Bug #97
closed
PM
PG
On QEMU coreboot with SeaBIOS with nvramcui does not work
Bug #97:
02/28/2017
SeaBIOS prints Run img/nvramcui and nothing else happens.
Please find the configuration and full log attached.
Files
SR Updated by Stefan Reinauer almost 9 years ago
- Assignee set to Patrick Georgi
HT Updated by HCL technologies almost 7 years ago
- File coreboot-debug-nvramcui.log.txt coreboot-debug-nvramcui.log.txt added
- File coreboot-nvramcui-config.txt coreboot-nvramcui-config.txt added
We are able to boot on qemu with some changes in attached config as a base.
Please find attached the modified config and debug log.
Take appropriate action on the issue status once verified at your end.
PG Updated by Patrick Georgi about 6 years ago
- Status changed from New to Closed
I just tried on latest master and can't reproduce the issue.
