Bug #466
closed
RS
Use printf instead of echo -n
Bug #466: Use printf instead of echo -n
Added by Ryan Schmidt over 3 years ago. Updated over 3 years ago.
Resolved
03/06/2023
Building flashrom on macOS, this is part of the output:
Building flashrom version v1.3.0
-n C compiler found:
Apple LLVM version 8.0.0 (clang-800.0.42.1)
This ("C compiler found:" being preceded by "-n" and followed by a newline) is happening because you are using echo -n which is not portable. Use printf instead. I refer you to cedb09de9d27d1608e02158c710dd6f2908c8ef1 where you've fixed this once before.
I attempted to follow your onerous contribution guidelines for submitting a patch and encountered errors I did not know how to correct; I won't be making any further attempts at that and hope the patch attached to this issue is sufficient.
Files
echo-n.patch (1.68 KB) echo-n.patch Ryan Schmidt, 03/06/2023 11:21 PM
AK Updated by Anastasia Klimchuk over 3 years ago Actions #2
AK Updated by Anastasia Klimchuk over 3 years ago Actions #3
  • Status changed from In Progress to Resolved
Ryan, thank you so much for reporting! Patch is merged, should be fixed in head, and will be included in 1.4.
On the separate note, I am sorry that you found contribution guidelines onerous. You are not wrong.
We are currently in the middle of an effort to re-write dev guidelines to be more clear, readable and modern. Hopefully new guidelines are better and maybe next time you will send a patch to us!
