Bug #6
closedchannel test fails on a Samsung DDR3L 8G memory with IVB processor
I'm using coreboot with a lenovo T420 laptop. I build coreboot as follows:
- checkout to a commit
- apply these patches:
- commit aad34cda4bc9c14ed10b00fe5da3f32233257913 (if the commit I checkout is older than this commit)
- http://review.coreboot.org/#/c/11765/
- http://review.coreboot.org/#/c/12087/2
- build coreboot
I found the latest git code causes a channel test failure on Samsung 8G DDR3L M471B1G73DB0-YK0 with i7-3720QM(QS version) processor, it works fine if I do one of the following changes:
- use i5-2520M processor
- use a 1.5V DDR3 8G memory or a Samsung 4G DDR3L module M471B5173QH0-YK0
I did a git bisect and the first bad commit is 9f1fbb9a3002e8d74d53d7973bd1c7e3d4879238.
Files
AC Updated by Alexander Couzens about 11 years ago
@Iru it would be nice ifyou could add your .config,
what's the last upstream commit?
Ping siro about this.
SR Updated by Stefan Reinauer about 11 years ago
Did you verify if the problem goes away if you back out exactly this patch with a top of tree build?
Also, did you try running with mrc.bin instead of native ram init?
IC Updated by Iru Cai about 11 years ago
- File ehci_normal.log ehci_normal.log added
- File config config added
Yes, I reverse patch that commit and the laptop boots with that memory module.
Well, I don't know other MRC(is that the FSP or ChromiumOS MRC) other than the coreboot MRC.
And I've add my config and a normal boot log after reverse patching that commit and use that Samsung 8G DDR3L.
I've just add my config.
362dbea2c9674bb50ddf2da306f477e7ae091134
PR Updated by Patrick Rudolph about 11 years ago
Please provide a full raminit log of the failing memory initialization.
- File faillog.tar.xz faillog.tar.xz added
- File normallog.tar.xz normallog.tar.xz added
OK. I set up the verbose RAM init log debug option and do the test. And I get some logs about channel test failure, and successful boots after a reverse patchcing.
IC Updated by Iru Cai almost 11 years ago
I've done some more testing recently, and found some more details:
- No bugs if I use a i5-3340M
- I just tested with a hynix 8G DDR3L module HMT41GS6BFR8A-PB, the machine also failed to boot, reverting that patch also solved the problem.
PR Updated by Patrick Rudolph almost 11 years ago
This issue is fixed on master as https://review.coreboot.org/#/c/11248/ have been reverted. An updated version is under review: https://review.coreboot.org/#/c/13714/. Please test if possible.
IC Updated by Iru Cai over 10 years ago
PR Updated by Patrick Rudolph over 10 years ago
- Status changed from Resolved to Closed
