Feature #587
closed
AK MD
Warnings about read-protected regions are shown for the area outside of what was requested with -i
Feature #587: Warnings about read-protected regions are shown for the area outside of what was requested with -i
Added by Anastasia Klimchuk over 1 year ago. Updated over 1 year ago.
Resolved
03/31/2025
With -i option, user can specify the regions they want to read.
flashrom reads whole flash and shows warnings for read-protected areas, even if those areas were not requested by -i
Example is with log attached, the command line is
flashrom -p internal -w <filename> --fmap -i EC -i COREBOOT -N >flashrom.log 2>&1
regions requested are EC and COREBOOT, in the logs there are 100+ warnings about "read_flash: cannot read inside Management Engine region" - but the user has not asked for ME region
The question is, should we show warnings for areas which are outside of what user requested?
Other notes:
  • warnings are not blocking, but there can be a lot of them
  • the option skip_unreadable_regions is not available from command line, but even if it would be available, this option impacts the reading from the whole flash regardless of what was requested by -i
This was raised from user experience of MrChromebox-flashrom, however this aspect seems the same for upstream too
Files
flashrom.log (11.7 KB) flashrom.log Anastasia Klimchuk, 03/31/2025 09:19 AM
AK Updated by Anastasia Klimchuk over 1 year ago Actions #1
  • Assignee changed from Anastasia Klimchuk to Matt DeVillier
