Feature #372
closed
AK AK
Feature #353: Release v1.3
Support code for per-region file arguments
Feature #372: Support code for per-region file arguments
Added by Anastasia Klimchuk over 4 years ago. Updated almost 4 years ago.
Resolved
Release prep
04/28/2022
100%
Check whether everything is fine, fix issues of any.
E. Updated by Edward . over 4 years ago Actions #1
  • Assignee set to David Hendricks
NH Updated by Nico Huber over 4 years ago Actions #2
Had a superficial look:
  • manpage: --include vs. --image
  • register_include_arg(): Missing return-value checks for strdup()?
Could use more eyes.
It seems to work generally, just tested it with dummyflasher.
AK Updated by Anastasia Klimchuk almost 4 years ago Actions #3
After looking closer at "include vs image" we have discovered:
i
The patch 23021 changed --image option into --include option, changed the handling code and manpage. --image gone, there is --include instead.
The code and manpage are handling "-i" as "--include" and manpage describes "include" as alias for "-i". So the code processing the argument and manpage are consistent with each other.
However, help message that is printed from cli_classic still mentions "image", and does not mention "include" (see cli_classic_usage()).
Also in cli_classic, an array long_options[] still mentions "image" and does not mention "include".
Summarising, what to do:
  1. update the help message printed from command line, see cli_classic_usage() in cli_classic
  2. update long_options[] in cli_classic.
AK Updated by Anastasia Klimchuk almost 4 years ago Actions #5
  • % Done changed from 0 to 50
AK Updated by Anastasia Klimchuk almost 4 years ago Actions #6
  • Assignee changed from David Hendricks to Anastasia Klimchuk
  • % Done changed from 50 to 100
