Bug #42
closed
RR
Commit 53c388fe6dfb4fc4ffcee6c58345d353c6ec33bf breaks coreboot for alix2d13
Bug #42: Commit 53c388fe6dfb4fc4ffcee6c58345d353c6ec33bf breaks coreboot for alix2d13
Added by Reto Rayen over 10 years ago. Updated about 10 years ago.
Closed
build system
04/13/2016
100%
Device Name: Alix 2d13
Build Options: As txt attachment
Coreboot revision: 53c388fe6dfb4fc4ffcee6c58345d353c6ec33bf
The commit 53c388fe6dfb4fc4ffcee6c58345d353c6ec33bf breaks to build a working coreboot rom for a "Pc Engines Alix2d13"
A history about the single builds can be found here: https://file.youngsolutions.ch/index.php/s/g2cixjqepvTwJhR
Thank you in advance guys
Files
MR Updated by Martin Roth over 10 years ago Actions #1
This builds for me under origin/master from coreboot.org, using the following miniconfig, so I'm still not sure what the issue is.
This miniconfig was generated by saving the coreboot_build_options_for_alix2d3.txt to .config then running 'make savedefconfig'. I then removed CONFIG_PXE_*= and CONFIG_ANY_TOOLCHAIN=y
To turn this back into a full config, save it as .config, then run 'make olddefconfig'
CONFIG_LOCALVERSION="4.3"
# CONFIG_COMPRESS_RAMSTAGE is not set
CONFIG_FLASHMAP_OFFSET=0x400000
CONFIG_VENDOR_PCENGINES=y
CONFIG_BOARD_PCENGINES_ALIX2D=y
CONFIG_CONSOLE_SERIAL_38400=y
Reto, could you please describe a little more about the failure you're seeing.
  • If it's a build failure, please attach build logs of the output of 'make V=1'. Also, please make sure that CONFIG_ANY_TOOLCHAIN is disabled.
  • If it's a boot failure, please attach the boot log.
MR Updated by Martin Roth over 10 years ago Actions #2
It was just pointed out to me that this is probably the same issue as bug #41.
https://ticket.coreboot.org/issues/41
That seems right - I'll work on a fix for 41, and re-address this issue if that fix doesn't work.
RR Updated by Reto Rayen over 10 years ago Actions #3
Hi Martin
the first two patches didn't worked.
RR Updated by Reto Rayen over 10 years ago Actions #4
Hi Martin
sorry it was just the first one. I saw now. That my git reset to the second was not successfull. It cannot switch to the second and third patch. Looks like they are not commited yet.
RR Updated by Reto Rayen over 10 years ago Actions #5
MR Updated by Martin Roth over 10 years ago Actions #6
This should be fixed at this point.
Reto, could you retest with the latest origin/master?
Thanks.
RR Updated by Reto Rayen over 10 years ago Actions #7
Hi Martin
you all, are awesome. It's working again. Thank you for your help. I did used the same config file, including the vsa image and it works like a charm. I'll try now to bring the ipxe payload into the coreboot, as describer here: https://pelican.craoc.fr/coreboot.html#ipxe. But you can close this ticket now.
Thank you very much for your help.
I created the coreboot rom with the following commit: f4609f9abf23bb48963ee173d2e54e5e71e6b64d.
KM Updated by Kyösti Mälkki about 10 years ago Actions #8
