Feature #613
open
AK
Speed optimisation for spi_master_promontory and chips larger than 16M
Feature #613: Speed optimisation for spi_master_promontory and chips larger than 16M
Added by Anastasia Klimchuk about 1 year ago.
New
Programmer
10/15/2025
The initial implementation of speed optimization for promontory had a bug for chips larger than 16M size.
The bug was fixed under the ticket 370, there are more details in here: https://ticket.coreboot.org/issues/370
This leaves open the feature request for speed optimization for what's currently recognised as spi_master_promontory and chips >16M size.
For additional context, below is the attempt to gather the prior art unsubmitted patches which could be relevant to this feature. Note they are mostly few years old, however might be useful.
58776: sb600spi: Remove memory-mapped read workaround | https://review.coreboot.org/c/flashrom/+/58776
65853: [NOTFORMERGE]sb600spi.c: Speed up MMIO on the FIFO buffer | https://review.coreboot.org/c/flashrom/+/65853
65237: amd_spi.c: Everything after rev 0x4a is a SPI100 ctrl | https://review.coreboot.org/c/flashrom/+/65237
65238: amd_spi.c: Combine CHIPSET_YANGTZE and CHIPSET_PROMONTORY | https://review.coreboot.org/c/flashrom/+/65238
65239: amd_spi.c: Add memory map path | https://review.coreboot.org/c/flashrom/+/65239
No data to display
