Feature #7
closed
AC AC
gnawty support based on acer cb3-111
Feature #7: gnawty support based on acer cb3-111
Added by Alexander Couzens about 11 years ago. Updated almost 4 years ago.
Closed
board support
11/20/2015
Adding google gnawty boards.
This board is very similiar to rambi, the only difference known is the ram configuration.
http://review.coreboot.org/#/c/12500
https://www.coreboot.org/Board:acer/cb3-111
SeaBIOS hangs with message:
Press F12 ...
but pressing f12 does nothing.
Booting ELF payload with openwrt fails because e820 isn't properly passed.
Using Linux Payload + x64 kernel openwrt boots up.
Files
bootup_x86_64_openwrt (60 KB) bootup_x86_64_openwrt Alexander Couzens, 11/20/2015 10:07 PM
vga_bios_hangs (29.1 KB) vga_bios_hangs Alexander Couzens, 11/20/2015 11:04 PM
dmesg (63.6 KB) dmesg dmesg_chromeos_gnawty Alexander Couzens, 11/21/2015 03:03 AM
lspci_vvv (10.3 KB) lspci_vvv chromeos Alexander Couzens, 11/21/2015 03:08 AM
lspci (789 Bytes) lspci chromso Alexander Couzens, 11/21/2015 03:08 AM
lspci_vvttnn (716 Bytes) lspci_vvttnn chromeos Alexander Couzens, 11/21/2015 03:09 AM
booting_4.1 (58.7 KB) booting_4.1 openwrt with 4.1 Alexander Couzens, 11/22/2015 10:35 PM
booting_4.1_with_ioapic (63.5 KB) booting_4.1_with_ioapic openwrt with 4.1 but with select ioapic in cb Alexander Couzens, 11/23/2015 01:46 AM
AC Updated by Alexander Couzens about 11 years ago Actions #3
AC Updated by Alexander Couzens about 11 years ago Actions #4
AC Updated by Alexander Couzens about 11 years ago Actions #6
AC Updated by Alexander Couzens about 11 years ago Actions #7
I can see
[    0.000000] ACPI: PM-Timer IO Port: 0x408
[    0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x02] enabled)
[    0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[    0.000000] I/O APIC 0xfec00000 registers return all ones, skipping!
But coreboot detects
APIC: 00: enabled 1
APIC: 02: enabled 1
APIC: 00 (Intel BayTrail SoC)
APIC: 02 (unknown)
I guess the second should not be enabled. but why is linux only finds this one ONLY ?
AC Updated by Alexander Couzens about 11 years ago Actions #8
last upstream rev:
commit 7dcf9d51e5ffadfcf8b5fceddcddb4e1d0a7db37
Author: Julius Werner <jwerner@chromium.org>
Date:   Fri Oct 16 13:10:02 2015 -0700
    arm64: tegra132: tegra210: Remove old arm64/stage_entry.S
    Change-Id: Ib3a0448b30ac9c7132581464573efd5e86e03698
    Signed-off-by: Julius Werner <jwerner@chromium.org>
    Reviewed-on: http://review.coreboot.org/12078
AC Updated by Alexander Couzens about 11 years ago Actions #10
the second APIC 02 looks good, because it's the second processor.
LR Updated by lx r about 11 years ago Actions #11
linux is now booting.
AC Updated by Alexander Couzens about 11 years ago Actions #12
  • Description updated (diff)
AC Updated by Alexander Couzens about 11 years ago Actions #13
Missing:
  • sdcard as file for SeaBIOS
  • migrate gnawty into rambi
  • pci irq routing
  • test if seabios can work with irq routing
SeaBios is booting without hardware irqs.
I'm waiting for a board to hack on.
MR Updated by Martin Roth almost 4 years ago Actions #14
  • Status changed from In Progress to Closed
No updates in 7 years. Closing.
MD Updated by Matt DeVillier almost 4 years ago Actions #15
Martin Roth wrote in #note-14:
also, gnawty has been supported as a rambi variant since early 2017
