Bug #22
closed
PR PR
X230 native raminit failed
Bug #22: X230 native raminit failed
Added by Patrick Rudolph almost 11 years ago. Updated almost 5 years ago.
Resolved
01/10/2016
Native raminit failed with: "edge write discovery failed".
It's failing on channel 1 with two DIMMs installed, while it has no problems booting with a single DIMM.
The test fails on lane 1.
These are the Cvals of channel 1:
Cval: 1, 1, 0, 26
Cval: 1, 1, 1, 21
Cval: 1, 1, 2, 41
Cval: 1, 1, 3, 4d
Cval: 1, 1, 4, 4e
Cval: 1, 1, 5, 52
Cval: 1, 1, 6, 2c
Cval: 1, 1, 7, 5e
Cval: 1, 0, 0, 22
Cval: 1, 0, 1, 5e
Cval: 1, 0, 2, 3b
Cval: 1, 0, 3, 4a
Cval: 1, 0, 4, 4a
Cval: 1, 0, 5, 4c
Cval: 1, 0, 6, 29
Cval: 1, 0, 7, 5b
Values for the same lane are about the same (+- 6units), but only lane 1
shows a huge offset of 61.
Files
x230_edge_write_discovery_failed.log (911 KB) x230_edge_write_discovery_failed.log Patrick Rudolph, 01/10/2016 02:02 PM
debugboot1.txt (61.7 KB) debugboot1.txt Martin Kepplinger, 07/05/2017 11:37 AM
PR Updated by Patrick Rudolph almost 11 years ago Actions #1
By adding a simple check to timB discovery:
 FOR_ALL_LANES {
               if (((ctrl->timings[channel][slotrank].lanes[lane].timB & 0x3f) == 0x3e) ||
                       ((ctrl->timings[channel][slotrank].lanes[lane].timB & 0x3f) == 0x3f))
               ctrl->timings[channel][slotrank].lanes[lane].timB += 2;
The issue is fixed for me.
This patch just covers the problem instead of fixing it.
PR Updated by Patrick Rudolph over 10 years ago Actions #2
Should be fixed in latest git.
Needs tests on x230.
AC Updated by Alexander Couzens over 10 years ago Actions #3
  • Status changed from Closed to Needs Testing
MK Updated by Martin Kepplinger over 9 years ago Actions #4
Native ram init should really work, as I'm using 2 DIMMs and at least with ram init I don't have a problem.
I append a cdbmem log, with ram debug enabled, in case that helps.
FL Updated by First name * Last name * over 8 years ago Actions #5
Works on my X230.
PR Updated by Patrick Rudolph over 7 years ago Actions #6
More raminit fixes landed in the meantime. Does it still happen?
MK Updated by Martin Kepplinger over 7 years ago Actions #7
Haven't had issues with raminit in a long time on the X230.
FS Updated by Felix Singer almost 5 years ago Actions #8
  • Status changed from Needs Testing to Resolved
