Bug #386
closed
GG
ASUS P8Z77-V LX2 - Raminit issue at second boot with two 8GiB DIMMs - bootloop
Bug #386: ASUS P8Z77-V LX2 - Raminit issue at second boot with two 8GiB DIMMs - bootloop
Added by gzz5f gzz5f over 4 years ago. Updated over 3 years ago.
Closed
High
board support
06/05/2022
ASUS P8Z77-V LX2
all
I build coreboot today for the ASUS P8Z77-V LX2 and used the latest coreboot master code.
The 2 8GiB DIMMs are working fine at first boot. You can start computer, install from a live media the OS and so on. But at the second boot it failes boot forever and its bootooping. It does not make a change if i boot for a second until SeaBIOS output and then turn off the computer or use the computer for longer time. The second boot is always broken.
Workaround 1: Remove one of the two 8GiB DIMMs. Then the computer also starts fine after a reboot.
Workaround 2: Install two 4GiB DIMMs instead of two 8GiB DIMMs. Then the computer also starts fine after reboot.
Workaround 3: At every boot boot for a second with one DIMM. Turn off the computer, insert the second DIMM and start it again.
kmalkki told me to rebuid the image with DEBUG_RAM_SETUP=y
I then build a second image, with DEBUG_RAM_SETUP=y.
The logfile contains the first successfull boot (created with Workaround 3), the poweroff and the poweron with the bootloop. I have let it bootloop few times before turned off the PSU.
Files
coreboot_logfie.txt (197 KB) coreboot_logfie.txt gzz5f gzz5f, 06/05/2022 04:06 PM
coreboot_logfile_cleaned.txt (160 KB) coreboot_logfile_cleaned.txt stripped ANSI escapes Kyösti Mälkki, 06/05/2022 04:32 PM
KM Updated by Kyösti Mälkki over 4 years ago Actions #2
I think only 8 GiB of RAM was available at first boot.
One of the DIMMs has SPD CRC error, and while they have matching part number, timing parameters are different.
[DEBUG] SPD probe channel1, slot1
[DEBUG] ERROR: SPD CRC failed!!!
MR Updated by Martin Roth over 3 years ago Actions #3
No update since Kyösti pointed out the issue in the boot log to indicate that this is anything beyond incompatible dimms. Closing.
