Bug #47
closed
KF
Wsxga+ screens display Grub incorrectly
Bug #47:
Closed
04/27/2016
Wsxga+ screens partition Grub output into a few sections, and one of the sections is blank; so it's hard to use the Grub commandline.
NH Updated by Nico Huber over 9 years ago
- Status changed from New to Response Needed
In case you are still interested... I guess you didn't get any response because nobody felt responsible and it's impossible to tell from your description who might know an answer (there are hundreds of different paths that could lead from coreboot to GRUB).
Which device do you use?
How do you initialize the display? native graphics init? Video BIOS?
Do you run it in textmode? or native resolution? or a vesa mode?
Is GRUB your payload. Or do you use SeaBIOS and let it load a GRUB from disk?
FS Updated by Felix Singer almost 5 years ago
- Status changed from Response Needed to Closed
Closed. No response since 5 years.
