Feature #389
closed
AK
AG
programmers can restore pci value in shutdown function
Feature #389:
07/15/2022
Resetting the bit to zero can be done in *_shutdown by reading the register, set it (for example, reg &= ~(1 << 24)) and write it back with pci_write_long(dev, SOME_SPECIAL_REG, reg).
It's related to next programmers:
- atahpt.c
- drkaiser.c
- gfxnvidia.c
- it8212.c
See the comment thread in the linked patch for more details.
FS Updated by Felix Singer over 4 years ago
Shouldn't this go to the cleanup tracker?
AK Updated by Anastasia Klimchuk over 4 years ago
- Assignee changed from Anastasia Klimchuk to Alexander Goncharov
AG Updated by Alexander Goncharov over 4 years ago
- Subject changed from atahpt can reset REG_FLASH_ACCESS in shutdown function to programmers can restore pci value in shutdown function
- Description updated (diff)
Reversible writes were introduced in commit 2bee8cf898007687c58ddb29eb119b461704f18a . Before this commit, the programmers were restoring a PCI value themselves, e.g:
atahpt :
uint32_t reg32;
/* Disable flash access again. */
reg32 = pci_read_long(pcidev_dev, REG_FLASH_ACCESS);
reg32 &= ~(1 << 24);
pci_write_long(pcidev_dev, REG_FLASH_ACCESS, reg32);
drkaiser :
/* Write protect the flash again. */
pci_write_word(pcidev_dev, PCI_MAGIC_DRKAISER_ADDR, 0);
gfxnvidia :
uint32_t reg32;
/* Disallow access to flash interface (and re-enable screen). */
reg32 = pci_read_long(pcidev_dev, 0x50);
reg32 |= (1 << 0);
pci_write_long(pcidev_dev, 0x50, reg32);
AG Updated by Alexander Goncharov about 4 years ago
Done!
