Bug #311
closedT410 PCIe Endpoints missing after flashing coreboot
After flashing coreboot on my Thinkpad T410, I realized the Mini PCIe Wifi card was no longer detected by my system. I have tried a second Intel Mini PCIe Wifi Card, I had lying around, but it was not recognized ether.
So I reflashed the original BIOS and checked lspci for devices (attached in PCIe_Bus/lenovo). The Wifi Card was found again. After comparing it to my lspci outputs with coreboot (PCIe_Bus/coreboot, it seems five devices (including the Bridge to Mini PCIe) are not detected with coreboot.
On the old coreboot documentation site, I found the result of lspci on the page of the T410 (https://www.coreboot.org/Board:lenovo/t410) and the Wifi Card is missing, too.
Do you have any idea, how to get the bridge to Mini PCIe working with coreboot, so I can use the Wifi Card? As far as I have understood, coreboot does not a full PCIe Enumeration. If so, can I force a full enumeration in coreboot or by changing a parameter in grub? Or is there already a workaround?
I have attached my coreboot configuration, too. I have used the ME_Cleaner to remove some parts of the Intel ME. I have tested it with Linux Mint and Fedora 34.
Files
PM Updated by Paul Menzel about 5 years ago
Thank you for taking the time to reporting this issue. Could you please try coreboot first without modifying the management engine?
AP Updated by Angel Pons about 5 years ago
- Category set to board support
- Assignee set to Angel Pons
Looks like the host bridge (00:00.0) PCI device ID is wrong. It's supposed to be 8086:0044, but is 8086:006a with coreboot. This usually happens because of me_cleaner usage. The system isn't expected to run in this state, and this can cause issues.
Still, the fix seems to be simple: https://review.coreboot.org/55169
LZ Updated by Lance Zhao about 5 years ago
Maybe there's some private programming needed in T410, either a GPIO pin to
turn on/off power rail or some special sequence needed other than generic
pcie enumeration.
coreboot@fe80.eu 于2021年6月3日周四 下午9:45写道:
Issue #311 has been reported by Johannes Roith.
Bug #311: T410 PCIe Endpoints missing after flashing coreboot
https://ticket.coreboot.org/issues/311
- Author: Johannes Roith
- Status: New
- Priority: Normal
- Assignee:
- Category:
- Target version:
PCIe Wifi Card, I had lying around, but it was not recognized ether.So I reflashed the original BIOS and checked lspci for devices (attached
(including the Bridge to Mini PCIe) are not detected with coreboot.On the old coreboot documentation site, I found the result of lspci on the
Wifi Card is missing, too.Do you have any idea, how to get the bridge to Mini PCIe working with
workaround?I have attached my coreboot configuration, too. I have used the ME_Cleaner
Fedora 34.---Files--------------------------------
T410.zip (6.05 KB)
.config (24.8 KB)--
You have received this notification because you have either subscribed to
it, or are involved in it.
To change your notification preferences, please click here:
https://ticket.coreboot.org/my/account
coreboot mailing list -- coreboot@coreboot.org
To unsubscribe send an email to coreboot-leave@coreboot.org
JR Updated by Johannes Roith about 5 years ago
Thank you all for your quick response.
I have tried Angel Pons' workaround to modify the device tree a little bit and recompiled the ROM with a cleaned Intel ME and now the Wifi Card is back there and ready for use!
Just for information I have attached some outputs of lspci with the coreboot build including the workaround.
From my side, we can close this bug, but maybe you want to wait, until the devicetree change is merged.
Thank you all once again and have a nice day,
Johannes
NH Updated by Nico Huber about 5 years ago
- Status changed from In Progress to Resolved
I've submitted the patches to master.
Johannes, if you can confirm that a build from master works unpatched now, you can close the ticket.
