SML0DATA
0x0428: 0x0000004d84000500 GPP_C5 SML0ALERT#
0x0430: 0x0000004e44000502 GPP_C6 SML1CLK
0x0438: 0x0000004f44000502 GPP_C7 SML1DATA
0x0440: 0x0000005084000102 GPP_C8 GPIO
0x0448: 0x0000005144000300 GPP_C9 GPIO
0x0450: 0x0000005244000300 GPP_C10 GPIO
0x0458: 0x0000005344000300 GPP_C11 GPIO
0x0460: 0x0000005444000300 GPP_C12 GPIO
0x0468: 0x0000005584000102 GPP_C13 GPIO
0x0470: 0x0000005644000300 GPP_C14 GPIO
0x0478: 0x0000005784000200 GPP_C15 GPIO
0x0480: 0x0000005844000502 GPP_C16 I2C0_SDA
0x0488: 0x0000005944000502 GPP_C17 I2C0_SCL
0x0490: 0x0000005a84000102 GPP_C18 GPIO
0x0498: 0x0000005b84000102 GPP_C19 GPIO
0x04a0: 0x0000005c84000502 GPP_C20 UART2_RXD
0x04a8: 0x0000005d84000600 GPP_C21 UART2_TXD
0x04b0: 0x0000005e44000300 GPP_C22 GPIO
0x04b8: 0x0000005f84000200 GPP_C23 GPIO
------- GPIO Group GPP_D -------
0x04c0: 0x0000006044000300 GPP_D0 GPIO
0x04c8: 0x0000006144000300 GPP_D1 GPIO
0x04d0: 0x0000006244000300 GPP_D2 GPIO
0x04d8: 0x0000006344000300 GPP_D3 GPIO
0x04e0: 0x0000006444000300 GPP_D4 GPIO
0x04e8: 0x0000006544000300 GPP_D5 GPIO
0x04f0: 0x0000006644000300 GPP_D6 GPIO
0x04f8: 0x0000006744000300 GPP_D7 GPIO
0x0500: 0x0000006844000300 GPP_D8 GPIO
0x0508: 0x0000006984000201 GPP_D9 GPIO
0x0510: 0x0000006a84000201 GPP_D10 GPIO
0x0518: 0x0000006b44000300 GPP_D11 GPIO
0x0520: 0x0000006c44000300 GPP_D12 GPIO
0x0528: 0x0000006d84000102 GPP_D13 GPIO
0x0530: 0x0000006e84000102 GPP_D14 GPIO
0x0538: 0x0000006f84000102 GPP_D15 GPIO
0x0540: 0x0000007084000102 GPP_D16 GPIO
0x0548: 0x0000007184000102 GPP_D17 GPIO
0x0550: 0x0000007284000102 GPP_D18 GPIO
0x0558: 0x0000007344000300 GPP_D19 GPIO
0x0560: 0x0000007444000300 GPP_D20 GPIO
0x0568: 0x0000007544000300 GPP_D21 GPIO
0x0570: 0x0000007644000300 GPP_D22 GPIO
0x0578: 0x0000007784000102 GPP_D23 GPIO
------- GPIO Group GPP_E -------
0x0580: 0x0000001884000102 GPP_E0 GPIO
0x0588: 0x0000001944000300 GPP_E1 GPIO
0x0590: 0x0000001a84000102 GPP_E2 GPIO
0x0598: 0x0000001b84000102 GPP_E3 GPIO
0x05a0: 0x0000001c44000300 GPP_E4 GPIO
0x05a8: 0x0000001d44000300 GPP_E5 GPIO
0x05b0: 0x0000001e44000300 GPP_E6 GPIO
0x05b8: 0x0000001f84000102 GPP_E7 GPIO
0x05c0: 0x0000002084000600 GPP_E8 SATA_LED#
0x05c8: 0x0000002144000502 GPP_E9 USB_OC0#
0x05d0: 0x0000002244000502 GPP_E10 USB_OC1#
0x05d8: 0x0000002344000502 GPP_E11 USB_OC2#
0x05e0: 0x0000002444000502 GPP_E12 USB_OC3#
------- GPIO Group GPP_F -------
0x05e8: 0x0000002544000300 GPP_F0 GPIO
0x05f0: 0x0000002642080102 GPP_F1 GPIO
0x05f8: 0x0000002742080102 GPP_F2 GPIO
0x0600: 0x0000002844000300 GPP_F3 GPIO
0x0608: 0x0000002944000300 GPP_F4 GPIO
0x0610: 0x0000002a42080102 GPP_F5 GPIO
0x0618: 0x0000002b04000102 GPP_F6 GPIO
0x0620: 0x0000002c44000300 GPP_F7 GPIO
0x0628: 0x0000002d44000300 GPP_F8 GPIO
0x0630: 0x0000002e44000300 GPP_F9 GPIO
0x0638: 0x0000002f80100102 GPP_F10 GPIO
0x0640: 0x0000003084000102 GPP_F11 GPIO
0x0648: 0x0000003180100102 GPP_F12 GPIO
0x0650: 0x0000003280100100 GPP_F13 GPIO
0x0658: 0x0000003340100100 GPP_F14 GPIO
0x0660: 0x0000003444000502 GPP_F15 USB_OC4#
0x0668: 0x0000003544000300 GPP_F16 GPIO
0x0670: 0x0000003644000300 GPP_F17 GPIO
0x0678: 0x0000003744000300 GPP_F18 GPIO
0x0680: 0x0000003884000102 GPP_F19 GPIO
0x0688: 0x0000003984000102 GPP_F20 GPIO
0x0690: 0x0000003a84000102 GPP_F21 GPIO
0x0698: 0x0000003b44000300 GPP_F22 GPIO
0x06a0: 0x0000003c44000300 GPP_F23 GPIO
------- GPIO Group GPP_G -------
0x06a8: 0x0000003d44000300 GPP_G0 GPIO
0x06b0: 0x0000003e44000300 GPP_G1 GPIO
0x06b8: 0x0000003f44000300 GPP_G2 GPIO
0x06c0: 0x0000004044000300 GPP_G3 GPIO
0x06c8: 0x0000004144000300 GPP_G4 GPIO
0x06d0: 0x0000004244000300 GPP_G5 GPIO
0x06d8: 0x0000004344000300 GPP_G6 GPIO
0x06e0: 0x0000004444000300 GPP_G7 GPIO
0x06e8: 0x0000004544000700 GPP_G8 FAN_PWM_0
0x06f0: 0x0000004644000700 GPP_G9 FAN_PWM_1
0x06f8: 0x0000004744000700 GPP_G10 FAN_PWM_2
0x0700: 0x0000004844000700 GPP_G11 FAN_PWM_3
0x0708: 0x0000004984000100 GPP_G12 GPIO
0x0710: 0x0000004a84000102 GPP_G13 GPIO
0x0718: 0x0000004b84000100 GPP_G14 GPIO
0x0720: 0x0000004c84000100 GPP_G15 GPIO
0x0728: 0x0000004d84000102 GPP_G16 GPIO
0x0730: 0x0000004e84000102 GPP_G17 GPIO
0x0738: 0x0000004f80100200 GPP_G18 GPIO
0x0740: 0x0000005080880102 GPP_G19 GPIO
0x0748: 0x0000005184000102 GPP_G20 GPIO
0x0750: 0x0000005284000102 GPP_G21 GPIO
0x0758: 0x0000005344000300 GPP_G22 GPIO
0x0760: 0x0000005444000300 GPP_G23 GPIO
------- GPIO Group GPP_H -------
0x0768: 0x0000005544000300 GPP_H0 GPIO
0x0770: 0x0000005644000300 GPP_H1 GPIO
0x0778: 0x0000005744000300 GPP_H2 GPIO
0x0780: 0x0000005844000300 GPP_H3 GPIO
0x0788: 0x0000005984000102 GPP_H4 GPIO
0x0790: 0x0000005a44000300 GPP_H5 GPIO
0x0798: 0x0000005b84000102 GPP_H6 GPIO
0x07a0: 0x0000005c44000300 GPP_H7 GPIO
0x07a8: 0x0000005d44000300 GPP_H8 GPIO
0x07b0: 0x0000005e84000102 GPP_H9 GPIO
0x07b8: 0x0000005f44000300 GPP_H10 GPIO
0x07c0: 0x0000006084000201 GPP_H11 GPIO
0x07c8: 0x0000006184000200 GPP_H12 GPIO
0x07d0: 0x0000006244000300 GPP_H13 GPIO
0x07d8: 0x0000006344000300 GPP_H14 GPIO
0x07e0: 0x0000006444000300 GPP_H15 GPIO
0x07e8: 0x0000006544000300 GPP_H16 GPIO
0x07f0: 0x0000006644000300 GPP_H17 GPIO
0x07f8: 0x0000006744000300 GPP_H18 GPIO
0x0800: 0x0000006884000102 GPP_H19 GPIO
0x0808: 0x0000006984000102 GPP_H20 GPIO
0x0810: 0x0000006a84000201 GPP_H21 GPIO
0x0818: 0x0000006b84000103 GPP_H22 GPIO
0x0820: 0x0000006c84000102 GPP_H23 GPIO
------- GPIO Community 2 -------
PCR Port ID: 0xad0000
-------- GPIO Group GPD --------
0x0400: 0x0000001884000102 GPD0 GPIO
0x0408: 0x0000001904000102 GPD1 GPIO
0x0410: 0x0000101a00080502 GPD2 LAN_WAKE#
0x0418: 0x0000301b04000502 GPD3 PWRBTN#
0x0420: 0x0000001c04000600 GPD4 SLP_S3#
0x0428: 0x0000001d04000600 GPD5 SLP_S4#
0x0430: 0x0000001e04000600 GPD6 SLP_A#
0x0438: 0x0000001f04000201 GPD7 GPIO
0x0440: 0x0000002004000600 GPD8 SUSCLK
0x0448: 0x0000002104000200 GPD9 GPIO
0x0450: 0x0000002204000600 GPD10 SLP_S5#
0x0458: 0x0000002304000600 GPD11 LANPHYPC
------- GPIO Community 3 -------
PCR Port ID: 0xac0000
------- GPIO Group GPP_I -------
0x0400: 0x0000006d84000502 GPP_I0 DDPB_HPD0
0x0408: 0x0000006e84000500 GPP_I1 DDPC_HPD1
0x0410: 0x0000006f84000500 GPP_I2 DDPD_HPD2
0x0418: 0x0000007082040100 GPP_I3 GPIO
0x0420: 0x0000007184000100 GPP_I4 GPIO
0x0428: 0x0000007284000502 GPP_I5 DDPB_CTRLCLK
0x0430: 0x0000107384000502 GPP_I6 DDPB_CTRLDATA
0x0438: 0x0000007484000502 GPP_I7 DDPC_CTRLCLK
0x0440: 0x0000107584000502 GPP_I8 DDPC_CTRLDATA
0x0448: 0x0000007684000502 GPP_I9 DDPD_CTRLCLK
0x0450: 0x0000107784000502 GPP_I10 DDPD_CTRLDATA
VM Updated by Vittorio Mori about 2 years ago Actions #5
Vittorio Mori wrote in #note-4:
Hi!
Here is LSPCI of the PCIe root port & wireless network card (working):
00:1c.0 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #7 (rev f1) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 0
Interrupt: pin C routed to IRQ 120
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000f000-00000fff [disabled]
Memory behind bridge: df000000-df0fffff [size=1M]
Prefetchable memory behind bridge: 00000000fff00000-00000000000fffff [disabled]
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
BridgeCtl: Parity- SERR+ NoISA- VGA- VGA16+ MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Capabilities: [40] Express (v2) Root Port (Slot+), MSI 00
DevCap: MaxPayload 256 bytes, PhantFunc 0
ExtTag- RBE+
DevCtl: CorrErr+ NonFatalErr+ FatalErr+ UnsupReq+
RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop-
MaxPayload 128 bytes, MaxReadReq 128 bytes
DevSta: CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr+ TransPend-
LnkCap: Port #7, Speed 8GT/s, Width x1, ASPM not supported
ClockPM- Surprise- LLActRep+ BwNot+ ASPMOptComp+
LnkCtl: ASPM Disabled; RCB 64 bytes, Disabled- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 2.5GT/s (downgraded), Width x1 (ok)
TrErr- Train- SlotClk+ DLActive+ BWMgmt+ ABWMgmt-
SltCap: AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug- Surprise-
Slot #0, PowerLimit 10.000W; Interlock- NoCompl+
SltCtl: Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
Control: AttnInd Unknown, PwrInd Unknown, Power- Interlock-
SltSta: Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet+ Interlock-
Changed: MRL- PresDet- LinkState+
RootCap: CRSVisible-
RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna+ CRSVisible-
RootSta: PME ReqID 0000, PMEStatus- PMEPending-
DevCap2: Completion Timeout: Range ABC, TimeoutDis+ NROPrPrP- LTR-
10BitTagComp- 10BitTagReq- OBFF Not Supported, ExtFmt- EETLPPrefix-
EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
FRS- LN System CLS Not Supported, TPHComp- ExtTPHComp- ARIFwd+
AtomicOpsCap: Routing- 32bit- 64bit- 128bitCAS-
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis- LTR- OBFF Disabled, ARIFwd-
AtomicOpsCtl: ReqEn- EgressBlck-
LnkCap2: Supported Link Speeds: 2.5-8GT/s, Crosslink- Retimer- 2Retimers- DRS-
LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete- EqualizationPhase1-
EqualizationPhase2- EqualizationPhase3- LinkEqualizationRequest-
Retimer- 2Retimers- CrosslinkRes: unsupported
Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit-
Address: fee04004 Data: 0021
Capabilities: [90] Subsystem: Lenovo 100 Series/C230 Series Chipset Family PCI Express Root Port
Capabilities: [a0] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [100 v1] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt+ RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+
AERCap: First Error Pointer: 00, ECRCGenCap- ECRCGenEn- ECRCChkCap- ECRCChkEn-
MultHdrRecCap- MultHdrRecEn- TLPPfxPres- HdrLogCap-
HeaderLog: 00000000 00000000 00000000 00000000
RootCmd: CERptEn+ NFERptEn+ FERptEn+
RootSta: CERcvd- MultCERcvd- UERcvd- MultUERcvd-
FirstFatal- NonFatalMsg- FatalMsg- IntMsg 0
ErrorSrc: ERR_COR: 0000 ERR_FATAL/NONFATAL: 0000
Capabilities: [140 v1] Access Control Services
ACSCap: SrcValid+ TransBlk+ ReqRedir+ CmpltRedir+ UpstreamFwd- EgressCtrl- DirectTrans-
ACSCtl: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
Capabilities: [220 v1] Secondary PCI Express
LnkCtl3: LnkEquIntrruptEn- PerformEqu-
LaneErrStat: 0
Kernel driver in use: pcieport
00: 86 80 16 a1 07 04 10 00 f1 00 04 06 00 00 81 00
10: 00 00 00 00 00 00 00 00 00 01 01 00 f0 00 00 20
20: 00 df 00 df f1 ff 01 00 00 00 00 00 00 00 00 00
30: 00 00 00 00 40 00 00 00 00 00 00 00 0b 03 12 00
01:00.0 Network controller: Intel Corporation Wireless 8260 (rev 3a)
Subsystem: Intel Corporation Dual Band Wireless-AC 8260
Physical Slot: 0
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Latency: 0
Interrupt: pin A routed to IRQ 126
Region 0: Memory at df000000 (64-bit, non-prefetchable) [size=8K]
Capabilities: [c8] Power Management version 3
Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Capabilities: [d0] MSI: Enable+ Count=1/1 Maskable- 64bit+
Address: 00000000fee04004 Data: 0023
Capabilities: [40] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s <512ns, L1 unlimited
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 0.000W
DevCtl: CorrErr- NonFatalErr- FatalErr- UnsupReq-
RlxdOrd+ ExtTag- PhantFunc- AuxPwr+ NoSnoop+ FLReset-
DevSta: CorrErr+ NonFatalErr- FatalErr- UnsupReq+ AuxPwr+ TransPend-
LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L1, Exit Latency L1 <8us
ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
ExtSynch- ClockPM+ AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 2.5GT/s (ok), Width x1 (ok)
TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range B, TimeoutDis+ NROPrPrP- LTR+
10BitTagComp- 10BitTagReq- OBFF Via WAKE#, ExtFmt- EETLPPrefix-
FRS- TPHComp- ExtTPHComp-
AtomicOpsCap: 32bit- 64bit- 128bitCAS-
DevCtl2: Completion Timeout: 16ms to 55ms, TimeoutDis- LTR- OBFF Disabled,
LnkCtl2: Target Link Speed: 2.5GT/s, EnterCompliance- SpeedDis-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+
Capabilities: [140 v1] Device Serial Number f0-d5-bf-ff-ff-38-e3-70
Capabilities: [14c v1] Latency Tolerance Reporting
Max snoop latency: 71680ns
Max no snoop latency: 71680ns
Capabilities: [154 v1] L1 PM Substates
L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
PortCommonModeRestoreTime=30us PortTPowerOnTime=18us
L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
T_CommonMode=0us LTR1.2_Threshold=0ns
L1SubCtl2: T_PwrOn=10us
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
00: 86 80 f3 24 06 04 10 00 3a 00 80 02 00 00 00 00
10: 04 00 00 df 00 00 00 00 00 00 00 00 00 00 00 00
20: 00 00 00 00 00 00 00 00 00 00 00 00 86 80 10 00
30: 00 00 00 00 c8 00 00 00 00 00 00 00 0b 01 00 00
VM Updated by Vittorio Mori about 2 years ago Actions #6
I can confirm 100% that FSP GOP DRIVER is NOT WORKING on M700 tiny with any Skylake/Kabylake CPU.
I do not get any video output on any port, testes right now with vanilla coreboot and vanilla config freshly compiled.
Libgfxinit works OK but display ports get uninitialized when booting windows 10/11.
Once windows has booted, the display stays OFF: I have to unplug/plug the cable to activate display.
This does not happen in Linux: once the kernel has loaded the gfx driver, it works straight away.
The display ports also work correctly with Lenovo OEM original bios i.e. they get correctly initialized when windows 10/11 boots, the display does not turn off (linux always OK).
WS Updated by Walter Sonius about 2 years ago · Edited Actions #7
Not a real solution but have you tried taping/isolating pcie pin(s) on the Wifi adapter mini-pcie/ngff? Found some examples see blog thecomputerperson
Can you also post the GPIO output with the inteltool of the OEM BIOS but than with the BIOS option of the Wireless lan to "disabled"(versus the enabled you did earlier) maybe a simple diff might reveal a solution?
Perhaps do the same for the superiotool -dV, with OEM BIOS with the wireless adapter enabled and once while its disabled?
MK Updated by Michał Kopeć about 2 years ago Actions #8
Should be fixed by https://review.coreboot.org/c/coreboot/+/84813
Vittorio, can you check and confirm if it fixes your issue?
