Bug #561
closed
PF PM
Install script can't find cmocka
Bug #561: Install script can't find cmocka
Added by Plaque FCC about 2 years ago. Updated about 2 years ago.
Resolved
09/13/2024
I run as instructed:
    meson setup builddir
    meson compile -C builddir
    meson test -C builddir
    meson install -C builddir
On the last command, after everything has been confiugred and built, and tested, it gets here and breaks:
Installing subprojects/cmocka-1.1.5/src/libcmocka.so.0.5.0 to /usr/local/lib/x86_64-linux-gnu
Installing symlink pointing to libcmocka.so.0.5.0 to /usr/local/lib/x86_64-linux-gnu/libcmocka.so.0
Installing symlink pointing to libcmocka.so.0 to /usr/local/lib/x86_64-linux-gnu/libcmocka.so
ERROR: File 'subprojects/cmocka-1.1.5/src/libcmocka.a' could not be found
What should I do about that?
AK Updated by Anastasia Klimchuk about 2 years ago Actions #1
  • Assignee set to Anastasia Klimchuk
AK Updated by Anastasia Klimchuk about 2 years ago Actions #2
  • Assignee changed from Anastasia Klimchuk to Peter Marheine
PM Updated by Peter Marheine about 2 years ago Actions #3
We probably shouldn't be trying to install the tests or related libraries at all, so need to look into how to tell meson not to install chosen things.
PM Updated by Peter Marheine about 2 years ago Actions #4
It seems like meson doesn't currently provide a good way to explicitly select install behavior for a subproject (which cmocka currently is, since we're using a wrap for it). From https://github.com/mesonbuild/meson/issues/10561, meson install --skip-subprojects is the intended way to do what we want.
AK Updated by Anastasia Klimchuk about 2 years ago Actions #5
I am wondering, would --skip-subprojects also skip what's in util directory, in particular util/ich_descriptors_tool ?
PM Updated by Peter Marheine about 2 years ago Actions #6
ich_descriptors_tool isn't a subproject (it doesn't use subproject() or a wrap file), so it would be unaffected.
However, I didn't like how --skip-subprojects needs to be specified on the command line (it adds burden to users), so I've opted to hack around the issue in https://review.coreboot.org/c/flashrom/+/84557 by modifying the cmocka wrap.
AK Updated by Anastasia Klimchuk about 2 years ago Actions #7
Plaque FCC, in case you want to try with the patch, the instructions how to download the patch are here: https://flashrom.org/dev_guide/development_guide.html#downloading-patch-from-gerrit
(you don't need to push it, you can just download)
PF Updated by Plaque FCC about 2 years ago ยท Edited Actions #8
$ git fetch https://review.coreboot.org/flashrom refs/changes/57/84557/3 && git checkout -b change-84557 FETCH_HEAD
  • branch refs/changes/57/84557/3 -> FETCH_HEAD
    Switched to a new branch 'change-84557'
$ rm -rf builddir; meson setup builddir && meson compile -C builddir && meson test -C builddir && sudo meson install -C builddir
Actually, after removing some garbage from the directory and rebuilding from scratch, everything is working fine now.
Thank you very much!
AK Updated by Anastasia Klimchuk about 2 years ago Actions #9
  • Status changed from In Progress to Resolved
Good to know it works now, thank you for reporting!
The patch is submitted, so I am closing the bug now.
