Bug #2
closedx201: broken on git master
100%
first bad commit: 456f495d4e3199146590bcb5cd76e12053c33c9e.
commit is causing
- unreliable/broken sata (linux doesn't boot)
- broken usb
- usb storage: dd if=file of=/dev/sdb write broken data to usb storage
- usb serial: just stops
- lot's of errors in dmesg
AC Updated by Alexander Couzens about 11 years ago
- Subject changed from x201: head broken to x201: broken on git master
SR Updated by Stefan Reinauer about 11 years ago
The commit before works?
commit is causing
- broken usb
Also, is there no way to assign a bug to someone?
- Assignee set to Alexander Couzens
yes
commit is causing
- broken usb
it's possible. But not for somebody who is not in this project. everybody who hasn't assign to this project can only report stuff.
NH Updated by Nico Huber almost 11 years ago
Similar commit (a3e41c0) for 206ax led to instabilities too. We ended up
disabling CONFIG_PARALLEL_CPU_INIT there (see 0ace013).
FL Updated by First name * Last name * over 10 years ago
Actually pre-456f495d4e3199146590bcb5cd76e12053c33c9e is troublesome too: sata will misbehave if the laptop is docked, although linux boots.
LR Updated by lx r about 10 years ago
- Status changed from New to Closed
