Bug #508
closed
YW NH
Dojo fails to boot from NVMe with CONFIG_RESOURCE_ALLOCATION_TOP_DOWN enabled
Bug #508: Dojo fails to boot from NVMe with CONFIG_RESOURCE_ALLOCATION_TOP_DOWN enabled
Added by Yu-Ping Wu about 3 years ago. Updated about 3 years ago.
Resolved
08/31/2023
Similar to #499, after https://review.coreboot.org/c/coreboot/+/75012, Dojo fails to boot.
Disabling CONFIG_RESOURCE_ALLOCATION_TOP_DOWN fixes the problem.
However I'm not sure how to fix it from MediaTek's PCIe functions or settings (for example mtk_pcie_domain_read_resources).
Files
ap-bad.log (32.8 KB) ap-bad.log Yu-Ping Wu, 08/31/2023 10:58 AM
Related issues 1 (0 open — 1 closed)
Related to coreboot - Bug #499: coreboot will not boot edk2 on Lenovo T440p with CONFIG_RESOURCE_ALLOCATION_TOP_DOWN enabled, cannot disable this setting during buildClosedNico Huber06/29/2023
YW Updated by Yu-Ping Wu about 3 years ago Actions #1
  • Related to Bug #499: coreboot will not boot edk2 on Lenovo T440p with CONFIG_RESOURCE_ALLOCATION_TOP_DOWN enabled, cannot disable this setting during build added
YW Updated by Yu-Ping Wu about 3 years ago Actions #2
dojo-rev1 ~ # lspci
0000:00:00.0 PCI bridge: MEDIATEK Corp. Device 8195 (rev 01)
0000:01:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller 980
0001:00:00.0 PCI bridge: MEDIATEK Corp. Device 8195 (rev 01)
0001:01:00.0 Network controller: MEDIATEK Corp. MT7921 802.11ax PCI Express Wireless Network Adapter
AH Updated by Arthur Heymans about 3 years ago Actions #3
I don't understand the hardware however I tried to look at the soc code.
In soc/mediatek/common/pcie.c I see the following:
write32p(table, mmio_res->cpu_addr |
	 PCIE_ATR_SIZE(__fls(mmio_res->size)));
Correct me if I'm wrong but would this not only program the most significant bit of the mmio region size?
Could it be that instead of a 48M window a 32M window is actually set up which would break top down allocation?
Would it be worth trying to set a size of 64M or 32M?
YW Updated by Yu-Ping Wu about 3 years ago Actions #4
Arthur Heymans wrote in #note-3:
Yes, you're right. This will be fixed in https://review.coreboot.org/c/coreboot/+/78044. Thanks.
YW Updated by Yu-Ping Wu about 3 years ago Actions #5
