Bug #343
closed
PM
Fails to load GRUB payload: CPU Index 0 - APIC 0 Unexpected Exception:6 @ 10:00009016 - Halting
Bug #343: Fails to load GRUB payload: CPU Index 0 - APIC 0 Unexpected Exception:6 @ 10:00009016 - Halting
Added by Paul Menzel over 4 years ago. Updated almost 4 years ago.
Resolved
03/30/2022
coreboot emulation/qemu-i440fx is unable to load GRUB payload. It works with SeaBIOS.
FMAP REGION: COREBOOT
Name                           Offset     Type           Size   Comp
cbfs master header             0x0        cbfs header        32 none
fallback/romstage              0x80       stage           21944 none
fallback/ramstage              0x56c0     stage           62048 LZMA (139536 decompressed)
config                         0x14980    raw               428 none
revision                       0x14b80    raw               716 none
build_info                     0x14e80    raw               112 none
fallback/dsdt.aml              0x14f40    raw              4044 none
cmos_layout.bin                0x15f40    cmos_layout       640 none
fallback/postcar               0x16200    stage           23328 none
fallback/payload               0x1bd80    simple elf     460906 none
(empty)                        0x8c640    null          3603556 none
bootblock                      0x3fc2c0   bootblock       15104 none
[NOTE ]  coreboot-4.16-415-ga84c00c9ce Wed Mar 30 01:18:14 UTC 2022 ramstage starting (log level: 7)...
[INFO ]  Timestamp - selfboot jump: 965162845
[EMERG]  CPU Index 0 - APIC 0 Unexpected Exception:6 @ 10:00009016 - Halting
[EMERG]  Code: 0 eflags: 00010002 cr2: 00000000
[EMERG]  eax: 00000000 ebx: 3ffbdc18 ecx: 0001ac27 edx: 000000ff
[EMERG]  edi: 3ffbdc00 esi: 3ffbdbf0 ebp: 000001e4 esp: 3ffc3fbc
[EMERG]  0x00008fd0:	00 00 00 00 00 00 00 00
[EMERG]  0x00008fd8:	00 00 00 00 00 00 00 00
[EMERG]  0x00008fe0:	00 00 00 00 00 00 00 00
[EMERG]  0x00008fe8:	00 00 00 00 00 00 00 00
[EMERG]  0x00008ff0:	00 00 00 00 00 00 00 00
[EMERG]  0x00008ff8:	00 00 00 00 00 00 00 00
[EMERG]  0x00009000:	52 52 68 27 ac 01 00 6a
[EMERG]  0x00009008:	0b e8 5e cd 00 00 83 c4
[EMERG]  0x00009010:	10 a0 00 00 00 00 0f 0b
[EMERG]  0x00009018:	51 51 68 6a a2 01 00 6a
[EMERG]  0x00009020:	0b e8 46 cd 00 00 83 c4
[EMERG]  0x00009028:	10 eb e6 90 bc f0 ff 07
[EMERG]  0x00009030:	00 e9 c7 d7 00 00 66 90
[EMERG]  0x00009038:	02 b0 ad 1b 02 00 00 00
[EMERG]  0x00009040:	fc 4f 52 e4 55 57 56 53
[EMERG]  0x00009048:	83 ec 1c 8b 5c 24 30 8b
[EMERG]  0x3ffc4038:	0x00000002
[EMERG]  0x3ffc4034:	0x00000003
[EMERG]  0x3ffc4030:	0x00000000
[EMERG]  0x3ffc402c:	0x00000000
[EMERG]  0x3ffc4028:	0x00000000
[EMERG]  0x3ffc4024:	0x00000000
[EMERG]  0x3ffc4020:	0x00000000
[EMERG]  0x3ffc401c:	0x00000000
[EMERG]  0x3ffc4018:	0x00000000
[EMERG]  0x3ffc4014:	0x00000000
[EMERG]  0x3ffc4010:	0x00000000
[EMERG]  0x3ffc400c:	0x00000000
[EMERG]  0x3ffc4008:	0x00000000
[EMERG]  0x3ffc4004:	0x00000000
[EMERG]  0x3ffc4000:	0x00000000
[EMERG]  0x3ffc3ffc:	0x00000000
[EMERG]  0x3ffc3ff8:	0x3ffbd4e8
[EMERG]  0x3ffc3ff4:	0xdeadbeef
[EMERG]  0x3ffc3ff0:	0xdeadbeef
[EMERG]  0x3ffc3fec:	0x3ff9e061
[EMERG]  0x3ffc3fe8:	0x3ffa1f19
[EMERG]  0x3ffc3fe4:	0x00018f20
[EMERG]  0x3ffc3fe0:	0x3ffdcfd4
[EMERG]  0x3ffc3fdc:	0x3ffc4000
[EMERG]  0x3ffc3fd8:	0x3ffd63ac
[EMERG]  0x3ffc3fd4:	0x00000000
[EMERG]  0x3ffc3fd0:	0x3ffa1fe5
[EMERG]  0x3ffc3fcc:	0x3ffa2139
[EMERG]  0x3ffc3fc8:	0x3ffbdc24
[EMERG]  0x3ffc3fc4:	0x3ffa4303
[EMERG]  0x3ffc3fc0:	0x3ff95000
[EMERG]  0x3ffc3fbc:	0x3ffac8e4 <-esp
Files
coreboot.log (17.2 KB) coreboot.log Serial console from QEMU Paul Menzel, 03/30/2022 10:57 AM
PM Updated by Paul Menzel over 4 years ago Actions #1
Sorry, forgot to attach the log.
AH Updated by Arthur Heymans over 4 years ago Actions #2
Bisected. 4ea7bae51f97e49c84dc67ea30b466ca8633b9f6 is the culprit in grub.
MN Updated by Michael Niewöhner over 4 years ago Actions #3
Confirmed here as well. Reverting that commit makes it work again.
Looks like others ran into this, too:
https://lists.yoctoproject.org/g/yocto/message/53322
https://git.yoctoproject.org/poky/commit/?h=hardknott&id=7ef7ee52476dc3c35c6f02cc7bc2a05df008b14d
https://savannah.gnu.org/bugs/index.php?60458
Setting CFLAGS+="-Os" instead of -O2 seems to resolve that problem, but feels like just a workaround
NH Updated by Nico Huber over 4 years ago Actions #4
MN Updated by Michael Niewöhner over 4 years ago Actions #5
Nico Huber wrote in #note-4:
I think this is related:
https://review.coreboot.org/c/coreboot/+/64235
Thanks for the hint. This fixes it
MR Updated by Martin Roth almost 4 years ago Actions #6
The patch https://review.coreboot.org/c/coreboot/+/64235 which was said to fix the issue was merged on 2022-11-02.
Please reopen if the issue is still seen.
