Documentation #361
closed
AK PM
Feature #353: Release v1.3
Document realtek_mst_i2c_spi programmer
Documentation #361: Document realtek_mst_i2c_spi programmer
Added by Anastasia Klimchuk over 4 years ago. Updated about 4 years ago.
Resolved
Release prep
04/28/2022
100%
Man page entry done https://review.coreboot.org/c/flashrom/+/63103
We can also try to add more info for developers, see if code can be commented better?
Specific questions:
  1. No probing, starts by toggling a GPIO. Are GPIO settings board specific?
  2. Timeout checks seem to have regressed since original commit. Not documented?
  3. Changes clock settings, is this board specific?
  4. Implements spi_master with special cases in an opcode LUT, doesn't bail out on unknown codes.
  5. Falls back on unaligned reads/writes, were these paths tested?
  6. Fixups suggest that the original code wasn't properly tested, was it by now?
PM Updated by Peter Marheine over 4 years ago Actions #1
Probably not board-specific, because chip documentation describes that pin as the SPI write protect.
No, it's controlling on-chip clocks to improve programmer performance. I think they get reset on chip reset (exiting ISP mode).
Probably not; I've only ever used it for operating on big chunks of memory at a time.
It worked the last time I wanted to use it, but nothing uses this in production so it's not actively tested.
AK Updated by Anastasia Klimchuk over 4 years ago Actions #2
  • Assignee set to Peter Marheine
AK Updated by Anastasia Klimchuk over 4 years ago Actions #3
An item from discussion:
TODO: update the comment on realtek_mst_i2c_spi_toggle_gpio_88_strap
AK Updated by Anastasia Klimchuk over 4 years ago Actions #4
From the discussion: all open question resolved the last one left:
Test the programmer on the device and then we can close the ticket.
PM Updated by Peter Marheine over 4 years ago Actions #5
I tested read write and verify successfully on the current version, so all seems well.
FS Updated by Felix Singer about 4 years ago Actions #6
  • Status changed from Closed to Resolved
FS Updated by Felix Singer about 4 years ago Actions #7
AP Updated by Angel Pons about 4 years ago Actions #8
Hi, sorry for the late reply. Some thoughts on this:
Peter Marheine wrote in #note-1:
OK, if that pin is specifically meant to be used as SPI write protect, it should be safe. If we were to add any new options, a simple "use WP GPIO" option would do. Hard to say if it would be needed, though: Realtek design guides could state that everyone has to use the GPIO for WP, and their programs could make the same assumption.
Could higher clocks cause issues depending on board-specific things like routing? If so, making clock settings configurable would address the problem.
Would be good to test, if possible. Is there a way (for anyone inside/outside Google) to obtain/borrow one of these things for testing?
Hmmm, what do you mean with "nothing uses this in production"? Is it dead code, or is it only used in non-production (e.g. manufacturing) environments? It's probably the latter, but the original wording is very confusing...
