Bug #151
open
PM
KCMA-D8 (and presumably other amdfam10/amdmct-based boards) fails to boot
Bug #151: KCMA-D8 (and presumably other amdfam10/amdmct-based boards) fails to boot
Added by Patrick McDermott almost 9 years ago.
New
chipset configuration
12/31/2017
Current master fails to boot on a KCMA-D8 with one Opteron 4238 and one Micron MT36KSF2G72PZ-1G4E1 (16-GiB PC3-10600 1.35-V ECC RDIMM). coreboot just infinitely loops through MCT DIMM training, sometimes resetting.
I've bisected the failure to commit 4.5-1097-g610d1c6 (Revert "nb/amd/mct_ddr3: Fix RDIMM training failure on Fam15h"), hence my suspicion that the KGPE-D16 and possibly other boards with a similar CPU/RAM configuration may also fail to boot. Attached are logs of that commit and current master (both failing) as well as master with that commit reverted (which booted all the way to the payload on the second try).
This seems different from bug #129, given that the regressing commit predates the commit range listed there and the symptoms differ (#129 suggests bootblock breakage, which I haven't seen in my tests and bisecting).
Files
coreboot-4.5-1097-g610d1c6.cap (120 KB) coreboot-4.5-1097-g610d1c6.cap Log of commit 4.5-1097-g610d1c6 Patrick McDermott, 12/31/2017 05:07 AM
coreboot-4.6-2479-g8e4384d.cap (166 KB) coreboot-4.6-2479-g8e4384d.cap Log of commit 4.6-2479-g8e4384d (current master) Patrick McDermott, 12/31/2017 05:22 AM
coreboot-4.6-2480-g6cfa8e2.cap (137 KB) coreboot-4.6-2480-g6cfa8e2.cap Log of commit 4.6-2479-g8e4384d (current master) with 4.5-1097-g610d1c6 reverted Patrick McDermott, 12/31/2017 05:39 AM
No data to display
