Bug #608
openIntel D510 (Pineview) CPU Index 0 - APIC 0 Unexpected Exception:2 @ 08:7f2a67d1 - Halting
I wanted to update this little board to coreboot-25.06-9fe1546ffe but it seems it is broken.
I cleared cmos, switched RAM just in case.
Previous (working) rom was 24.05. I have trouble reflashing with my test clip so I'll desolder later to recover.
Please see log attached. (serial)
Related links
[NOTE ] coreboot-25.06-9fe1546ffe Mon Jul 07 10:54:51 UTC 2025 x86_32 bootblock starting (log level: 7)...
[INFO ] Timestamp - end of bootblock: 32009410
[INFO ] Timestamp - starting to load romstage: 40249380
[DEBUG] FMAP: Found "FLASH" version 1.1 at 0x100000.
[DEBUG] FMAP: base = 0x0 size = 0x1000000 #areas = 3
[DEBUG] FMAP: area COREBOOT found @ 100200 (15728128 bytes)
[INFO ] CBFS: mcache @0xfefc2e00 built for 19 files, used 0x3b4 of 0x4000 bytes
[INFO ] CBFS: Found 'fallback/romstage' @0x80 size 0xd2f0 in mcache @0xfefc2e2c
[INFO ] Timestamp - finished loading romstage: 107933420
[DEBUG] BS: bootblock times (exec / console): total (unknown) / 60 ms
[NOTE ] coreboot-25.06-9fe1546ffe Mon Jul 07 10:54:51 UTC 2025 x86_32 romstage starting (log level: 7)...
[DEBUG] SMBus controller enabled
[DEBUG] Setting up static southbridge registers... done.
[DEBUG] Disabling Watchdog reboot... done.
[DEBUG] Intel Pineview northbridge
[DEBUG] Setting up static northbridge registers... done.
[DEBUG] Initializing memory
[INFO ] Timestamp - before RAM initialization: 203355730
[DEBUG] Boot path: Normal
[DEBUG] 0xfefc1aa0: 80 08 08 0e 0a 61 40 00 05 25 40 00 82 08 00 00 .....a@..%@.....
[DEBUG] 0xfefc1ab0: 0c 08 30 01 02 00 07 3d 50 50 60 32 1e 32 25 01 ..0....=PP`2.2%.
[DEBUG] 0xfefc1ac0: 17 25 05 12 3c 1e 1e 00 06 3c 7f 80 14 1e 00 00 .%..<....<......
[DEBUG] 0xfefc1ad0: 00 03 00 00 00 00 00 00 00 00 00 00 00 00 12 c3 ................
[DEBUG] 0xfefc1be8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
[DEBUG] ...
[DEBUG] Total memory = 2048MB
[DEBUG] GGC = 0x0130
[DEBUG] GBSM (igd) = verified 7f800000 (written 7f800000)
[DEBUG] BGSM (gtt) = verified 7f700000 (written 7f700000)
[DEBUG] TSEG (smm) = verified 7f600000 (written 7f600000)
[DEBUG] RAM initialization finished.
[INFO ] Timestamp - after RAM initialization: 456308720
[DEBUG] Memory initialized
[DEBUG] CBMEM:
[DEBUG] IMD: root @ 0x7f3ff000 254 entries.
[DEBUG] IMD: root @ 0x7f3fec00 62 entries.
[DEBUG] External stage cache:
[DEBUG] IMD: root @ 0x7f6ff000 254 entries.
[DEBUG] IMD: root @ 0x7f6fec00 62 entries.
[DEBUG] SMM Memory Map
[DEBUG] SMRAM : 0x7f600000 0x100000
[DEBUG] Subregion 0: 0x7f600000 0x80000
[DEBUG] Subregion 1: 0x7f680000 0x80000
[DEBUG] Subregion 2: 0x7f700000 0x0
[DEBUG] Normal boot
[INFO ] CBFS: Found 'fallback/postcar' @0x2d740 size 0x89e8 in mcache @0xfefc3034
[DEBUG] Loading module at 0x7f3cd000 with entry 0x7f3cd031. filesize: 0x8148 memsize: 0xe498
[DEBUG] Processing 536 relocs. Offset value of 0x7d3cd000
[INFO ] Timestamp - end of romstage: 626016100
[DEBUG] BS: romstage times (exec / console): total (unknown) / 198 ms
[NOTE ] coreboot-25.06-9fe1546ffe Mon Jul 07 10:54:51 UTC 2025 x86_32 postcar starting (log level: 7)...
[INFO ] Timestamp - start of postcar: 665484600
[INFO ] Timestamp - end of postcar: 673831930
[DEBUG] Normal boot
[INFO ] Timestamp - starting to load ramstage: 686222860
[INFO ] CBFS: Found 'fallback/ramstage' @0xd400 size 0x15812 in mcache @0x7f3dd08c
[INFO ] Timestamp - starting LZMA decompress (ignore for x86): 709278150
[INFO ] Timestamp - finished LZMA decompress (ignore for x86): 828909740
[DEBUG] Loading module at 0x7f294000 with entry 0x7f294000. filesize: 0x2b178 memsize: 0x137c30
[DEBUG] Processing 3232 relocs. Offset value of 0x7b294000
[INFO ] Timestamp - finished loading ramstage: 866463700
[DEBUG] BS: postcar times (exec / console): total (unknown) / 71 ms
[NOTE ] coreboot-25.06-9fe1546ffe Mon Jul 07 10:54:51 UTC 2025 x86_32 ramstage starting (log level: 7)...
[INFO ] Timestamp - start of ramstage: 906512580
[DEBUG] Normal boot
[INFO ] Timestamp - early chipset initialization: 919331960
[DEBUG] BS: BS_DEV_INIT_CHIPS run times (exec / console): 0 / 6 ms
[INFO ] Timestamp - device enumeration: 940505000
[INFO ] Enumerating buses...
[DEBUG] Root Device scanning...
[DEBUG] CPU_CLUSTER: 0 enabled
[DEBUG] DOMAIN: 00000000 enabled
[DEBUG] DOMAIN: 00000000 scanning...
[DEBUG] PCI: pci_scan_bus for segment group 00 bus 00
[DEBUG] PCI: 00:00:00.0 [8086/a000] enabled
[DEBUG] PCI: 00:00:02.0 [8086/a001] enabled
[DEBUG] PCI: 00:00:02.1 [8086/a002] enabled
[DEBUG] PCI: 00:00:1b.0 [8086/27d8] enabled
[DEBUG] PCI: 00:00:1c.0 [8086/27d0] enabled
[DEBUG] PCI: 00:00:1c.1 [8086/27d2] enabled
[DEBUG] PCI: 00:00:1c.2 [8086/27d4] enabled
[DEBUG] PCI: 00:00:1c.3 [8086/27d6] enabled
[DEBUG] PCI: 00:00:1d.0 [8086/27c8] enabled
[DEBUG] PCI: 00:00:1d.1 [8086/27c9] enabled
[DEBUG] PCI: 00:00:1d.2 [8086/27ca] enabled
[DEBUG] PCI: 00:00:1d.3 [8086/27cb] enabled
[DEBUG] PCI: 00:00:1d.7 [8086/27cc] enabled
[DEBUG] PCI: 00:00:1e.0 [8086/2448] enabled
[DEBUG] PCI: 00:00:1f.0 [8086/27bc] enabled
[DEBUG] PCI: 00:00:1f.1: Disabling device
[DEBUG] Set SATA mode early
[DEBUG] PCI: 00:00:1f.2 [8086/27c1] enabled
[DEBUG] PCI: 00:00:1f.3 [8086/27da] enabled
[DEBUG] PCI: 00:00:1f.4: Disabling device
[DEBUG] PCI: 00:00:1f.5: Disabling device
[DEBUG] PCI: 00:00:1f.6: Disabling device
[WARN ] PCI: Leftover static devices:
[WARN ] PCI: 00:00:1f.1
[WARN ] PCI: 00:00:1f.4
[WARN ] PCI: 00:00:1f.5
[WARN ] PCI: 00:00:1f.6
[WARN ] PCI: Check your devicetree.cb.
[DEBUG] PCI: 00:00:1c.0 scanning...
[DEBUG] PCI: pci_scan_bus for segment group 00 bus 01
[DEBUG] PCI: 00:01:00.0 [10ec/8168] enabled
[DEBUG] scan_bus: bus PCI: 00:00:1c.0 finished in 10 msecs
[DEBUG] PCI: 00:00:1c.1 scanning...
[DEBUG] PCI: pci_scan_bus for segment group 00 bus 02
[DEBUG] scan_bus: bus PCI: 00:00:1c.1 finished in 5 msecs
[DEBUG] PCI: 00:00:1c.2 scanning...
[DEBUG] PCI: pci_scan_bus for segment group 00 bus 03
[DEBUG] scan_bus: bus PCI: 00:00:1c.2 finished in 5 msecs
[DEBUG] PCI: 00:00:1c.3 scanning...
[DEBUG] PCI: pci_scan_bus for segment group 00 bus 04
[DEBUG] scan_bus: bus PCI: 00:00:1c.3 finished in 5 msecs
[DEBUG] PCI: 00:00:1e.0 scanning...
[DEBUG] PCI: pci_scan_bus for segment group 00 bus 05
[DEBUG] scan_bus: bus PCI: 00:00:1e.0 finished in 5 msecs
[DEBUG] PCI: 00:00:1f.0 scanning...
[DEBUG] PNP: 004e.0 disabled
[DEBUG] PNP: 004e.1 enabled
[DEBUG] PNP: 004e.2 enabled
[DEBUG] PNP: 004e.3 enabled
[DEBUG] PNP: 004e.5 enabled
[DEBUG] PNP: 004e.6 disabled
[DEBUG] PNP: 004e.7 disabled
[DEBUG] PNP: 004e.8 disabled
[DEBUG] PNP: 004e.9 disabled
[DEBUG] PNP: 004e.a disabled
[DEBUG] PNP: 004e.b enabled
[DEBUG] scan_bus: bus PCI: 00:00:1f.0 finished in 35 msecs
[DEBUG] PCI: 00:00:1f.3 scanning...
[DEBUG] I2C: 01:69 enabled
[DEBUG] bus: PCI: 00:00:1f.3->scan_bus: bus PCI: 00:00:1f.3 finished in 6 msecs
[DEBUG] scan_bus: bus DOMAIN: 00000000 finished in 268 msecs
[DEBUG] scan_bus: bus Root Device finished in 285 msecs
[INFO ] done
[DEBUG] BS: BS_DEV_ENUMERATE run times (exec / console): 0 / 305 ms
[INFO ] Timestamp - device configuration: 1470442510
[DEBUG] found VGA at PCI: 00:00:02.0
[DEBUG] Setting up VGA for PCI: 00:00:02.0
[DEBUG] Setting PCI_BRIDGE_CTL_VGA for bridge DOMAIN: 00000000
[DEBUG] Setting PCI_BRIDGE_CTL_VGA for bridge Root Device
[INFO ] Allocating resources...
[INFO ] Reading resources...
[DEBUG] TOUUD 0x80000000 TOLUD 0x80000000 TOM 0x100000000 8M UMA and 1M GTT
[DEBUG] Unused RAM between cbmem_top and TOM: 0x200000
[DEBUG] Adding PCIe enhanced config space BAR 0xe0000000-0xf0000000.
[INFO ] Done reading resources.
[INFO ] === Resource allocator: DOMAIN: 00000000 - Pass 1 (relative placement) ===
[DEBUG] PCI: 00:00:1c.0 io: size: 0 align: 12 gran: 12 limit: ffff
[DEBUG] PCI: 00:01:00.0 10 * [0x0 - 0xff] io
[DEBUG] PCI: 00:00:1c.0 io: size: 1000 align: 12 gran: 12 limit: ffff done
[DEBUG] PCI: 00:00:1c.0 mem: size: 0 align: 20 gran: 20 limit: ffffffff
[DEBUG] PCI: 00:01:00.0 30 * [0x0 - 0x1ffff] mem
[DEBUG] PCI: 00:00:1c.0 mem: size: 100000 align: 20 gran: 20 limit: ffffffff done
[DEBUG] PCI: 00:00:1c.0 prefmem: size: 0 align: 20 gran: 20 limit: ffffffffffffffff
[DEBUG] PCI: 00:01:00.0 20 * [0x0 - 0x3fff] prefmem
[DEBUG] PCI: 00:01:00.0 18 * [0x4000 - 0x4fff] prefmem
[DEBUG] PCI: 00:00:1c.0 prefmem: size: 100000 align: 20 gran: 20 limit: ffffffff done
[INFO ] === Resource allocator: DOMAIN: 00000000 - Pass 2 (allocating resources) ===
[DEBUG] DOMAIN: 00000000 io: base: 0 size: 0 align: 0 gran: 0 limit: ffff
[DEBUG] avoid_fixed_resources: PCI: 00:00:1f.0 10000000 base 00000000 limit 00000fff io (fixed)
[DEBUG] avoid_fixed_resources: PNP: 004e.1 60 base 00000378 limit 0000037f io (fixed)
[DEBUG] avoid_fixed_resources: PNP: 004e.2 60 base 000003f8 limit 000003ff io (fixed)
[DEBUG] avoid_fixed_resources: PNP: 004e.3 60 base 000002f8 limit 000002ff io (fixed)
[DEBUG] avoid_fixed_resources: PNP: 004e.5 60 base 00000060 limit 00000060 io (fixed)
[DEBUG] avoid_fixed_resources: PNP: 004e.5 62 base 00000064 limit 00000064 io (fixed)
[DEBUG] avoid_fixed_resources: PNP: 004e.b 60 base 00000290 limit 00000297 io (fixed)
[DEBUG] avoid_fixed_resources: PCI: 00:00:1f.3 20 base 00000400 limit 0000041f io (fixed)
[INFO ] DOMAIN: 00000000: Resource ranges:
[INFO ] * Base: 1000, Size: f000, Tag: 100
[DEBUG] PCI: 00:00:1c.0 1c * [0xf000 - 0xffff] limit: ffff io
[DEBUG] PCI: 00:00:1d.0 20 * [0xefe0 - 0xefff] limit: efff io
[DEBUG] PCI: 00:00:1d.1 20 * [0xefc0 - 0xefdf] limit: efdf io
[DEBUG] PCI: 00:00:1d.2 20 * [0xefa0 - 0xefbf] limit: efbf io
[DEBUG] PCI: 00:00:1d.3 20 * [0xef80 - 0xef9f] limit: ef9f io
[DEBUG] PCI: 00:00:1f.2 20 * [0xef60 - 0xef7f] limit: ef7f io
[DEBUG] PCI: 00:00:02.0 14 * [0xef58 - 0xef5f] limit: ef5f io
[DEBUG] PCI: 00:00:1f.2 10 * [0xef50 - 0xef57] limit: ef57 io
[DEBUG] PCI: 00:00:1f.2 18 * [0xef48 - 0xef4f] limit: ef4f io
[DEBUG] PCI: 00:00:1f.2 14 * [0xef44 - 0xef47] limit: ef47 io
[DEBUG] PCI: 00:00:1f.2 1c * [0xef40 - 0xef43] limit: ef43 io
[DEBUG] DOMAIN: 00000000 io: base: 0 size: 0 align: 0 gran: 0 limit: ffff done
[DEBUG] DOMAIN: 00000000 mem: base: 7f400000 size: 0 align: 0 gran: 0 limit: febfffff
[DEBUG] DOMAIN: 00000000 mem: base: 100000000 size: 0 align: 0 gran: 0 limit: fffffffff
[DEBUG] avoid_fixed_resources: DOMAIN: 00000000 03 base 00000000 limit 0009ffff mem (fixed)
[DEBUG] avoid_fixed_resources: DOMAIN: 00000000 04 base 00100000 limit 7f3fffff mem (fixed)
[DEBUG] avoid_fixed_resources: DOMAIN: 00000000 05 base 7f600000 limit 7f6fffff mem (fixed)
[DEBUG] avoid_fixed_resources: DOMAIN: 00000000 06 base 7f700000 limit 7f7fffff mem (fixed)
[DEBUG] avoid_fixed_resources: DOMAIN: 00000000 07 base 7f800000 limit 7fffffff mem (fixed)
[DEBUG] avoid_fixed_resources: DOMAIN: 00000000 08 base 7f400000 limit 7f5fffff mem (fixed)
[DEBUG] avoid_fixed_resources: DOMAIN: 00000000 0a base e0000000 limit efffffff mem (fixed)
[DEBUG] avoid_fixed_resources: DOMAIN: 00000000 0b base fed00000 limit fedfffff mem (fixed)
[DEBUG] avoid_fixed_resources: DOMAIN: 00000000 0c base 000a0000 limit 000bffff mem (fixed)
[DEBUG] avoid_fixed_resources: DOMAIN: 00000000 0d base 000c0000 limit 000fffff mem (fixed)
[DEBUG] avoid_fixed_resources: PCI: 00:00:1f.0 10000100 base ff800000 limit ffffffff mem (fixed)
[DEBUG] avoid_fixed_resources: PCI: 00:00:1f.0 03 base fec00000 limit fec00fff mem (fixed)
[INFO ] * Base: 80000000, Size: 60000000, Tag: 200
[INFO ] * Base: f0000000, Size: ec00000, Tag: 200
[INFO ] * Base: 100000000, Size: f00000000, Tag: 200
[DEBUG] PCI: 00:00:02.0 18 * [0xd0000000 - 0xdfffffff] limit: dfffffff prefmem
[DEBUG] PCI: 00:00:02.0 1c * [0xfeb00000 - 0xfebfffff] limit: febfffff mem
[DEBUG] PCI: 00:00:1c.0 24 * [0xfea00000 - 0xfeafffff] limit: feafffff prefmem
[DEBUG] PCI: 00:00:1c.0 20 * [0xfe900000 - 0xfe9fffff] limit: fe9fffff mem
[DEBUG] PCI: 00:00:02.0 10 * [0xfe880000 - 0xfe8fffff] limit: fe8fffff mem
[DEBUG] PCI: 00:00:02.1 10 * [0xfe800000 - 0xfe87ffff] limit: fe87ffff mem
[DEBUG] PCI: 00:00:1b.0 10 * [0xfe7fc000 - 0xfe7fffff] limit: fe7fffff mem
[DEBUG] PCI: 00:00:1d.7 10 * [0xfe7fb000 - 0xfe7fb3ff] limit: fe7fb3ff mem
[DEBUG] PCI: 00:00:1f.2 24 * [0xfe7fa000 - 0xfe7fa3ff] limit: fe7fa3ff mem
[DEBUG] DOMAIN: 00000000 mem: base: 7f400000 size: 0 align: 0 gran: 0 limit: febfffff done
[DEBUG] DOMAIN: 00000000 mem: base: 100000000 size: 0 align: 0 gran: 0 limit: fffffffff done
[DEBUG] PCI: 00:01:00.0 10 * [0xf000 - 0xf0ff] limit: f0ff io
[DEBUG] PCI: 00:01:00.0 18 * [0xfea04000 - 0xfea04fff] limit: fea04fff prefmem
[DEBUG] PCI: 00:01:00.0 20 * [0xfea00000 - 0xfea03fff] limit: fea03fff prefmem
[DEBUG] PCI: 00:01:00.0 30 * [0xfe900000 - 0xfe91ffff] limit: fe91ffff mem
[INFO ] === Resource allocator: DOMAIN: 00000000 - resource allocation complete ===
[DEBUG] DOMAIN: 00000000 03 <- [0x0000000000000000 - 0x000000000009ffff] size 0x000a0000 gran 0x00 mem
[DEBUG] DOMAIN: 00000000 04 <- [0x0000000000100000 - 0x000000007f3fffff] size 0x7f300000 gran 0x00 mem
[DEBUG] DOMAIN: 00000000 05 <- [0x000000007f600000 - 0x000000007f6fffff] size 0x00100000 gran 0x00 mem
[DEBUG] DOMAIN: 00000000 06 <- [0x000000007f700000 - 0x000000007f7fffff] size 0x00100000 gran 0x00 mem
[DEBUG] DOMAIN: 00000000 07 <- [0x000000007f800000 - 0x000000007fffffff] size 0x00800000 gran 0x00 mem
[DEBUG] DOMAIN: 00000000 08 <- [0x000000007f400000 - 0x000000007f5fffff] size 0x00200000 gran 0x00 mem
[DEBUG] DOMAIN: 00000000 0a <- [0x00000000e0000000 - 0x00000000efffffff] size 0x10000000 gran 0x00 mem
[DEBUG] DOMAIN: 00000000 0b <- [0x00000000fed00000 - 0x00000000fedfffff] size 0x00100000 gran 0x00 mem
[DEBUG] DOMAIN: 00000000 0c <- [0x00000000000a0000 - 0x00000000000bffff] size 0x00020000 gran 0x00 mem
[DEBUG] DOMAIN: 00000000 0d <- [0x00000000000c0000 - 0x00000000000fffff] size 0x00040000 gran 0x00 mem
[DEBUG] PCI: 00:00:02.0 10 <- [0x00000000fe880000 - 0x00000000fe8fffff] size 0x00080000 gran 0x13 mem
[DEBUG] PCI: 00:00:02.0 14 <- [0x000000000000ef58 - 0x000000000000ef5f] size 0x00000008 gran 0x03 io
[DEBUG] PCI: 00:00:02.0 18 <- [0x00000000d0000000 - 0x00000000dfffffff] size 0x10000000 gran 0x1c prefmem
[DEBUG] PCI: 00:00:02.0 1c <- [0x00000000feb00000 - 0x00000000febfffff] size 0x00100000 gran 0x14 mem
[DEBUG] PCI: 00:00:02.1 10 <- [0x00000000fe800000 - 0x00000000fe87ffff] size 0x00080000 gran 0x13 mem
[DEBUG] PCI: 00:00:1b.0 10 <- [0x00000000fe7fc000 - 0x00000000fe7fffff] size 0x00004000 gran 0x0e mem64
[DEBUG] PCI: 00:00:1c.0 1c <- [0x000000000000f000 - 0x000000000000ffff] size 0x00001000 gran 0x0c seg 00 bus 01 io
[DEBUG] PCI: 00:00:1c.0 24 <- [0x00000000fea00000 - 0x00000000feafffff] size 0x00100000 gran 0x14 seg 00 bus 01 prefmem
[DEBUG] PCI: 00:00:1c.0 20 <- [0x00000000fe900000 - 0x00000000fe9fffff] size 0x00100000 gran 0x14 seg 00 bus 01 mem
[DEBUG] PCI: 00:01:00.0 10 <- [0x000000000000f000 - 0x000000000000f0ff] size 0x00000100 gran 0x08 io
[DEBUG] PCI: 00:01:00.0 18 <- [0x00000000fea04000 - 0x00000000fea04fff] size 0x00001000 gran 0x0c prefmem64
[DEBUG] PCI: 00:01:00.0 20 <- [0x00000000fea00000 - 0x00000000fea03fff] size 0x00004000 gran 0x0e prefmem64
[DEBUG] PCI: 00:01:00.0 30 <- [0x00000000fe900000 - 0x00000000fe91ffff] size 0x00020000 gran 0x11 romem
[DEBUG] PCI: 00:00:1c.1 1c <- [0x000000000000ffff - 0x000000000000fffe] size 0x00000000 gran 0x0c seg 00 bus 02 io
[DEBUG] PCI: 00:00:1c.1 24 <- [0xffffffffffffffff - 0xfffffffffffffffe] size 0x00000000 gran 0x14 seg 00 bus 02 prefmem
[DEBUG] PCI: 00:00:1c.1 20 <- [0x00000000ffffffff - 0x00000000fffffffe] size 0x00000000 gran 0x14 seg 00 bus 02 mem
[DEBUG] PCI: 00:00:1c.2 1c <- [0x000000000000ffff - 0x000000000000fffe] size 0x00000000 gran 0x0c seg 00 bus 03 io
[DEBUG] PCI: 00:00:1c.2 24 <- [0xffffffffffffffff - 0xfffffffffffffffe] size 0x00000000 gran 0x14 seg 00 bus 03 prefmem
[DEBUG] PCI: 00:00:1c.2 20 <- [0x00000000ffffffff - 0x00000000fffffffe] size 0x00000000 gran 0x14 seg 00 bus 03 mem
[DEBUG] PCI: 00:00:1c.3 1c <- [0x000000000000ffff - 0x000000000000fffe] size 0x00000000 gran 0x0c seg 00 bus 04 io
[DEBUG] PCI: 00:00:1c.3 24 <- [0xffffffffffffffff - 0xfffffffffffffffe] size 0x00000000 gran 0x14 seg 00 bus 04 prefmem
[DEBUG] PCI: 00:00:1c.3 20 <- [0x00000000ffffffff - 0x00000000fffffffe] size 0x00000000 gran 0x14 seg 00 bus 04 mem
[DEBUG] PCI: 00:00:1d.0 20 <- [0x000000000000efe0 - 0x000000000000efff] size 0x00000020 gran 0x05 io
[DEBUG] PCI: 00:00:1d.1 20 <- [0x000000000000efc0 - 0x000000000000efdf] size 0x00000020 gran 0x05 io
[DEBUG] PCI: 00:00:1d.2 20 <- [0x000000000000efa0 - 0x000000000000efbf] size 0x00000020 gran 0x05 io
[DEBUG] PCI: 00:00:1d.3 20 <- [0x000000000000ef80 - 0x000000000000ef9f] size 0x00000020 gran 0x05 io
[DEBUG] PCI: 00:00:1d.7 10 <- [0x00000000fe7fb000 - 0x00000000fe7fb3ff] size 0x00000400 gran 0x0a mem
[DEBUG] PCI: 00:00:1e.0 1c <- [0x000000000000ffff - 0x000000000000fffe] size 0x00000000 gran 0x0c seg 00 bus 05 io
[DEBUG] PCI: 00:00:1e.0 24 <- [0xffffffffffffffff - 0xfffffffffffffffe] size 0x00000000 gran 0x14 seg 00 bus 05 prefmem
[DEBUG] PCI: 00:00:1e.0 20 <- [0x00000000ffffffff - 0x00000000fffffffe] size 0x00000000 gran 0x14 seg 00 bus 05 mem
[DEBUG] PNP: 004e.1 60 <- [0x0000000000000378 - 0x000000000000037f] size 0x00000008 gran 0x03 io
[DEBUG] PNP: 004e.1 70 <- [0x0000000000000007 - 0x0000000000000007] size 0x00000001 gran 0x00 irq
[DEBUG] PNP: 004e.1 74 <- [0x0000000000000004 - 0x0000000000000004] size 0x00000001 gran 0x00 drq
[DEBUG] PNP: 004e.2 60 <- [0x00000000000003f8 - 0x00000000000003ff] size 0x00000008 gran 0x03 io
[DEBUG] PNP: 004e.2 70 <- [0x0000000000000004 - 0x0000000000000004] size 0x00000001 gran 0x00 irq
[DEBUG] PNP: 004e.3 60 <- [0x00000000000002f8 - 0x00000000000002ff] size 0x00000008 gran 0x03 io
[DEBUG] PNP: 004e.3 70 <- [0x0000000000000003 - 0x0000000000000003] size 0x00000001 gran 0x00 irq
[DEBUG] PNP: 004e.3 f1 <- [0x0000000000000000 - 0x0000000000000000] size 0x00000001 gran 0x00 irq
[DEBUG] PNP: 004e.5 60 <- [0x0000000000000060 - 0x0000000000000060] size 0x00000001 gran 0x00 io
[DEBUG] PNP: 004e.5 62 <- [0x0000000000000064 - 0x0000000000000064] size 0x00000001 gran 0x00 io
[DEBUG] PNP: 004e.5 70 <- [0x0000000000000001 - 0x0000000000000001] size 0x00000001 gran 0x00 irq
[DEBUG] PNP: 004e.5 72 <- [0x000000000000000c - 0x000000000000000c] size 0x00000001 gran 0x00 irq
[DEBUG] PNP: 004e.5 f0 <- [0x0000000000000080 - 0x0000000000000080] size 0x00000001 gran 0x00 irq
[DEBUG] PNP: 004e.b 60 <- [0x0000000000000290 - 0x0000000000000297] size 0x00000008 gran 0x03 io
[DEBUG] PNP: 004e.b 70 <- [0x0000000000000000 - 0x0000000000000000] size 0x00000001 gran 0x00 irq
[DEBUG] PCI: 00:00:1f.2 10 <- [0x000000000000ef50 - 0x000000000000ef57] size 0x00000008 gran 0x03 io
[DEBUG] PCI: 00:00:1f.2 14 <- [0x000000000000ef44 - 0x000000000000ef47] size 0x00000004 gran 0x02 io
[DEBUG] PCI: 00:00:1f.2 18 <- [0x000000000000ef48 - 0x000000000000ef4f] size 0x00000008 gran 0x03 io
[DEBUG] PCI: 00:00:1f.2 1c <- [0x000000000000ef40 - 0x000000000000ef43] size 0x00000004 gran 0x02 io
[DEBUG] PCI: 00:00:1f.2 20 <- [0x000000000000ef60 - 0x000000000000ef7f] size 0x00000020 gran 0x05 io
[DEBUG] PCI: 00:00:1f.2 24 <- [0x00000000fe7fa000 - 0x00000000fe7fa3ff] size 0x00000400 gran 0x0a mem
[INFO ] Done setting resources.
[INFO ] Done allocating resources.
[DEBUG] BS: BS_DEV_RESOURCES run times (exec / console): 1 / 1164 ms
[INFO ] Timestamp - device enable: 3463231870
[INFO ] Enabling resources...
[DEBUG] PCI: 00:00:00.0 subsystem <- 8086/a000
[DEBUG] PCI: 00:00:00.0 cmd <- 06
[DEBUG] PCI: 00:00:02.0 subsystem <- 8086/a001
[DEBUG] PCI: 00:00:02.0 cmd <- 03
[DEBUG] PCI: 00:00:02.1 subsystem <- 8086/a002
[DEBUG] PCI: 00:00:02.1 cmd <- 02
[DEBUG] PCI: 00:00:1b.0 subsystem <- 8086/27d8
[DEBUG] PCI: 00:00:1b.0 cmd <- 102
[DEBUG] PCI: 00:00:1c.0 bridge ctrl <- 0013
[DEBUG] PCI: 00:00:1c.0 subsystem <- 8086/27d0
[DEBUG] PCI: 00:00:1c.0 cmd <- 107
[DEBUG] PCI: 00:00:1c.1 bridge ctrl <- 0013
[DEBUG] PCI: 00:00:1c.1 subsystem <- 8086/27d2
[DEBUG] PCI: 00:00:1c.1 cmd <- 100
[DEBUG] PCI: 00:00:1c.2 bridge ctrl <- 0013
[DEBUG] PCI: 00:00:1c.2 subsystem <- 8086/27d4
[DEBUG] PCI: 00:00:1c.2 cmd <- 100
[DEBUG] PCI: 00:00:1c.3 bridge ctrl <- 0013
[DEBUG] PCI: 00:00:1c.3 subsystem <- 8086/27d6
[DEBUG] PCI: 00:00:1c.3 cmd <- 100
[DEBUG] PCI: 00:00:1d.0 subsystem <- 8086/27c8
[DEBUG] PCI: 00:00:1d.0 cmd <- 01
[DEBUG] PCI: 00:00:1d.1 subsystem <- 8086/27c9
[DEBUG] PCI: 00:00:1d.1 cmd <- 01
[DEBUG] PCI: 00:00:1d.2 subsystem <- 8086/27ca
[DEBUG] PCI: 00:00:1d.2 cmd <- 01
[DEBUG] PCI: 00:00:1d.3 subsystem <- 8086/27cb
[DEBUG] PCI: 00:00:1d.3 cmd <- 01
[DEBUG] PCI: 00:00:1d.7 subsystem <- 8086/27cc
[DEBUG] PCI: 00:00:1d.7 cmd <- 102
[DEBUG] PCI: 00:00:1e.0 bridge ctrl <- 0013
[DEBUG] PCI: 00:00:1e.0 subsystem <- 8086/2448
[DEBUG] PCI: 00:00:1e.0 cmd <- 100
[DEBUG] PCI: 00:00:1f.0 subsystem <- 8086/27bc
[DEBUG] PCI: 00:00:1f.0 cmd <- 107
[DEBUG] PCI: 00:00:1f.2 subsystem <- 8086/27c1
[DEBUG] PCI: 00:00:1f.2 cmd <- 03
[DEBUG] PCI: 00:00:1f.3 subsystem <- 8086/27da
[DEBUG] PCI: 00:00:1f.3 cmd <- 101
[DEBUG] PCI: 00:01:00.0 subsystem <- 10ec/8168
[DEBUG] PCI: 00:01:00.0 cmd <- 103
[INFO ] done.
[DEBUG] BS: BS_DEV_ENABLE run times (exec / console): 0 / 188 ms
[INFO ] Timestamp - device initialization: 3793644650
[INFO ] Initializing devices...
[DEBUG] CPU_CLUSTER: 0 init
[DEBUG] microcode: sig=0x106ca pf=0x8 revision=0x0
[WARN ] CBFS: 'cpu_microcode_blob.bin' not found.
[WARN ] microcode: failed because no ucode was found
[INFO ] LAPIC 0x0 in XAPIC mode.
[DEBUG] MTRR: Physical address space:
[DEBUG] 0x0000000000000000 - 0x000000000009ffff size 0x000a0000 type 6
[DEBUG] 0x00000000000a0000 - 0x00000000000bffff size 0x00020000 type 0
[DEBUG] 0x00000000000c0000 - 0x000000007f5fffff size 0x7f540000 type 6
[DEBUG] 0x000000007f600000 - 0x00000000cfffffff size 0x50a00000 type 0
[DEBUG] 0x00000000d0000000 - 0x00000000dfffffff size 0x10000000 type 1
[DEBUG] 0x00000000e0000000 - 0x00000000ffffffff size 0x20000000 type 0
[DEBUG] apic_id 0x0: MTRR: Fixed MSR 0x250 0x0606060606060606
[DEBUG] apic_id 0x0: MTRR: Fixed MSR 0x258 0x0606060606060606
[DEBUG] apic_id 0x0: MTRR: Fixed MSR 0x259 0x0000000000000000
[DEBUG] apic_id 0x0: MTRR: Fixed MSR 0x268 0x0606060606060606
[DEBUG] apic_id 0x0: MTRR: Fixed MSR 0x269 0x0606060606060606
[DEBUG] apic_id 0x0: MTRR: Fixed MSR 0x26a 0x0606060606060606
[DEBUG] apic_id 0x0: MTRR: Fixed MSR 0x26b 0x0606060606060606
[DEBUG] apic_id 0x0: MTRR: Fixed MSR 0x26c 0x0606060606060606
[DEBUG] apic_id 0x0: MTRR: Fixed MSR 0x26d 0x0606060606060606
[DEBUG] apic_id 0x0: MTRR: Fixed MSR 0x26e 0x0606060606060606
[DEBUG] apic_id 0x0: MTRR: Fixed MSR 0x26f 0x0606060606060606
[DEBUG] apic_id 0x0 setup mtrr for CPU physical address size: 36 bits
[DEBUG] MTRR: default type WB/UC MTRR counts: 6/4.
[DEBUG] MTRR: UC selected as default type.
[DEBUG] MTRR: 0 base 0x0000000000000000 mask 0x0000000f80000000 type 6
[DEBUG] MTRR: 1 base 0x000000007f600000 mask 0x0000000fffe00000 type 0
[DEBUG] MTRR: 2 base 0x000000007f800000 mask 0x0000000fff800000 type 0
[DEBUG] MTRR: 3 base 0x00000000d0000000 mask 0x0000000ff0000000 type 1
[DEBUG] MTRR check
[DEBUG] Fixed MTRRs : Enabled
[DEBUG] Variable MTRRs: Enabled
[DEBUG] CPU has 4 cores.
[DEBUG] Setting up SMI for CPU
[INFO ] Will perform SMM setup.
[INFO ] CPU: Intel(R) Atom(TM) CPU K510 @ 1.66GHz.
[DEBUG] CPU: APIC: 00 enabled
[DEBUG] CPU: APIC: 01 enabled
[DEBUG] CPU: APIC: 02 enabled
[DEBUG] CPU: APIC: 03 enabled
[DEBUG] Loading module at 0x00030000 with entry 0x00030000. filesize: 0x178 memsize: 0x178
[DEBUG] Processing 16 relocs. Offset value of 0x00030000
[DEBUG] Attempting to start 3 APs
[DEBUG] Waiting for 10ms after sending INIT.
[DEBUG] Waiting for SIPI to complete...
[INFO ] LAPIC 0x1 in XAPIC mode.
[DEBUG] done.
[INFO ] AP: slot 3 apic_id 1, MCU rev: 0x00000000
[DEBUG] done.
[INFO ] LAPIC 0x2 in XAPIC mode.
[INFO ] LAPIC 0x3 in XAPIC mode.
[INFO ] AP: slot 1 apic_id 2, MCU rev: 0x00000000
[INFO ] AP: slot 2 apic_id 3, MCU rev: 0x00000000
[DEBUG] Loading module at 0x00038000 with entry 0x00038000. filesize: 0x1d8 memsize: 0x1d8
[DEBUG] Processing 9 relocs. Offset value of 0x00038000
[DEBUG] smm_module_setup_stub: stack_top = 0x7f601000
[DEBUG] smm_module_setup_stub: per cpu stack_size = 0x400
[DEBUG] smm_module_setup_stub: runtime.smm_size = 0x10000
[DEBUG] SMM Module: stub loaded at 38000. Will call 0x7f2a84bb
[DEBUG] Installing permanent SMM handler to 0x7f600000
[DEBUG] HANDLER [0x7f67e000-0x7f67f18f]
[DEBUG] CPU 0
[DEBUG] ss0 [0x7f67dc00-0x7f67dfff]
[DEBUG] stub0 [0x7f676000-0x7f6761d7]
[DEBUG] CPU 1
[DEBUG] ss1 [0x7f67d800-0x7f67dbff]
[DEBUG] stub1 [0x7f675c00-0x7f675dd7]
[DEBUG] CPU 2
[DEBUG] ss2 [0x7f67d400-0x7f67d7ff]
[DEBUG] stub2 [0x7f675800-0x7f6759d7]
[DEBUG] CPU 3
[DEBUG] ss3 [0x7f67d000-0x7f67d3ff]
[DEBUG] stub3 [0x7f675400-0x7f6755d7]
[DEBUG] stacks [0x7f600000-0x7f600fff]
[DEBUG] Loading module at 0x7f67e000 with entry 0x7f67e54b. filesize: 0x1140 memsize: 0x1190
[DEBUG] Processing 49 relocs. Offset value of 0x7f67e000
[DEBUG] Loading module at 0x7f676000 with entry 0x7f676000. filesize: 0x1d8 memsize: 0x1d8
[DEBUG] Processing 9 relocs. Offset value of 0x7f676000
[DEBUG] smm_module_setup_stub: runtime.smm_size = 0x80000
[DEBUG] SMM Module: placing smm entry code at 7f675c00, cpu # 0x1
[DEBUG] SMM Module: placing smm entry code at 7f675800, cpu # 0x2
[DEBUG] SMM Module: placing smm entry code at 7f675400, cpu # 0x3
[DEBUG] SMM Module: stub loaded at 7f676000. Will call 0x7f67e54b
[INFO ] smm_do_relocation : curr_smbase 0x30000 perm_smbase 0x7f66e000, cpu = 0
[DEBUG] In relocation handler: cpu 0
[DEBUG] New SMBASE=0x7f66e000
[WARN ] SMRR not enabled, skip writing SMRR...
[DEBUG] Relocation complete.
[DEBUG] CPU doesn't support VMX; exiting
[INFO ] smm_do_relocation : curr_smbase 0x30000 perm_smbase 0x7f66d400, cpu = 3
[DEBUG] In relocation handler: cpu 3
[DEBUG] New SMBASE=0x7f66d400
[DEBUG] Writing SMRR. base = 0x7f600000, mask=0xfff00800
[INFO ] smm_do_relocation : curr_smbase 0x30000 perm_smbase 0x7f66d800, cpu = 2
[DEBUG] In relocation handler: cpu 2
[DEBUG] New SMBASE=0x7f66d800
[INFO ] smm_do_relocation : curr_smbase 0x30000 perm_smbase 0x7f66dc00, cpu = 1
[DEBUG] In relocation handler: cpu 1
[DEBUG] New SMBASE=0x7f66dc00
[INFO ] Initializing CPU #0
[DEBUG] CPU: vendor Intel device 106ca
[DEBUG] CPU: family 06, model 1c, stepping 0a
[INFO ] CPU #0 initialized
[INFO ] Initializing CPU #3
[INFO ] Initializing CPU #2
[INFO ] Initializing CPU #1
[INFO ] CPU #2 initialized
[INFO ] CPU #1 initialized
[INFO ] CPU #3 initialized
[DEBUG] CPU 1 going down...
[INFO ] bsp_do_flight_plan done after 384 msecs.
[DEBUG] CPU 3 going down...
[DEBUG] CPU 2 going down...
[DEBUG] SMI_STS:
[DEBUG] GPE0_STS: GPIO15 GPIO14 GPIO11 GPIO1 GPIO0
[DEBUG] ALT_GP_SMI_STS: GPI15 GPI14 GPI11 GPI7 GPI6 GPI5 GPI4 GPI3 GPI2 GPI1 GPI0
[DEBUG] TCO_STS: INTRD_DET
[DEBUG] Locking SMM.
[DEBUG] CPU_CLUSTER: 0 init finished in 692 msecs
[DEBUG] DOMAIN: 00000000 init
[DEBUG] DOMAIN: 00000000 init finished in 0 msecs
[DEBUG] PCI: 00:00:00.0 init
[DEBUG] PCI: 00:00:00.0 init finished in 0 msecs
[DEBUG] PCI: 00:00:02.0 init
[INFO ] CBFS: Found 'vbt.bin' @0x2cd00 size 0x4ab in mcache @0x7f3dd1b4
[INFO ] Timestamp - starting LZMA decompress (ignore for x86): 5046864060
[INFO ] Timestamp - finished LZMA decompress (ignore for x86): 5060057340
[INFO ] Found a VBT of 3730 bytes
[INFO ] GMA: Found VBT in CBFS
[INFO ] GMA: Found valid VBT in CBFS
[DEBUG] gttbase = 7f700000
[EMERG] CPU Index 0 - APIC 0 Unexpected Exception:2 @ 08:7f2a67d1 - Halting
[EMERG] Code: 0 eflags: 00000097 cr2: 00000000
[EMERG] eax: 30213c1c ebx: 00000000 ecx: 0019f0a0 edx: 00000001
[EMERG] edi: 00000001 esi: 302135e6 ebp: 7f2be6e0 esp: 7f2c1010
[EMERG] 0x7f2a6790: 84 b8 ff ff 83 c4 0c 50
[EMERG] 0x7f2a6798: 68 98 5a 2b 7f 6a 03 e8
[EMERG] 0x7f2a67a0: 10 3e 00 00 83 c4 20 83
[EMERG] 0x7f2a67a8: c8 ff 5b 5e 5f c3 e9 74
[EMERG] 0x7f2a67b0: 3a 00 00 57 56 53 0f ae
[EMERG] 0x7f2a67b8: f0 0f 31 89 d7 89 c6 e8
[EMERG] 0x7f2a67c0: 63 3a 00 00 f7 64 24 10
[EMERG] 0x7f2a67c8: 89 c1 89 d3 0f ae f0 0f
[EMERG] 0x7f2a67d0: 31 29 f0 19 fa 39 c8 89
[EMERG] 0x7f2a67d8: d0 19 d8 73 04 f3 90 eb
[EMERG] 0x7f2a67e0: eb 5b 5e 5f c3 55 57 56
[EMERG] 0x7f2a67e8: 53 83 ec 1c 83 3d 40 96
[EMERG] 0x7f2a67f0: 2c 7f 00 75 1f e8 2d 3a
[EMERG] 0x7f2a67f8: 00 00 0f ae f0 0f 31 c7
[EMERG] 0x7f2a6800: 05 40 96 2c 7f 01 00 00
[EMERG] 0x7f2a6808: 00 a3 4c 96 2c 7f 89 15
[EMERG] 0x7f2c108c: 0x7f2be6e0
[EMERG] 0x7f2c1088: 0x7f2c10a8
[EMERG] 0x7f2c1084: 0x7f2b3fb7
[EMERG] 0x7f2c1080: 0x00000007
[EMERG] 0x7f2c107c: 0xffa3b996
[EMERG] 0x7f2c1078: 0x1f288f8e
[EMERG] 0x7f2c1074: 0x9c000000
[EMERG] 0x7f2c1070: 0x000e0d4f
[EMERG] 0x7f2c106c: 0x001fbf81
[EMERG] 0x7f2c1068: 0x5582504f
[EMERG] 0x7f2c1064: 0x5f2b3fbf
[EMERG] 0x7f2c1060: 0x7f2aa449
[EMERG] 0x7f2c105c: 0x7f2bd360
[EMERG] 0x7f2c1058: 0x7f800000
[EMERG] 0x7f2c1054: 0x0000ef58
[EMERG] 0x7f2c1050: 0x7f2cba5c
[EMERG] 0x7f2c104c: 0x000000a3
[EMERG] 0x7f2c1048: 0x000000a3
[EMERG] 0x7f2c1044: 0x00000020
[EMERG] 0x7f2c1040: 0x00000001
[EMERG] 0x7f2c103c: 0x7f297c4f
[EMERG] 0x7f2c1038: 0xfe880000
[EMERG] 0x7f2c1034: 0xe0000000
[EMERG] 0x7f2c1030: 0xfe880000
[EMERG] 0x7f2c102c: 0x7f2a67c4
[EMERG] 0x7f2c1028: 0x7f2c1048
[EMERG] 0x7f2c1024: 0x7f2b05cd
[EMERG] 0x7f2c1020: 0x000003e8
[EMERG] 0x7f2c101c: 0x7f299150
[EMERG] 0x7f2c1018: 0x000000ff
[EMERG] 0x7f2c1014: 0x00000001
[EMERG] 0x7f2c1010: 0x00000001 <-esp
FATAL: read zero bytes from port
term_exitfunc: reset failed for dev UNKNOWN: Input/output error
PR Updated by Patrick Rudolph about 1 year ago
x86 exception 2 seems to be related to a NMI. The code in the stacktrace seems to be not related to the NMI iteself.
Case 1)
You have set up an watchdog that triggers the NMI?
Case 2)
A hardware error occured. The memory or the CPU isn't working as it should, causing this issue.
DD Updated by David Duchesne about 1 year ago
Patrick Rudolph wrote in #note-1:
Case 1)
You have set up an watchdog that triggers the NMI?Case 2)
- No.
- It was my initial thought so I tried several combination of DDR2 sticks (1x 1GB, 2x 1GB, 1x 2GB, 2x 2GB), nothing.
I just finished desoldering the W25Q128 and put back previous rom (24.05-5a0207e56a), soldered it back and it boots fine again.
I tried with the DDR2 combinations described above and all are working.
[NOTE ] coreboot-24.05-5a0207e56a Tue May 28 04:12:27 UTC 2024 x86_32 bootblock starting (log level: 7)...
[INFO ] Timestamp - end of bootblock: 37019110
[INFO ] Timestamp - starting to load romstage: 45198470
[INFO ] CBFS: Found 'fallback/romstage' @0x80 size 0xd150 in mcache @0xfefc2e2c
[INFO ] Timestamp - finished loading romstage: 67852840
[DEBUG] BS: bootblock times (exec / console): total (unknown) / 35 ms
[NOTE ] coreboot-24.05-5a0207e56a Tue May 28 04:12:27 UTC 2024 x86_32 romstage starting (log level: 7)...
[INFO ] Timestamp - before RAM initialization: 163274930
[DEBUG] 0xfefc1ab0: 0c 04 30 01 02 00 03 3d 50 50 60 32 1e 32 25 80 ..0....=PP`2.2%.
[DEBUG] 0xfefc1ac0: 17 25 05 12 3c 1e 1e 00 30 32 64 80 14 1e 00 00 .%..<...02d.....
[DEBUG] 0xfefc1ad0: 00 03 00 00 00 00 00 00 00 00 00 00 00 00 12 3f ...............?
[DEBUG] ...
[DEBUG] Total memory = 1024MB
[DEBUG] GBSM (igd) = verified 3f800000 (written 3f800000)
[DEBUG] BGSM (gtt) = verified 3f700000 (written 3f700000)
[DEBUG] TSEG (smm) = verified 3f600000 (written 3f600000)
[INFO ] Timestamp - after RAM initialization: 418244640
[DEBUG] CBMEM:
[DEBUG] IMD: root @ 0x3f3ff000 254 entries.
[DEBUG] IMD: root @ 0x3f3fec00 62 entries.
[DEBUG] IMD: root @ 0x3f6ff000 254 entries.
[DEBUG] IMD: root @ 0x3f6fec00 62 entries.
[DEBUG] SMRAM : 0x3f600000 0x100000
[DEBUG] Subregion 0: 0x3f600000 0x80000
[DEBUG] Subregion 1: 0x3f680000 0x80000
[DEBUG] Subregion 2: 0x3f700000 0x0
[DEBUG] Normal boot
[INFO ] CBFS: Found 'fallback/postcar' @0x2d240 size 0x8848 in mcache @0xfefc3054
[DEBUG] Loading module at 0x3f3cd000 with entry 0x3f3cd031. filesize: 0x7fc8 memsize: 0xe318
[DEBUG] Processing 528 relocs. Offset value of 0x3d3cd000
[INFO ] Timestamp - end of romstage: 587454250
[NOTE ] coreboot-24.05-5a0207e56a Tue May 28 04:12:27 UTC 2024 x86_32 postcar starting (log level: 7)...
[INFO ] Timestamp - start of postcar: 626900390
[INFO ] Timestamp - end of postcar: 635246930
[DEBUG] Normal boot
[INFO ] Timestamp - starting to load ramstage: 647638820
[INFO ] CBFS: Found 'fallback/ramstage' @0xd280 size 0x15506 in mcache @0x3f3dd0ac
[INFO ] Timestamp - starting LZMA decompress (ignore for x86): 670693300
[INFO ] Timestamp - finished LZMA decompress (ignore for x86): 789928360
[DEBUG] Loading module at 0x3f294000 with entry 0x3f294000. filesize: 0x2b450 memsize: 0x137ed0
[DEBUG] Processing 3151 relocs. Offset value of 0x3b294000
[INFO ] Timestamp - finished loading ramstage: 827467110
[NOTE ] coreboot-24.05-5a0207e56a Tue May 28 04:12:27 UTC 2024 x86_32 ramstage starting (log level: 7)...
[INFO ] Timestamp - start of ramstage: 867523800
[DEBUG] Normal boot
[INFO ] Timestamp - device enumeration: 880344650
[DEBUG] BS: BS_DEV_INIT_CHIPS run times (exec / console): 0 / 5 ms
[INFO ] done
[DEBUG] BS: BS_DEV_ENUMERATE run times (exec / console): 0 / 300 ms
[INFO ] Timestamp - device configuration: 1421369900
[DEBUG] TOUUD 0x40000000 TOLUD 0x40000000 TOM 0x80000000 8M UMA and 1M GTT
[DEBUG] PCI: 00:00:1c.0 1c * [0x1000 - 0x1fff] limit: 1fff io
[DEBUG] PCI: 00:00:1d.0 20 * [0x2000 - 0x201f] limit: 201f io
[DEBUG] PCI: 00:00:1d.1 20 * [0x2020 - 0x203f] limit: 203f io
[DEBUG] PCI: 00:00:1d.2 20 * [0x2040 - 0x205f] limit: 205f io
[DEBUG] PCI: 00:00:1d.3 20 * [0x2060 - 0x207f] limit: 207f io
[DEBUG] PCI: 00:00:1f.2 20 * [0x2080 - 0x209f] limit: 209f io
[DEBUG] PCI: 00:00:02.0 14 * [0x20a0 - 0x20a7] limit: 20a7 io
[DEBUG] PCI: 00:00:1f.2 10 * [0x20a8 - 0x20af] limit: 20af io
[DEBUG] PCI: 00:00:1f.2 18 * [0x20b0 - 0x20b7] limit: 20b7 io
[DEBUG] PCI: 00:00:1f.2 14 * [0x20b8 - 0x20bb] limit: 20bb io
[DEBUG] PCI: 00:00:1f.2 1c * [0x20bc - 0x20bf] limit: 20bf io
[DEBUG] DOMAIN: 00000000 mem: base: 3f400000 size: 0 align: 0 gran: 0 limit: fdffffff
[DEBUG] avoid_fixed_resources: DOMAIN: 00000000 04 base 00100000 limit 3f3fffff mem (fixed)
[DEBUG] avoid_fixed_resources: DOMAIN: 00000000 05 base 3f600000 limit 3f6fffff mem (fixed)
[DEBUG] avoid_fixed_resources: DOMAIN: 00000000 06 base 3f700000 limit 3f7fffff mem (fixed)
[DEBUG] avoid_fixed_resources: DOMAIN: 00000000 07 base 3f800000 limit 3fffffff mem (fixed)
[DEBUG] avoid_fixed_resources: DOMAIN: 00000000 08 base 3f400000 limit 3f5fffff mem (fixed)
[INFO ] * Base: 40000000, Size: a0000000, Tag: 200
[INFO ] * Base: f0000000, Size: e000000, Tag: 200
[DEBUG] PCI: 00:00:02.0 18 * [0x40000000 - 0x4fffffff] limit: 4fffffff prefmem
[DEBUG] PCI: 00:00:02.0 1c * [0x50000000 - 0x500fffff] limit: 500fffff mem
[DEBUG] PCI: 00:00:1c.0 24 * [0x50100000 - 0x501fffff] limit: 501fffff prefmem
[DEBUG] PCI: 00:00:1c.0 20 * [0x50200000 - 0x502fffff] limit: 502fffff mem
[DEBUG] PCI: 00:00:02.0 10 * [0x50300000 - 0x5037ffff] limit: 5037ffff mem
[DEBUG] PCI: 00:00:02.1 10 * [0x50380000 - 0x503fffff] limit: 503fffff mem
[DEBUG] PCI: 00:00:1b.0 10 * [0x50400000 - 0x50403fff] limit: 50403fff mem
[DEBUG] PCI: 00:00:1d.7 10 * [0x50404000 - 0x504043ff] limit: 504043ff mem
[DEBUG] PCI: 00:00:1f.2 24 * [0x50405000 - 0x504053ff] limit: 504053ff mem
[DEBUG] DOMAIN: 00000000 mem: base: 3f400000 size: 0 align: 0 gran: 0 limit: fdffffff done
[DEBUG] PCI: 00:01:00.0 10 * [0x1000 - 0x10ff] limit: 10ff io
[DEBUG] PCI: 00:01:00.0 18 * [0x50104000 - 0x50104fff] limit: 50104fff prefmem
[DEBUG] PCI: 00:01:00.0 20 * [0x50100000 - 0x50103fff] limit: 50103fff prefmem
[DEBUG] PCI: 00:01:00.0 30 * [0x50200000 - 0x5021ffff] limit: 5021ffff mem
[DEBUG] DOMAIN: 00000000 04 <- [0x0000000000100000 - 0x000000003f3fffff] size 0x3f300000 gran 0x00 mem
[DEBUG] DOMAIN: 00000000 05 <- [0x000000003f600000 - 0x000000003f6fffff] size 0x00100000 gran 0x00 mem
[DEBUG] DOMAIN: 00000000 06 <- [0x000000003f700000 - 0x000000003f7fffff] size 0x00100000 gran 0x00 mem
[DEBUG] DOMAIN: 00000000 07 <- [0x000000003f800000 - 0x000000003fffffff] size 0x00800000 gran 0x00 mem
[DEBUG] DOMAIN: 00000000 08 <- [0x000000003f400000 - 0x000000003f5fffff] size 0x00200000 gran 0x00 mem
[DEBUG] PCI: 00:00:02.0 10 <- [0x0000000050300000 - 0x000000005037ffff] size 0x00080000 gran 0x13 mem
[DEBUG] PCI: 00:00:02.0 14 <- [0x00000000000020a0 - 0x00000000000020a7] size 0x00000008 gran 0x03 io
[DEBUG] PCI: 00:00:02.0 18 <- [0x0000000040000000 - 0x000000004fffffff] size 0x10000000 gran 0x1c prefmem
[DEBUG] PCI: 00:00:02.0 1c <- [0x0000000050000000 - 0x00000000500fffff] size 0x00100000 gran 0x14 mem
[DEBUG] PCI: 00:00:02.1 10 <- [0x0000000050380000 - 0x00000000503fffff] size 0x00080000 gran 0x13 mem
[DEBUG] PCI: 00:00:1b.0 10 <- [0x0000000050400000 - 0x0000000050403fff] size 0x00004000 gran 0x0e mem64
[DEBUG] PCI: 00:00:1c.0 1c <- [0x0000000000001000 - 0x0000000000001fff] size 0x00001000 gran 0x0c seg 00 buio
[DEBUG] PCI: 00:00:1c.0 24 <- [0x0000000050100000 - 0x00000000501fffff] size 0x00100000 gran 0x14 seg 00 buprefmem
[DEBUG] PCI: 00:00:1c.0 20 <- [0x0000000050200000 - 0x00000000502fffff] size 0x00100000 gran 0x14 seg 00 bumem
[DEBUG] PCI: 00:01:00.0 10 <- [0x0000000000001000 - 0x00000000000010ff] size 0x00000100 gran 0x08 io
[DEBUG] PCI: 00:01:00.0 18 <- [0x0000000050104000 - 0x0000000050104fff] size 0x00001000 gran 0x0c prefmem64
[DEBUG] PCI: 00:01:00.0 20 <- [0x0000000050100000 - 0x0000000050103fff] size 0x00004000 gran 0x0e prefmem64
[DEBUG] PCI: 00:01:00.0 30 <- [0x0000000050200000 - 0x000000005021ffff] size 0x00020000 gran 0x11 romem
[DEBUG] PCI: 00:00:1c.1 1c <- [0x000000000000ffff - 0x000000000000fffe] size 0x00000000 gran 0x0c seg 00 buio
[DEBUG] PCI: 00:00:1c.1 24 <- [0xffffffffffffffff - 0xfffffffffffffffe] size 0x00000000 gran 0x14 seg 00 buprefmem
[DEBUG] PCI: 00:00:1c.1 20 <- [0x00000000ffffffff - 0x00000000fffffffe] size 0x00000000 gran 0x14 seg 00 bumem
[DEBUG] PCI: 00:00:1c.2 1c <- [0x000000000000ffff - 0x000000000000fffe] size 0x00000000 gran 0x0c seg 00 buio
[DEBUG] PCI: 00:00:1c.2 24 <- [0xffffffffffffffff - 0xfffffffffffffffe] size 0x00000000 gran 0x14 seg 00 buprefmem
[DEBUG] PCI: 00:00:1c.2 20 <- [0x00000000ffffffff - 0x00000000fffffffe] size 0x00000000 gran 0x14 seg 00 bumem
[DEBUG] PCI: 00:00:1c.3 1c <- [0x000000000000ffff - 0x000000000000fffe] size 0x00000000 gran 0x0c seg 00 buio
[DEBUG] PCI: 00:00:1c.3 24 <- [0xffffffffffffffff - 0xfffffffffffffffe] size 0x00000000 gran 0x14 seg 00 buprefmem
[DEBUG] PCI: 00:00:1c.3 20 <- [0x00000000ffffffff - 0x00000000fffffffe] size 0x00000000 gran 0x14 seg 00 bumem
[DEBUG] PCI: 00:00:1d.0 20 <- [0x0000000000002000 - 0x000000000000201f] size 0x00000020 gran 0x05 io
[DEBUG] PCI: 00:00:1d.1 20 <- [0x0000000000002020 - 0x000000000000203f] size 0x00000020 gran 0x05 io
[DEBUG] PCI: 00:00:1d.2 20 <- [0x0000000000002040 - 0x000000000000205f] size 0x00000020 gran 0x05 io
[DEBUG] PCI: 00:00:1d.3 20 <- [0x0000000000002060 - 0x000000000000207f] size 0x00000020 gran 0x05 io
[DEBUG] PCI: 00:00:1d.7 10 <- [0x0000000050404000 - 0x00000000504043ff] size 0x00000400 gran 0x0a mem
[DEBUG] PCI: 00:00:1e.0 1c <- [0x000000000000ffff - 0x000000000000fffe] size 0x00000000 gran 0x0c seg 00 buio
[DEBUG] PCI: 00:00:1e.0 24 <- [0xffffffffffffffff - 0xfffffffffffffffe] size 0x00000000 gran 0x14 seg 00 buprefmem
[DEBUG] PCI: 00:00:1e.0 20 <- [0x00000000ffffffff - 0x00000000fffffffe] size 0x00000000 gran 0x14 seg 00 bumem
[DEBUG] PCI: 00:00:1f.2 10 <- [0x00000000000020a8 - 0x00000000000020af] size 0x00000008 gran 0x03 io
[DEBUG] PCI: 00:00:1f.2 14 <- [0x00000000000020b8 - 0x00000000000020bb] size 0x00000004 gran 0x02 io
[DEBUG] PCI: 00:00:1f.2 18 <- [0x00000000000020b0 - 0x00000000000020b7] size 0x00000008 gran 0x03 io
[DEBUG] PCI: 00:00:1f.2 1c <- [0x00000000000020bc - 0x00000000000020bf] size 0x00000004 gran 0x02 io
[DEBUG] PCI: 00:00:1f.2 20 <- [0x0000000000002080 - 0x000000000000209f] size 0x00000020 gran 0x05 io
[DEBUG] PCI: 00:00:1f.2 24 <- [0x0000000050405000 - 0x00000000504053ff] size 0x00000400 gran 0x0a mem
[DEBUG] BS: BS_DEV_RESOURCES run times (exec / console): 1 / 1158 ms
[INFO ] Timestamp - device enable: 3403135450
[INFO ] done.
[INFO ] Timestamp - device initialization: 3733550070
[DEBUG] 0x00000000000c0000 - 0x000000003f5fffff size 0x3f540000 type 6
[DEBUG] 0x000000003f600000 - 0x000000003fffffff size 0x00a00000 type 0
[DEBUG] 0x0000000040000000 - 0x000000004fffffff size 0x10000000 type 1
[DEBUG] 0x0000000050000000 - 0x00000000ffffffff size 0xb0000000 type 0
[DEBUG] MTRR: 0 base 0x0000000000000000 mask 0x0000000fc0000000 type 6
[DEBUG] MTRR: 1 base 0x000000003f600000 mask 0x0000000fffe00000 type 0
[DEBUG] MTRR: 2 base 0x000000003f800000 mask 0x0000000fff800000 type 0
[DEBUG] MTRR: 3 base 0x0000000040000000 mask 0x0000000ff0000000 type 1
[DEBUG] MTRR check
[INFO ] AP: slot 3 apic_id 3, MCU rev: 0x00000000
[INFO ] AP: slot 2 apic_id 2, MCU rev: 0x00000000
[DEBUG] done.
[INFO ] AP: slot 1 apic_id 1, MCU rev: 0x00000000
[DEBUG] done.
[DEBUG] smm_module_setup_stub: stack_top = 0x3f601000
[DEBUG] SMM Module: stub loaded at 38000. Will call 0x3f2a8182
[DEBUG] Installing permanent SMM handler to 0x3f600000
[DEBUG] HANDLER [0x3f67e000-0x3f67f190]
[DEBUG] CPU 0
[DEBUG] ss0 [0x3f67dc00-0x3f67e000]
[DEBUG] stub0 [0x3f676000-0x3f6761d8]
[DEBUG] CPU 1
[DEBUG] ss1 [0x3f67d800-0x3f67dc00]
[DEBUG] stub1 [0x3f675c00-0x3f675dd8]
[DEBUG] CPU 2
[DEBUG] ss2 [0x3f67d400-0x3f67d800]
[DEBUG] stub2 [0x3f675800-0x3f6759d8]
[DEBUG] CPU 3
[DEBUG] ss3 [0x3f67d000-0x3f67d400]
[DEBUG] stub3 [0x3f675400-0x3f6755d8]
[DEBUG] stacks [0x3f600000-0x3f601000]
[DEBUG] Loading module at 0x3f67e000 with entry 0x3f67e55c. filesize: 0x1140 memsize: 0x1190
[DEBUG] Processing 51 relocs. Offset value of 0x3f67e000
[DEBUG] Loading module at 0x3f676000 with entry 0x3f676000. filesize: 0x1d8 memsize: 0x1d8
[DEBUG] Processing 9 relocs. Offset value of 0x3f676000
[DEBUG] SMM Module: placing smm entry code at 3f675c00, cpu # 0x1
[DEBUG] SMM Module: placing smm entry code at 3f675800, cpu # 0x2
[DEBUG] SMM Module: placing smm entry code at 3f675400, cpu # 0x3
[DEBUG] SMM Module: stub loaded at 3f676000. Will call 0x3f67e55c
[INFO ] smm_do_relocation : curr_smbase 0x30000 perm_smbase 0x3f66e000, cpu = 0
[DEBUG] New SMBASE=0x3f66e000
[INFO ] smm_do_relocation : curr_smbase 0x30000 perm_smbase 0x3f66dc00, cpu = 1
[DEBUG] New SMBASE=0x3f66dc00
[DEBUG] Writing SMRR. base = 0x3f600000, mask=0xfff00800
[INFO ] smm_do_relocation : curr_smbase 0x30000 perm_smbase 0x3f66d800, cpu = 2
[DEBUG] New SMBASE=0x3f66d800
[INFO ] smm_do_relocation : curr_smbase 0x30000 perm_smbase 0x3f66d400, cpu = 3
[DEBUG] New SMBASE=0x3f66d400
[INFO ] bsp_do_flight_plan done after 366 msecs.
[DEBUG] SMI_STS:
[DEBUG] ALT_GP_SMI_STS: GPI15 GPI14 GPI13 GPI12 GPI11 GPI10 GPI9 GPI8 GPI7 GPI6 GPI5 GPI4 GPI3 GPI2 GPI1 GPI0
[DEBUG] CPU_CLUSTER: 0 init finished in 695 msecs
[INFO ] CBFS: Found 'vbt.bin' @0x2c800 size 0x4ab in mcache @0x3f3dd1d4
[INFO ] Timestamp - starting LZMA decompress (ignore for x86): 4990933790
[INFO ] Timestamp - finished LZMA decompress (ignore for x86): 5004134900
[DEBUG] gttbase = 3f700000
[INFO ] GTT PGETBL_CTL register : 0x00000001
[INFO ] GTT PGETBL2_CTL register: 0x00000000
[DEBUG] PCI: 00:00:02.0 init finished in 55 msecs
[DEBUG] PCI: 00:00:02.1 init
[DEBUG] PCI: 00:00:02.1 init finished in 0 msecs
[DEBUG] PCI: 00:00:1b.0 init
[DEBUG] Azalia: codec type: Azalia
[DEBUG] Azalia: base = 50400000
[DEBUG] Azalia: codec_mask = 04
[DEBUG] azalia_audio: Initializing codec #2
[DEBUG] azalia_audio: codec viddid: 10ec0662
[DEBUG] azalia_audio: verb_size: 40
[DEBUG] azalia_audio: verb not loaded.
[DEBUG] PCI: 00:00:1b.0 init finished in 31 msecs
[DEBUG] PCI: 00:00:1c.0 init
[DEBUG] Initializing ICH7 PCIe bridge.
[DEBUG] PCI: 00:00:1c.0 init finished in 4 msecs
[DEBUG] PCI: 00:00:1c.1 init
[DEBUG] PCI: 00:00:1c.1 init finished in 4 msecs
[DEBUG] PCI: 00:00:1c.2 init
[DEBUG] PCI: 00:00:1c.2 init finished in 4 msecs
[DEBUG] PCI: 00:00:1c.3 init
[DEBUG] PCI: 00:00:1c.3 init finished in 4 msecs
[DEBUG] PCI: 00:00:1d.0 init
[DEBUG] UHCI: Setting up controller.. done.
[DEBUG] PCI: 00:00:1d.0 init finished in 4 msecs
[DEBUG] PCI: 00:00:1d.1 init
[DEBUG] PCI: 00:00:1d.1 init finished in 4 msecs
[DEBUG] PCI: 00:00:1d.2 init
[DEBUG] PCI: 00:00:1d.2 init finished in 4 msecs
[DEBUG] PCI: 00:00:1d.3 init
[DEBUG] PCI: 00:00:1d.3 init finished in 4 msecs
[DEBUG] PCI: 00:00:1d.7 init
[DEBUG] EHCI: Setting up controller.. done.
[DEBUG] PCI: 00:00:1d.7 init finished in 4 msecs
[DEBUG] PCI: 00:00:1e.0 init
[DEBUG] PCI: 00:00:1e.0 init finished in 0 msecs
[DEBUG] PCI: 00:00:1f.0 init
[DEBUG] i82801gx: lpc_init
[DEBUG] IOAPIC: Initializing IOAPIC at fec00000
[DEBUG] IOAPIC: ID = 0x00
[DEBUG] IOAPIC: 24 interrupts
[DEBUG] IOAPIC: Clearing IOAPIC at fec00000
[DEBUG] IOAPIC: Bootstrap Processor Local APIC = 0x00
[INFO ] Set power off after power failure.
[INFO ] NMI sources enabled.
[DEBUG] rtc_failed = 0x0
[DEBUG] RTC Init
[WARN ] RTC: Checksum invalid
[DEBUG] apm_control: Disabling ACPI.
[DEBUG] APMC done.
[DEBUG] PCI: 00:00:1f.0 init finished in 48 msecs
[DEBUG] PCI: 00:00:1f.2 init
[DEBUG] i82801gx_sata: initializing...
[DEBUG] SATA controller in AHCI mode.
[DEBUG] PCI: 00:00:1f.2 init finished in 8 msecs
[DEBUG] PCI: 00:01:00.0 init
[DEBUG] PCI: 00:01:00.0 init finished in 0 msecs
[DEBUG] PNP: 004e.1 init
[DEBUG] PNP: 004e.1 init finished in 0 msecs
[DEBUG] PNP: 004e.2 init
[DEBUG] PNP: 004e.2 init finished in 0 msecs
[DEBUG] PNP: 004e.3 init
[DEBUG] PNP: 004e.3 init finished in 0 msecs
[DEBUG] PNP: 004e.5 init
[DEBUG] PNP: 004e.5 init finished in 0 msecs
[DEBUG] PNP: 004e.b init
[DEBUG] PNP: 004e.b init finished in 0 msecs
[DEBUG] smbus: PCI: 00:00:1f.3->I2C: 01:69 init
[DEBUG] Changing 13 of the 13 ck505 config bytes.
[DEBUG] I2C: 01:69 init finished in 32 msecs
[INFO ] Devices initialized
[DEBUG] BS: BS_DEV_INIT run times (exec / console): 237 / 892 ms
[INFO ] Finalize devices...
[DEBUG] PCI: 00:00:1f.0 final
[INFO ] Manufacturer: ef
[INFO ] SF: Detected ef 4018 with sector size 0x1000, total 0x1000000
[INFO ] Devices finalized
[INFO ] Timestamp - device setup done: 5698134760
[DEBUG] BS: BS_POST_DEVICE run times (exec / console): 0 / 25 ms
[INFO ] Timestamp - cbmem post: 5717638400
[DEBUG] BS: BS_OS_RESUME_CHECK run times (exec / console): 1 / 4 ms
[INFO ] Timestamp - write tables: 5736559900
[INFO ] CBFS: Found 'fallback/dsdt.aml' @0x2a8c0 size 0x1ef0 in mcache @0x3f3dd1a8
[WARN ] CBFS: 'fallback/slic' not found.
[INFO ] ACPI: Writing ACPI tables at 3f254000.
[DEBUG] ACPI: * FACS
[DEBUG] ACPI: * FACP
[DEBUG] ACPI: added table 1/32, length now 44
[DEBUG] Found 1 CPU(s) with 4 core(s) each.
[DEBUG] clocks between 1333 and 1666 MHz.
[DEBUG] adding 2 P-States between busratio 8 and a, incl. P0
[DEBUG] PSS: 1666MHz power 35000 control 0xa12 status 0xa12
[DEBUG] PSS: 1333MHz power 25000 control 0x812 status 0x812
[WARN ] CBFS: 'pci8086,a002.rom' not found.
[DEBUG] PCI Option ROM loading disabled for PCI: 00:00:02.1
[WARN ] PCI: 00:00:02.1: Missing PCI Option ROM
[DEBUG] Generating ACPI PIRQ entries
[DEBUG] ACPI: * SSDT
[DEBUG] ACPI: added table 2/32, length now 52
[DEBUG] ACPI: * MCFG
[DEBUG] ACPI: added table 3/32, length now 60
[DEBUG] ACPI: * APIC
[DEBUG] ACPI: added table 4/32, length now 68
[DEBUG] ACPI: * SPCR
[DEBUG] ACPI: added table 5/32, length now 76
[DEBUG] current = 3f256a00
[DEBUG] ACPI: * HPET
[DEBUG] ACPI: added table 6/32, length now 84
[INFO ] ACPI: done.
[DEBUG] ACPI tables: 10816 bytes.
[DEBUG] smbios_write_tables: 3f24c000
[DEBUG] SMBIOS firmware version is set to coreboot_version: '24.05-5a0207e56a'
[DEBUG] SMBIOS tables: 622 bytes.
[DEBUG] Writing table forward entry at 0x00000500
[DEBUG] Wrote coreboot table at: 0x00000500, 0x10 bytes, checksum 40b7
[DEBUG] Writing coreboot table at 0x3f278000
[INFO ] CBFS: Found 'cmos_layout.bin' @0x2ce40 size 0x3c8 in mcache @0x3f3dd22c
[DEBUG] 0. 0000000000000000-0000000000000fff: CONFIGURATION TABLES
[DEBUG] 1. 0000000000001000-000000000009ffff: RAM
[DEBUG] 2. 00000000000a0000-00000000000fffff: RESERVED
[DEBUG] 3. 0000000000100000-000000003f24bfff: RAM
[DEBUG] 4. 000000003f24c000-000000003f293fff: CONFIGURATION TABLES
[DEBUG] 5. 000000003f294000-000000003f3cbfff: RAMSTAGE
[DEBUG] 6. 000000003f3cc000-000000003f3fffff: CONFIGURATION TABLES
[DEBUG] 7. 000000003f400000-000000003fffffff: RESERVED
[DEBUG] 8. 00000000e0000000-00000000efffffff: RESERVED
[DEBUG] 9. 00000000fed00000-00000000fedfffff: RESERVED
[DEBUG] Wrote coreboot table at: 0x3f278000, 0x750 bytes, checksum 8378
[DEBUG] coreboot table: 1896 bytes.
[DEBUG] IMD ROOT 0. 0x3f3ff000 0x00001000
[DEBUG] IMD SMALL 1. 0x3f3fe000 0x00001000
[DEBUG] CONSOLE 2. 0x3f3de000 0x00020000
[DEBUG] RO MCACHE 3. 0x3f3dd000 0x00000420
[DEBUG] TIME STAMP 4. 0x3f3dc000 0x00000910
[DEBUG] AFTER CAR 5. 0x3f3cc000 0x00010000
[DEBUG] RAMSTAGE 6. 0x3f293000 0x00139000
[DEBUG] SMM BACKUP 7. 0x3f283000 0x00010000
[DEBUG] IGD OPREGION 8. 0x3f280000 0x00002e92
[DEBUG] COREBOOT 9. 0x3f278000 0x00008000
[DEBUG] ACPI 10. 0x3f254000 0x00024000
[DEBUG] SMBIOS 11. 0x3f24c000 0x00008000
[DEBUG] IMD small region:
[DEBUG] IMD ROOT 0. 0x3f3fec00 0x00000400
[DEBUG] FMAP 1. 0x3f3feb40 0x000000b6
[DEBUG] ROMSTAGE 2. 0x3f3feb20 0x00000004
[DEBUG] ROMSTG STCK 3. 0x3f3fea80 0x00000088
[DEBUG] ACPI GNVS 4. 0x3f3fe980 0x00000100
[INFO ] Timestamp - finalize chips: 6406050930
[DEBUG] BS: BS_WRITE_TABLES run times (exec / console): 5 / 394 ms
[INFO ] Timestamp - starting to load payload: 6425409750
[INFO ] CBFS: Found 'fallback/payload' @0x35b00 size 0x11bae in mcache @0x3f3dd298
[DEBUG] Checking segment from ROM address 0xff135d2c
[DEBUG] Payload being loaded at below 1MiB without region being marked as RAM usable.
[DEBUG] Checking segment from ROM address 0xff135d48
[DEBUG] Loading segment from ROM address 0xff135d2c
[DEBUG] code (compression=1)
[DEBUG] New segment dstaddr 0x000de100 memsize 0x21f00 srcaddr 0xff135d64 filesize 0x11b76
[DEBUG] Loading Segment: addr: 0x000de100 memsz: 0x0000000000021f00 filesz: 0x0000000000011b76
[DEBUG] using LZMA
[INFO ] Timestamp - starting LZMA decompress (ignore for x86): 6529696850
[INFO ] Timestamp - finished LZMA decompress (ignore for x86): 6604913840
[DEBUG] Loading segment from ROM address 0xff135d48
[DEBUG] Entry Point 0x000fd247
[DEBUG] BS: BS_PAYLOAD_LOAD run times (exec / console): 38 / 84 ms
[DEBUG] ICH-NM10-PCH: watchdog disabled
[DEBUG] Jumping to boot code at 0x000fd247(0x3f278000)
[INFO ] Timestamp - selfboot jump: 6659816060
SeaBIOS (version rel-1.16.3-0-ga6ed6b70)
BUILD: gcc: (coreboot toolchain v_) 13.2.0 binutils: (GNU Binutils) 2.42
Found coreboot cbmem console @ 3f3de000
Found mainboard Intel D510MO
Relocating init from 0x000df860 to 0x3e23eb60 (size 54272)
Found CBFS header at 0xff10022c
multiboot: eax=3f2bee58, ebx=3f2bee24
Found 18 PCI devices (max PCI bus is 05)
Copying SMBIOS from 0x3f24c000 to 0x000f5ae0
Copying SMBIOS 3.0 from 0x3f24c020 to 0x000f5ac0
Copying ACPI RSDP from 0x3f254000 to 0x000f5a90
table(50434146)=0x3f256190 (via xsdt)
Using pmtimer, ioport 0x508
Scan for VGA option rom
Running option rom at c000:0003
Start SeaVGABIOS (version rel-1.16.3-0-ga6ed6b70)
VGABUILD: gcc: (coreboot toolchain v_) 13.2.0 binutils: (GNU Binutils) 2.42
enter vga_post:
a=00000000 b=0000ffff c=00000000 d=0000ffff ds=0000 es=f000 ss=0000
si=00000000 di=00006680 bp=00000000 sp=00006daa cs=f000 ip=d014 f=0000
coreboot vga init
Did not find coreboot framebuffer - assuming EGA text
Attempting to allocate 512 bytes lowmem via pmm call to f000:d08c
pmm call arg1=0
VGA stack allocated at ec1a0
Hooking hardware timer irq (old=f000fea5 new=c0003f3a)
Turning on vga text mode console
set VGA mode 3
EHCI init on dev 00:1d.7 (regs=0x50404020)
UHCI init on dev 00:1d.0 (io=2000)
UHCI init on dev 00:1d.1 (io=2020)
UHCI init on dev 00:1d.2 (io=2040)
UHCI init on dev 00:1d.3 (io=2060)
AHCI controller at 00:1f.2, iobase 0x50405000, irq 0
Searching bootorder for: HALT
Found 0 lpt ports
Found 2 serial ports
Searching bootorder for: /rom@img/memtest64
Searching bootorder for: /rom@img/grub2
Got ps2 nak (status=51)
All threads complete.
Scan for option roms
Press ESC for boot menu.
Space available for UMB: c7800-eb800, f5300-f5a70
Returned 16777216 bytes of ZoneHigh
e820 map has 7 items:
0: 0000000000000000 - 000000000009fc00 = 1 RAM
1: 000000000009fc00 - 00000000000a0000 = 2 RESERVED
2: 00000000000f0000 - 0000000000100000 = 2 RESERVED
3: 0000000000100000 - 000000003f24c000 = 1 RAM
4: 000000003f24c000 - 0000000040000000 = 2 RESERVED
5: 00000000e0000000 - 00000000f0000000 = 2 RESERVED
6: 00000000fed00000 - 00000000fee00000 = 2 RESERVED
enter handle_19:
NULL
Booting from CBFS...
Run img/memtest64
No support for compression type 8ec88c07
enter handle_18:
NULL
Run img/grub2
Calling addr 0x00009000
DD Updated by David Duchesne about 1 year ago ยท Edited
David Duchesne wrote in #note-2:
While the board now boots fine, I noticed that after a while (30min on), when I power off / on, I have the same error :
Also with a simple reboot, I also received a ram init failure. But not always. Only after a couple of minutes uptime.
but in both cases, clearing cmos and wait a 1 or 2min and it boots fine again. (with 25.06, it was completely bricked)
Not sure where to go from here. It would be nice if other with this board could either confirm if they notice similar behaviour or not.
But I think it is might be an hardware issue indeed, the board is very old already.
Feel free to close or leave it open.
I'll keep using it a little while with linux to see if I notice other strange things.
It is possible that raminit isn't perfectly working and you end with a slightly unstable DIMM.
When the issue is 100% reproducible you can start a git bisect and try to figure out which code change made it worse.
