Feature #486
closed
AK PM
Support installing git hooks with meson
Feature #486: Support installing git hooks with meson
Added by Anastasia Klimchuk over 3 years ago. Updated over 3 years ago.
Resolved
Build system
04/30/2023
100%
In makefile, git hooks are installed by the gitconfig target:
gitconfig:
	./util/getrevision.sh -c 2>/dev/null && ./util/git-hooks/install.sh
Meson should also have an option to install git hooks.
PM Updated by Peter Marheine over 3 years ago Actions #1
The only reference to the gitconfig target I can find is in the development guidelines on the wiki, in the form of instructions to run make gitconfig to install git hooks.
Rather than attempting to write a meson rule to do the same thing, I think the docs should simply be updated to specify the commands directly; so tell the reader to run
instead of make.
AK Updated by Anastasia Klimchuk over 3 years ago Actions #2
./util/getrevision.sh is deteled in this patch:
https://review.coreboot.org/c/flashrom/+/72657
What would be the way to install git hooks without it?
Is that
git rev-parse 2>/dev/null && ./util/git-hooks/install.sh
as from the patch?
PM Updated by Peter Marheine over 3 years ago Actions #3
Just ./util/git-hooks/install.sh seems fine; I think the use of getrevision.sh is meant to verify that it's actually being run from inside a git repository, but that seems unnecessary if it's only being run interactively.
PM Updated by Peter Marheine over 3 years ago Actions #4
https://review.coreboot.org/c/flashrom/+/74924/ updates documentation (which I've move in-tree from the wiki) and deletes the make gitconfig target.
PM Updated by Peter Marheine over 3 years ago Actions #5
Moved things around a little; the wiki has been updated to say to run ./util/git-hooks/install.sh directly so we can land removal of the make target anytime now. Moving documentation in-tree from the wiki will be a longer process but this change doesn't depend on it.
AK Updated by Anastasia Klimchuk over 3 years ago Actions #6
