Feature #375
closed
AK
DH
Check the right chipset is selected for Intel Emmitsburg PCH
Feature #375:
04/28/2022
Files
E. Updated by Edward . over 4 years ago
- Assignee set to David Hendricks
Hey David, could you take a look into this please?
DH Updated by David Hendricks over 4 years ago
- File ebg_7228ce0_read.txt ebg_7228ce0_read.txt added
Edward . wrote in #note-1:
Yes, the right chipset is selected. I also verified this result on a CRB w/ Emmitsburg just now using the master branch (verbose output attached). 1.3.x will need to cherry-pick 51e1d0e and 106f097 from master, at least.
NH Updated by Nico Huber over 4 years ago
What was mentioned in the review already, compared to Lewisburg:
- The missing FREG registers were added.
- Software sequencing is not allowed anymore (so should we disabled it by default even if we are not locked out?)
Also:
- FLCOMP in the descriptor got an update, e.g. the printed frequencies are off.
I guess it generally got the same update as other newer chipsets.
If nobody cares about the informational output for a given chipset, should we disable it selectively?
FS Updated by Felix Singer almost 4 years ago
- Status changed from New to Response Needed
We are not entirely sure what's left to do here. Is it release blocking?
AK Updated by Anastasia Klimchuk over 3 years ago
- Target version deleted (
1.3) - Parent task deleted (
#353)
AK Updated by Anastasia Klimchuk about 2 years ago
- Status changed from Response Needed to Closed
