Bug #511
closed
ES
[STM/PE][BUG][SMMSTORE] Coreboot doesn't boot if SMMSTOREv2 driver Kconfig option is enabled when using STM (STM/PE)
Bug #511: [STM/PE][BUG][SMMSTORE] Coreboot doesn't boot if SMMSTOREv2 driver Kconfig option is enabled when using STM (STM/PE)
Added by Elias Souza about 3 years ago. Updated about 3 years ago.
Resolved
High
coreboot common code
10/09/2023
is necessary testing in newest hardwares include Haswell and Kaby Lake, but idk if affect other platforms different than Sandybridge
All
For some reason the SMMSTOREv2 looks to break SMMSTORE support in STM/PE during boot.
Coreboot: 4.21
HARDWARE: Gigabyte H61M-DS2 with Ivybridge processor
Payload: EDK2
SMMSTORE: SMMSTOREv2
A example with other guy using https://www.reddit.com/r/coreboot/comments/10rakni/comment/k444jz1/?context=3
  • According with the reddit user crazyfox-ua " The same for me on T440p & X230t (both with edk2) - just blank screen. Disabled STM brings both laptops back to life. CB logs says nothing strange IMO (last record is "[DEBUG] Jumping to boot code at ".
Is necessary to test if others payloads is affected by this bug
MD Updated by Matt DeVillier about 3 years ago Actions #1
was this combination previously working with the 4.20 tag?
ES Updated by Elias Souza about 3 years ago Actions #2
Matt DeVillier wrote in #note-1:
Sadly no, it's not working in the 4.20, the first try is from 8 months past and continues to can't boot, just work if SMMSTOREv2 driver is not enabled and just SMMSTOREv1 is used.
MD Updated by Matt DeVillier about 3 years ago Actions #3
Elias Souza wrote in #note-2:
have you tried just disabling SMMSTORE on the edk2 side? You can do that by removing the param passed to edk2 via the extra build params Kconfig.
Sounds like this will need to be debugged on a board with serial output to see what's breaking in edk2
ES Updated by Elias Souza about 3 years ago Actions #4
Matt DeVillier wrote in #note-3:
Oh thanks i will try to remove -DSMMSTORE from edk2 build and post the result here, the most problem are that i don't have a specific hardware debugger for UART debugging,
In my country this is so hard to find
PR Updated by Patrick Rudolph about 3 years ago Actions #5
Tested coreboot 17848b65c38c32fa9630925ca8a15203a0617788 with EDK2 92533b23fb93259b20661b6534109e9f59384e93 origin/uefipayload_202306 and SMMSTOREv2 works fine on Lenovo X220 (SandyBridge).
What's a STM/PE?
ES Updated by Elias Souza about 3 years ago Actions #6
Patrick Rudolph wrote in #note-5:
What's a STM/PE?
This Issue is about STM/PE a Supervisor/Hypervisor for SMM System Management Mode, if you can test too can be good too, please if are possible, just enable STM option in Menuconfig and enable STM/PE Hypervisor
ES Updated by Elias Souza about 3 years ago Actions #7
  • Subject changed from [STM/PE][BUG][SMMSTORE] Coreboot doesn't boot if SMMSTOREv2 driver Kconfig option is enabled to [STM/PE][BUG][SMMSTORE] Coreboot doesn't boot if SMMSTOREv2 driver Kconfig option is enabled when using STM (STM/PE)
PR Updated by Patrick Rudolph about 3 years ago Actions #8
The STM was never tested on production environments and might not work with other SMM "services" like SMMSTORE.
I would assume that you need to compile the SMMSTORE code into the stm.bin, however that's not the case right now.
EM Updated by Eugene Myers about 3 years ago Actions #9
In this instance, the STM is not active. The only thing coreboot does for the STM is setup some data structures and move the STM binary into the MSEG. The operating system has to start the STM. If coreboot is crashing when STM and SMMSTOREV2 are configured at the same time, this means that there is a collision in the TSEG layout. We need a coreboot trace to ferret this out.
EM Updated by Eugene Myers about 3 years ago Actions #10
See CB:78889 for a resolution for this issue.
MR Updated by Martin Roth about 3 years ago Actions #11
  • Status changed from Needs Testing to Resolved
