Refactoring #380
closed
E. AK
Feature #353: Release v1.3
tests/lifecycle.c: Split up into compilation units
Refactoring #380: tests/lifecycle.c: Split up into compilation units
Added by Edward . over 4 years ago. Updated about 4 years ago.
Resolved
Build system
05/13/2022
100%
As remarked in https://review.coreboot.org/c/flashrom/+/64224
We could get rid of the pre-processor conditionals by splitting up the file into per-driver compilation units and using a weak symbol entry point then letting the linker do the rest for us.
Related links
Feel free to rebase https://review.coreboot.org/c/flashrom/+/62777 and drive it forwards.
Related issues 1 (1 open — 0 closed)
Related to flashrom - Refactoring #428: Replace pre-processor ifdefs with weak functionsNew10/15/2022
AK Updated by Anastasia Klimchuk over 4 years ago Actions #1
  • Assignee set to Anastasia Klimchuk
AK Updated by Anastasia Klimchuk over 4 years ago Actions #2
  • Tracker changed from Cleanup to Feature
  • Category set to Build system
  • Target version changed from none to 1.3
  • Parent task set to #353
E. Updated by Edward . over 4 years ago Actions #3
  • Related links updated (diff)
AK Updated by Anastasia Klimchuk about 4 years ago Actions #4
  • % Done changed from 0 to 60
Current status: lifecycle.c is split into per-programmer files. So one large lifecycle.c does not exist anymore, there is an individual file for each programmer.
What is left: "get rid of the pre-processor conditionals" but this will be done after meson upgrade is merged https://review.coreboot.org/c/flashrom/+/63724
FS Updated by Felix Singer about 4 years ago Actions #5
  • Tracker changed from Feature to Refactoring
  • Target version changed from 1.3 to main
AK Updated by Anastasia Klimchuk about 4 years ago Actions #6
We just had an in-depth discussion on the topic of #ifdef vs weak symbols in unit tests and decided to keep #ifdef for now.
Reasons (from meeting notes):
  1. Weak symbols makes code less obvious: harder to understand what is going on
  2. Flashrom (non-test code) does not use weak symbols, maybe tests should not either? We should use the same concept in flashrom and test code. We can switch both to weak symbols, or none.
  3. Let’s think about it later?
  4. Not blocking release.
  5. Ideally we won’t be touching ifdefs until we drop make
Closing this ticket, but we may return back to the question of weak symbols after the release.
AK Updated by Anastasia Klimchuk about 4 years ago Actions #7
  • Status changed from In Progress to Resolved
  • % Done changed from 60 to 100
FS Updated by Felix Singer about 4 years ago Actions #8
  • Related to Refactoring #428: Replace pre-processor ifdefs with weak functions added
