Bug #392
closedcoreboot 4.17 - SeaBIOS Windows 10 BSOD "ACPI Error"
Since CoreBoot 4.16 my Windows 10 cant boot from SeaBios, i get BSOD with "ACPI Error" very early.
Don't know which commit exactly brakes ACPI, but i can say, that in my CoreBoot 4.15 Image from 11/09/2021 Windows 10 is booting just fine from SeaBIOS.
Some time later under CoreBoot 4.16 i saw that windows is BSODing. Tried yesterday with CoreBoot 4.17 and its still broken.
I think, since CB4.16 there is something broken in ACPI. As i read, the problem is, that ACPI reserves some memory area, which in Windows is reserved for the system.
This [[https://ticket.coreboot.org/issues/327]] seems to be a similar problem, but the guy is using TianoCore instead of SeaBIOS.
Changing the line
OperationRegion (OPRG, SystemMemory, ASLS, 0x2000)
to
OperationRegion (OPRG, SystemMemory, ASLS, 0x1000)
doesnt fix it for SeaBios, but fix it for TianoCore.
Files
Related links
This bug is solved. Thanks for all, who worked on this task.
PR Updated by Pawel Radomychelski over 4 years ago
CoreBoot 4.15
[ 0.172669] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.172734] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.172796] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000cbfff window]
[ 0.172871] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000fffff window]
[ 0.172946] pci_bus 0000:00: root bus resource [mem 0x8ea00000-0xefffffff window]
[ 0.173020] pci_bus 0000:00: root bus resource [mem 0xfed40000-0xfed44fff window]
CoreBoot 4.17
[ 0.172744] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.172809] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.172872] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000cbfff window]
[ 0.172948] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000fffff window]
[ 0.173022] pci_bus 0000:00: root bus resource [mem 0x8ea00000-0xefffffff window]
[ 0.173096] pci_bus 0000:00: root bus resource [mem 0x471600001-0xfffffffff window]
[ 0.173170] pci_bus 0000:00: root bus resource [mem 0xfed40000-0xfed44fff window]
Maybe its the same bug like https://ticket.coreboot.org/issues/327,
but in Bug #327 Windows is starting in UEFI mode via Tianocore, in my bug Windows ist started in legacy mode via SeaBIOS.
Solution which is discussed in Bug #327 doesnt work for SeaBIOS.
- Priority changed from High to Normal
PM Updated by Paul Menzel over 4 years ago
- Subject changed from Coreboot 4.16 & 4.17 - SeaBios Windows 10 BSOD "ACPI Error" to Coreboot 4.16 & 4.17 - SeaBIOS Windows 10 BSOD "ACPI Error"
- Subject changed from Coreboot 4.16 & 4.17 - SeaBIOS Windows 10 BSOD "ACPI Error" to coreboot 4.16 & 4.17 - SeaBIOS Windows 10 BSOD "ACPI Error"
- Please attach a photo of the BSOD, or copy all messages from it.
- Please attach the coreboot log of both images. (If you do not have GNU/Linux installed, you can start it from a USB device with a GNU/Linux live image.
- If you can flash external to potentially recover, please bisect the issue.
AH Updated by Arthur Heymans over 4 years ago
Can you check if https://review.coreboot.org/c/coreboot/+/65250 fixes it?
- File CB4.17_BSOD.jpg CB4.17_BSOD.jpg added
Arthur Heymans wrote in #note-7:
@Arthur: This patch unfortunately doesn't fix it. :(
@Paul:
- Image of BSOD attached. No additional information.
- How can i create coreboot.log of both images?
- I can flash externaly and have also Debian 11 on another drive, so its no problem for me.
Strange that there is no more specific error code.
If your Linux kernel is recent enough (maybe from backports), and has GOOGLE_MEMCONSOLE_COREBOOT selected
$ grep MEMCONSOLE /boot/config-5.18.0-2-amd64
CONFIG_GOOGLE_MEMCONSOLE=m
# CONFIG_GOOGLE_MEMCONSOLE_X86_LEGACY is not set
CONFIG_GOOGLE_MEMCONSOLE_COREBOOT=m
then
Otherwise: In the coreboot source tree, make -C util/cbmem and sudo util/cbmem/cbmem -1.
LZ Updated by Lance Zhao over 4 years ago
If we can get a windows crash dump will be easier to debug the issue, we can use windbg to open generated dump file(memory.dmp most of the time). Then the detail info normally included,
Lance Zhao wrote in #note-10:
I will try to create it, thanks
Paul Menzel wrote in #note-9:
GOOGLE_MEMCONSOLE_COREBOOTselected$ grep MEMCONSOLE /boot/config-5.18.0-2-amd64 CONFIG_GOOGLE_MEMCONSOLE=m # CONFIG_GOOGLE_MEMCONSOLE_X86_LEGACY is not set CONFIG_GOOGLE_MEMCONSOLE_COREBOOT=mthen
make -C util/cbmemandsudo util/cbmem/cbmem -1.
Attached both /sys/firmware/log from CoreBoot 4.15 and 4.17. Thanks
- File 062322-6125-01.dmp added
Added Windows/Minidump *.dmp File.
Will also look how to upload MEMORY.dmp which is 1,4GB large.
Output of minidump shows that's not acpi bios error.
4: kd> !analyze -v
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: ffffdd80db3e1760, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, value 0 = read operation, 1 = write operation
Arg4: fffff8036dea1981, address which referenced memory
Debugging Details:
BUGCHECK_CODE: d1
BUGCHECK_P1: ffffdd80db3e1760
BUGCHECK_P2: 2
BUGCHECK_P3: 0
BUGCHECK_P4: fffff8036dea1981
READ_ADDRESS: Unable to get NonPagedPoolStart
Unable to get NonPagedPoolEnd
Unable to get PagedPoolStart
Unable to get PagedPoolEnd
ffffdd80db3e1760
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: notmyfault64.exe
TRAP_FRAME: fffffe87853e24a0 -- (.trap 0xfffffe87853e24a0)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=0000000000730055 rbx=0000000000000000 rcx=ffffdd80d0000340
rdx=0000000000000890 rsi=0000000000000000 rdi=0000000000000000
rip=fffff8036dea1981 rsp=fffffe87853e2630 rbp=0000000000000002
r8=ffffdd80e25e2da0 r9=0000000000000000 r10=ffffdd80d00002c0
r11=ffffdd80db3c1750 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei ng nz na po nc
myfault+0x1981:
fffff8036dea1981 8b03 mov eax,dword ptr [rbx] ds:0000000000000000=????????
Resetting default scope
STACK_TEXT:
fffffe87853e2358 fffff80370609d69 : 000000000000000a ffffdd80db3e1760 0000000000000002 0000000000000000 : nt!KeBugCheckEx
fffffe87853e2360 fffff80370606069 : 0000000000000000 ffffca09b6b03740 0000000000000f4d 0000000000000000 : nt!KiBugCheckDispatch+0x69
fffffe87853e24a0 fffff8036dea1981 : ffffffffffffffff ffffca09af887080 fffffe87853e2730 0000000000000aa0 : nt!KiPageFault+0x469
fffffe87853e2630 ffffffffffffffff : ffffca09af887080 fffffe87853e2730 0000000000000aa0 0000000000000000 : myfault+0x1981
fffffe87853e2638 ffffca09af887080 : fffffe87853e2730 0000000000000aa0 0000000000000000 fffff8036dea1d3d : 0xffffffffffffffff fffffe87853e2640 fffffe87853e2730 : 0000000000000aa0 0000000000000000 fffff8036dea1d3d ffffdd8000730055 : 0xffffca09af887080
fffffe87853e2648 0000000000000aa0 : 0000000000000000 fffff8036dea1d3d ffffdd8000730055 00000000000f00ff : 0xfffffe87853e2730 fffffe87853e2650 0000000000000000 : fffff8036dea1d3d ffffdd8000730055 00000000000f00ff 00000001`00000000 : 0xaa0
SYMBOL_NAME: myfault+1981
MODULE_NAME: myfault
IMAGE_NAME: myfault.sys
STACK_COMMAND: .cxr; .ecxr ; kb
BUCKET_ID_FUNC_OFFSET: 1981
FAILURE_BUCKET_ID: AV_myfault!unknown_function
OS_VERSION: 10.0.19041.1
BUILDLAB_STR: vb_release
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {9745090a-9bce-ccba-c096-ca6e9ca04c64}
Followup: MachineOwner
To save time, you can install a windbg yourself and run !anlyze -v to get the detailed information. Then use !amli dl or other acpi debug provided by windbg itself.
Sorry @Lance Zhao, but this is the wrong dump. It was created by the app, NotMyFault, which i used to play around with dumps.
It looks so, that the dump we need is not beeing created...
- File deleted (
062322-6125-01.dmp)
I could build Coreboot 4.16 with replacing the folder src/drivers/intel/gma/acpi from Coreboot 4.15.
With replaced acpi folder Windows 10 works without BSOD.
Unfortunately the same trick doesn't work for Coreboot 4.17. With 4.17 and acpi folder from 4.15 Windows 10 crashed very early with ACPI Error BSOD.
crash dump is also not created. Maybe because its crashes very early.
- File deleted (
dmesg_cb416.txt)
- File dmesg_cb416.txt dmesg_cb416.txt added
Paul Menzel wrote in #note-23:
Nice test. Please bisect with
and build and test each commit that is shown. (This only works, if the regression really is in
src/drivers/intel/gma/acpi– otherwise, just usegit bisect start 4.16 4.15.)
Thanks for the info, but i am not very familiar with git commands.
When i am on the 4.16 branch (with default src/drivers/intel/gma/acpi) and i enter the command:
git bisect start 4.16 4.15 -- src/drivers/intel/gma/acpi
warning: refname '4.16' is ambiguous.
Switched to branch '4.16_branch'
Your branch is up to date with 'origin/4.16_branch'.
Bisecting: 3 revisions left to test after this (roughly 2 steps)
[24eb605280b737ee63c72ede451bd5a7d0dce5e2] drivers/intel/gma/acpi: Replace Multiply(a,b) with ASL 2.0 syntax
I have tested all revisions and marked it all as good
I tested also the default 4.16 branch and windows still works.
So i would say, that the "bad" commit is somewhere between 4.16 and 4.17 branch and propably has nothing to do with src/drivers/intel/gma/acpi.
So need to bisect every commit between 4.17 and 4.16? OMG! :)
- Subject changed from coreboot 4.16 & 4.17 - SeaBIOS Windows 10 BSOD "ACPI Error" to coreboot 4.17 - SeaBIOS Windows 10 BSOD "ACPI Error"
- Affected versions deleted (
4.16)
ON Updated by Olexandr Nesterenko over 4 years ago
I use t420 with Ivy Bridge CPU
Run bisect 4.16 - 4.17 and result:
# first bad commit: [f8daf86282c1be33643ace4e9f453e7548cab41c] nb/intel/sandybridge/acpi: Support setting PCI bars above 4G
After this commit i have BSOD ACPI Error.
дуже дякую, Олексанре!
Thank you very much, Oleksandr for bisecting the problem!
hope the fix will be applied to the master branch!
Kind regards
Pawel Radomychelski
On July 24, 2022 at 9:19 AM Olexandr Nesterenko < coreboot@fe80.eu > wrote:
Issue #392 has been updated by Olexandr Nesterenko.
Bug #392: coreboot 4.17 - SeaBIOS Windows 10 BSOD "ACPI Error"
https://ticket.coreboot.org/issues/392#change-1048
- Author: Pawel Radomychelski
- Status: New
- Priority: Normal
- Category: board support
- Target version: 4.17
- Start date: 2022-06-18
- Affected versions: 4.17, master
- Related links: https://ticket.coreboot.org/issues/327
- Affected hardware: Lenovo ThinkPad X230 Tablet
- Affected OS: Windows 10
This [[ https://ticket.coreboot.org/issues/327 ]] seems to be a similar problem, but the guy is using TianoCore instead of SeaBIOS.
Changing the line
to
---Files--------------------------------
dmesg_cb415.txt (78.9 KB)
dmesg_cb417.txt (79.9 KB)
.config (19.7 KB)
CB415.log (46.4 KB)
CB417.log (128 KB)
CB416.log (128 KB)
dmesg_cb416.txt (81.8 KB)
You have received this notification because you have either subscribed to it, or are involved in it.
To change your notification preferences, please click here: https://ticket.coreboot.org/my/account
Do we believe we need to have extra protection to check A4GB is not zero as
well?
Need to see the debug print about A4GB and A4GS at this point.
Lance
Pawel Radomychelski coreboot@fe80.eu 于2022年7月24日周日 17:00写道:
Issue #392 has been updated by Pawel Radomychelski.
Kind regards
Pawel Radomychelski
- Status: New
- Priority: Normal
- Related links:
https://ticket.coreboot.org/issues/327- Affected hardware: Lenovo ThinkPad X230 Tablet
"ACPI Error" very early.Don't know which commit exactly brakes ACPI, but i can say, that in my
SeaBIOS.
yesterday with CoreBoot 4.17 and its still broken.I think, since CB4.16 there is something broken in ACPI. As i read, the
reserved for the system.This [[
SeaBIOS.
Changing the line
to
doesnt fix it for SeaBios, but fix it for TianoCore.---Files--------------------------------
.config (19.7 KB)
CB415.log (46.4 KB)
CB417.log (128 KB)
CB416.log (128 KB)
dmesg_cb416.txt (81.8 KB)--
https://ticket.coreboot.org/issues/392#change-1049
- Status: New
- Priority: Normal
SeaBIOS.
reserved for the system.This [[https://ticket.coreboot.org/issues/327]] seems to be a similar
Changing the line
to
.config (19.7 KB)
CB415.log (46.4 KB)
CB417.log (128 KB)
CB416.log (128 KB)
coreboot mailing list -- coreboot@coreboot.org
To unsubscribe send an email to coreboot-leave@coreboot.org
MR Updated by Martin Roth almost 4 years ago
- Status changed from New to Response Needed
Is this fixed now? There was a revert of the patch that caused the problem, but that was abandoned with a comment saying that another pair of patches fixed the issue. Unfortunately, one of those two patches was also abandoned with no reason given.
Revert: https://review.coreboot.org/c/coreboot/+/65501 (Abandoned)
Fix patch 1: https://review.coreboot.org/c/coreboot/+/66255 (Abandoned)
Fix patch 2: https://review.coreboot.org/c/coreboot/+/66256 (Merged)
Can anyone verify whether this is still an issue or some other patch fixed it?
MB Updated by Michael Büchler almost 4 years ago
I was getting this problem with a port I was working on (Intel DQ67SW, not on Gerrit yet).
Since rebasing this port on 4.18 the issue is gone for me. I tested Windows 10 21H2 with SeaBIOS and EDK II (mrchromebox/uefipayload_202107). The live installer on a USB drive and the installation on a disk are both booting without the ACPI Error.
PR Updated by Pawel Radomychelski almost 4 years ago
- Status changed from Response Needed to Resolved
Martin Roth wrote in #note-29:
Fix patch 2: https://review.coreboot.org/c/coreboot/+/66256 (Merged)Can anyone verify whether this is still an issue or some other patch fixed it?
