Bug #37
closed
AC
x220/native graphics: after some time the display shows only a one color blur image.
Bug #37: x220/native graphics: after some time the display shows only a one color blur image.
Added by Alexander Couzens over 10 years ago. Updated almost 5 years ago.
Closed
03/12/2016
After some time the display goes into a one color blur mode.
Everything but the display continues to work. Changing to another tty doesn't help.
Workaround: suspend/resume
[22770.401257] [drm:intel_set_pch_fifo_underrun_reporting [i915]] *ERROR* uncleared pch fifo underrun on pch transcoder A
Files
config (349 Bytes) config lx r, 03/13/2016 08:57 AM
dmesg_with_resume_with_native_graphics_with_failure (154 KB) dmesg_with_resume_with_native_graphics_with_failure Alexander Couzens, 03/31/2016 11:07 AM
dmesg_with_resume_with_native_graphics_without_failure (126 KB) dmesg_with_resume_with_native_graphics_without_failure Alexander Couzens, 03/31/2016 11:07 AM
dmesg_vgabios (126 KB) dmesg_vgabios Alexander Couzens, 03/31/2016 11:17 AM
LR Updated by lx r over 10 years ago Actions #1
could this a problem of power save features?
LR Updated by lx r over 10 years ago Actions #2
  • Subject changed from x220/native graphics: display shows only a one colore blue image. to x220/native graphics: after some time the display shows only a one color blur image.
AC Updated by Alexander Couzens over 10 years ago Actions #3
There was an old leftover in my cmdline for linux.
removed it. I played a with i915 cmdline options to mitigate some flickering my previous laptop x201. Removing i915.edp_vswing=2 from cmdline now.
AC Updated by Alexander Couzens over 10 years ago Actions #4
  • Status changed from Closed to New
the bug is related to native gfx. it happens much more often with these experimental options.
it also shows up if using radare2 in visual mode and scrolling a little bit.
the pattern triggers than this behaviour.
AC Updated by Alexander Couzens over 10 years ago Actions #7
don't think this is a problem
[    9.232164] [drm:intel_dump_pipe_config] [CRTC:21][setup_hw_state] config ffff8800baa3b800 for pipe A
[   14.948348] [drm:intel_dump_pipe_config] [CRTC:21][setup_hw_state] config ffff88007fca8000 for pipe A
brightness is broken?!
[    9.218958] [drm:intel_panel_setup_backlight] Connector LVDS-1 backlight initialized, enabled, brightness 4437/1552 (nativegfx)
[   14.936242] [drm:intel_panel_setup_backlight] Connector LVDS-1 backlight initialized, enabled, brightness 3000/3000 (vgabios
-they use a different port config:- before re-init by X. later they have the same.
[    9.232180] [drm:intel_dump_pipe_config] port clock: 76000 (nativegfx)
[   14.948377] [drm:intel_dump_pipe_config] port clock: 75000 (VGABIOS)
-and have a different port size- before re-init by X. later they have the same.
pipe src size: 640x480 (nativegfx)
pipe src size: 720x400 (VGABIOS)
only found on vgabios:
[ 14.922811] [drm:parse_general_definitions] crt_ddc_bus_pin: 2
PR Updated by Patrick Rudolph over 10 years ago Actions #8
I've played a little bit with FDI link training on Sandybridge and it looks like it's very similar to the i915 kernel module.
But I discovered that the i915 kernel module expects the GPU to be configured and it doesn't reset all registers to a known state.
I accidentally disabled FDI scrambling and the display output was random, even after the kernel started...
NH Updated by Nico Huber over 9 years ago Actions #9
  • Status changed from New to Response Needed
Does this problem persist with a current kernel? Probably it's worth to give libgfxinit a shot?
FS Updated by Felix Singer almost 5 years ago Actions #10
  • Status changed from Response Needed to Closed
Closed. No response since 5 years.
