Bug #335
closed
XW
High prority bug causes bricking when tianocore and flash log console used together
Bug #335: High prority bug causes bricking when tianocore and flash log console used together
Added by xinhua wang almost 5 years ago. Updated almost 4 years ago.
Closed
01/04/2022
With tianocore payload. spi flash console was working here is my log of where it hang
BS: BS_DEV_INIT run times (exec / console): 209 / 87 ms
FMAP: area SMMSTORE found @ 690000 (262144 bytes)
smm store: 4 # blocks with size 0x10000
SMMSTORE: Setting up SMI handler
BS: BS_DEV_INIT exit times (exec / console): 0 / 1 ms
Finalize devices...
PCI: 00:1f.0 final
apm_control: Finalizing SMM.
ΓΏ (then all yyyy) any ideas? Thx
Maybe block spi flash console from being used when payload is tianocore before its resolved? It causes bricking of system for those who dont have ch341/soic clip/in circuit flashing/bios header to recover easily
XW Updated by xinhua wang almost 5 years ago Actions #1
Board is aspire xc600
PM Updated by Paul Menzel almost 5 years ago Actions #2
  1. Just to avoid misunderstandings, if you use the SeaBIOS, it works?
  2. Where is the source for the aspire xc600?
  3. Please attach all the logs nevertheless (for working and non-working situations).
NH Updated by Nico Huber almost 5 years ago Actions #3
May I ask what is your use case? The SPI flash console is explicitly meant for the case that you use an external flash setup (see Kconfig help text). It's only meant for debugging during early development, not for users. The payload shouldn't matter because it's usually used when the system isn't booting. If it's booting, there is the CBMEM console.
MR Updated by Martin Roth almost 4 years ago Actions #4
No response to comments asking for clarification in over a year. Closing.
