Support #356
closedFeature #353: Release v1.3
Add GD25Q256D from downstream
Ref commit https://github.com/flashrom/flashrom/commit/86fc9cf7ab221bc54ef6f10252e296fc2d7a22d2
Comments added after patch had been merged. Is there some work left to do for this? Needs investigation.
AK Updated by Anastasia Klimchuk over 4 years ago
E. Updated by Edward . over 4 years ago
According to the follow up comment post-merge:
"Are we sure about this? the datasheet explicitly mentions the sequence: CS# goes low -> sending Enter 4-Byte mode command -> CS# goes high."
Nikolai can you validate this commit with a datasheet please?
- Assignee set to Anastasia Klimchuk
NA Updated by Nikolai Artemiev over 4 years ago
IIUC, the comment is about whether enter 4BA command is permitted after a WREN command.
The "CS# goes low -> sending Enter 4-Byte mode command -> CS# goes high." part of the datasheet seems to just be describing the a minimal transaction for issuing an enter 4BA command, I don't think it's saying anything about whether it's permitted after a WREN or not.
We'd probably need to test, but flashrom isn't capable of that right now.
NH Updated by Nico Huber over 4 years ago
Nikolai Artemiev wrote in #note-4:
Actually, if it is only permitted after WREN. IOW, if WREN is needed.
Ack. I misread that. WREN would have its own CS#low/high sequence. Still if one looks at the WREN description, EN4B is not mentioned.
You can replace FEATURE_4BA_WREN with FEATURE_4BA_ENTER, if reading >16MiB works, WREN is not needed (requires a programmer that supports 4BA modes).
- Assignee changed from Anastasia Klimchuk to Nikolai Artemiev
FS Updated by Felix Singer almost 4 years ago
- Tracker changed from Feature to Support
- Target version changed from 1.3 to main
- Status changed from New to Feedback
AK Updated by Anastasia Klimchuk almost 4 years ago
- Status changed from Feedback to New
I have a question, I read the discussion and I am not entirely sure:
Does the chip work right now, with whatever definition is currently in?
Is this a ticket about a bug, or about an improvement of a chip definition?
- Description updated (diff)
LF Updated by Liam Flaherty almost 4 years ago
I have tested a GD25Q256D with it's current definition at head using a ft2232_spi programmer - the read, write, erase, and verify functions worked correctly.
- Category changed from Release prep to Flash chip
- Status changed from Feedback to In Progress
- Parent task deleted (
#353)
Given that chip works with its current definition, I am unlinking the ticket from 1.3.
However, the ticket stays open, since there is an open conversation in comments.
NA Updated by Nikolai Artemiev almost 4 years ago
I've tested and found WREN is not needed, so we should change the chip definition for 1.3.
Here is a patch to update the chip definition: https://review.coreboot.org/c/flashrom/+/70342
- Parent task set to #353
- Status changed from In Progress to Resolved
