Support #434
open
LC
Add Winbond W25Q128FW support
Support #434: Add Winbond W25Q128FW support
Added by Luca Consoli about 4 years ago. Updated almost 3 years ago.
New
Flash chip
10/24/2022
Arch Linux
Hello,
is it possible to support Winbond W25Q128FW please?
Datasheet is here.
LC Updated by Luca Consoli about 4 years ago Actions #1
  • Tracker changed from Feature to Support
  • Category set to Flash chip
  • Affected OS set to Arch Linux
  • Affected versions 1.2 added
I've found that this chip is already supported, however i face this issue when trying to autodetect it: Found Generic flash chip "unknown SPI chip (RDID)" (0 kB, SPI) on serprog..
FS Updated by Felix Singer almost 4 years ago Actions #2
A common issue is that the connectivity to the chip is unstable. If you use wires, then please check that the connection is solid and the wires are not too long. It should be <20cm, I prefer something between 10-15cm at most.
AK Updated by Anastasia Klimchuk almost 3 years ago Actions #3
Hello Luca, how this is going? It's right that the chip already supported, covered by the definition W25Q128.W
