Bug #83
open
AE TP
KGPE-D16 - Only one (or zero) out of two PCIe 10 Gigabit ethernet devices functional
Bug #83: KGPE-D16 - Only one (or zero) out of two PCIe 10 Gigabit ethernet devices functional
Added by Andrew Engelbrecht almost 10 years ago. Updated over 9 years ago.
New
11/18/2016
Hello,
For the KGPE-D16, only one or zero out of two StartTech ST20000SPEXI PCIe cards are functional under coreboot, depending on which slots are used. However both devices are listed by lspci.
Both appear functional under the proprietary BIOS: all ethernet links were listed by "ip link".
Revision of coreboot used: e39a8a9c092ed66686632d591ec84ed7a6165a50
Coreboot config attached (microcode and in-tree VGA were used).
Kernel version used: 4.2.0-42 (Trisquel 7.0)
Boot, dmesg, lspci, dmidecode and cbmem logs are attached.
In test 1 slots 3 and 4 were used and neither card was functional.
In test 2 slots 1 and 2 were used and one card was functional.
PCIe card: https://www.startech.com/Networking-IO/Adapter-Cards/2-port-pcie-10g-network-adapter~ST20000SPEXI
Thank you for your coreboot port. :)
Files
kgpe-d16-10gb-eth-test.tgz (167 KB) kgpe-d16-10gb-eth-test.tgz Andrew Engelbrecht, 11/18/2016 10:15 PM
NH Updated by Nico Huber over 9 years ago Actions #1
  • Assignee set to Timothy Pearson
AE Updated by Andrew Engelbrecht over 9 years ago Actions #2
Ruben got both cards to be recognized by using this kernel option:
pci=realloc=off
I believe this issue may be resolved. :)
AE Updated by Andrew Engelbrecht over 9 years ago Actions #3
Ruben points out that the issue may not be coreboot related.
