Bug #41
closed[Geode][LX] Zero-address accesses results in UD2
The following source files deliberately access addresses near zero.
In src/northbridge/amd/lx/northbridgeinit.c:
/* Now that the descriptor to memory is set up. */
/* The memory controller needs one read to synch its lines before it can be used. */
i = *(volatile int *)0;
In src/northbridge/amd/lx/raminit.c (sdram_enable):
/* The RAM dll needs a write to lock on so generate a few dummy writes */
/* Note: The descriptor needs to be enabled to point at memory */
volatile unsigned long *ptr;
for (i = 0; i < 5; i++) {
ptr = (void *)i;
*ptr = (unsigned long)i;
Recent versions of gcc, including the coreboot-provided crossgcc, do not generate the intended code. Look at the disassembly of sdram_enable, for instance:
00000000 <sdram_enable>:
0: 55 push %ebp
1: 57 push %edi
(...snip...)
14b: 6a 7e push $0x7e
14d: e8 fc ff ff ff call 14e <sdram_enable+0x14e>
14e: R_386_PC32 post_code
152: c7 05 00 00 00 00 00 movl $0x0,0x0
159: 00 00 00
15c: 0f 0b ud2
All the code after the first zero-address access is replaced by ud2. Needless to say, the machine crashes on boot. With the patch below coreboot boots properly:
diff --git a/src/northbridge/amd/lx/northbridgeinit.c b/src/northbridge/amd/lx/northbridgeinit.c
index a07a1ea..37bfde6 100644
--- a/src/northbridge/amd/lx/northbridgeinit.c
+++ b/src/northbridge/amd/lx/northbridgeinit.c
@@ -738,7 +738,7 @@ void northbridge_init_early(void)
- i = *(volatile int *)0;
+ __asm__ __volatile__ ("cmp (%0), %0" : : "r" (0) : "memory", "cc");
GeodeLinkPriority();
diff --git a/src/northbridge/amd/lx/raminit.c b/src/northbridge/amd/lx/raminit.c
index f20aed2..363b0ff 100644
--- a/src/northbridge/amd/lx/raminit.c
+++ b/src/northbridge/amd/lx/raminit.c
@@ -747,11 +747,17 @@ void sdram_enable(int controllers, const struct mem_controller *ctrl)
+#if 0
ptr = (void *)i;
+#else
+ for (i = 0; i < 5; i++) {
+ __asm__ __volatile__ ("mov %0, (%0)" : : "r" (4 * i) : "memory");
+#endif
/* SWAPSiF for PBZ 4112 (Errata 34) */
/* check for failed DLL settings now that we have done a memory write. */
msrnum = GLCP_DELAY_CONTROLS;
MR Updated by Martin Roth over 10 years ago
It looks like we missed these when we introduced zeroptr. Look at commits 23cc9b09 and ff8076d7.
It doesn't really look like we need to read from address 0 for either of these though. I'd try just changing them to read starting at address 1 instead of using asm to force the read at 0.
PG Updated by Patrick Georgi over 10 years ago
https://review.coreboot.org/14345 plus ancestors should fix this.
Achille, We believe this should be fixed at this point. Could you verify that?
Thanks.
AF Updated by Achille Fouilleul over 10 years ago
I checked out commit 3383a25f91fab26ce20f40f9981eeee5b2ba9eb0 a few days ago.
I had a chance to test it today and it worked fine.
Btw I think I have spotted another place where a zero address is accessed:
src/device/oprom/realmode/x86.c: setup_realmode_idt
For some reason gcc 5.3 does not generate an ud2 but some future version might.
MR Updated by Martin Roth about 10 years ago
- Status changed from New to Closed
closing as fixed.
