Bug #3
closed
PG PG
The build system isn't helpful when util/xcompile/xcompile fails because of missing dependencies.
Bug #3: The build system isn't helpful when util/xcompile/xcompile fails because of missing dependencies.
Added by Patrick Georgi about 11 years ago. Updated about 11 years ago.
Closed
build system
11/18/2015
11/20/2015
100%
When trying to build coreboot without iasl installed, util/xcompile/xcompile die()s with an error and an empty .xcompile file, but the build system doesn't catch that.
This leads to unintuitive error messages such as "toolchain.inc:147: *** building bootblock without the required toolchain. Stop."
Instead, the build system should abort while pushing xcompile's complaint into the user's face.
PG Updated by Patrick Georgi about 11 years ago Actions #1
http://review.coreboot.org/12473 makes issues more obvious
SR Updated by Stefan Reinauer about 11 years ago Actions #3
  • Category set to build system
  • Assignee set to Patrick Georgi
PG Updated by Patrick Georgi about 11 years ago Actions #4
  • Due date set to 11/20/2015
An incomplete .xcompile is now removed with a request to redo the build. If a dependency is missing, the build will still fail, but since the xcompile utility is definitely called, it's error messages should be apparent.
