Bug #408
closed
AG AG
Bug #438: Release v1.4
flashbuses_to_text() may crash flashrom
Bug #408: flashbuses_to_text() may crash flashrom
Added by Alexander Goncharov about 4 years ago. Updated over 3 years ago.
Resolved
08/22/2022
See the provided comments in the function code towards the end.
 * Return a string corresponding to the bustype parameter.
 * Memory is obtained with malloc() and must be freed with free() by the caller.
char *flashbuses_to_text(enum chipbustype bustype)
	char *ret = calloc(1, 1);
	 * FIXME: Once all chipsets and flash chips have been updated, NONSPI
	 * will cease to exist and should be eliminated here as well.
	if (bustype == BUS_NONSPI) {
		ret = strcat_realloc(ret, "Non-SPI, ");
	} else {
		if (bustype & BUS_PARALLEL)
			ret = strcat_realloc(ret, "Parallel, ");
		if (bustype & BUS_LPC)
			ret = strcat_realloc(ret, "LPC, ");
		if (bustype & BUS_FWH)
			ret = strcat_realloc(ret, "FWH, ");
		if (bustype & BUS_SPI)
			ret = strcat_realloc(ret, "SPI, ");
		if (bustype & BUS_PROG)
			ret = strcat_realloc(ret, "Programmer-specific, ");
		if (bustype == BUS_NONE)
			ret = strcat_realloc(ret, "None, ");
    // BUG:
    // If ret == NULL right now, then flashrom will crash.
    // strlen(ret) will cause a segmentation fault.
	/* Kill last comma. */
	ret[strlen(ret) - 2] = '\0';
	ret = realloc(ret, strlen(ret) + 1);
	return ret;
FS Updated by Felix Singer about 4 years ago Actions #1
  • Parent task set to #353
FS Updated by Felix Singer about 4 years ago Actions #2
How did you encounter the bug? How can one reproduce it? Please give some more details.
E. Updated by Edward . almost 4 years ago Actions #3
AG Updated by Alexander Goncharov almost 4 years ago Actions #4
I found this bug when I just went through the code. strcat_realloc() can return NULL, but we don't handle this case. So, the bug will appear only when the PC has no available memory (out of memory).
Edward, your implementation is interesting but still has some memory problems. The first calloc(), which initializes char *ret, can fail and returns NULL; strlen(NULL) will cause an error.
FS Updated by Felix Singer almost 4 years ago Actions #5
  • Assignee changed from Alexander Goncharov to Felix Singer
AK Updated by Anastasia Klimchuk almost 4 years ago Actions #6
  • Assignee changed from Felix Singer to Alexander Goncharov
  • Parent task changed from #353 to #438
AK Updated by Anastasia Klimchuk over 3 years ago Actions #8
Fixed (see patch above)
