Bug #310
closed
DH AP
Coreboot 4.14 fails on a Lenvovo T440p
Bug #310: Coreboot 4.14 fails on a Lenvovo T440p
Added by David Hoelscher over 5 years ago. Updated about 4 years ago.
Resolved
06/02/2021
100%
ThinkPad T440p
All (coreboot bug)
Hi all,
coreboot 4.14 dies on early boot. The T440p ended with led blinking and beep sound.
This was my first try - so i think it was maybe a problem with mrc.bin or vga.rom. But if I skip back to version 4.13, everything works fine (4.13 working config is appended). I don't know how to get debug information on this early stage of boot. Does anyone has a hint? A Raspberry Pi as an external flasher is available.
Further - is it possible to flash only the 4 MB BIOS chip? This IC is very easy accessible. I am afraid to disassemble the complete backplate to access the other 8MB chip again. Initially I flashed the complete Rom without ME on both chips.
Files
Coreboot_4.13.config (23.6 KB) Coreboot_4.13.config Coreboot 4.13 Working config David Hoelscher, 06/02/2021 07:53 PM
descriptor.bin (4 KB) descriptor.bin BIOS Descriptor.bin David Hoelscher, 06/02/2021 08:07 PM
Updated by Anonymous over 5 years ago Actions #1
I flashed each T440p-related commit made after the 4.13 release until I found the one that no longer boots. This appears to be the breaking change:
https://review.coreboot.org/plugins/gitiles/coreboot/+/ae999503f62ef8a3b9b2756a2810d29c383a009e
I tried reverting the changes made in this commit (PEG_CAP,PEG_DCAP,etc) and was then able to build from master/4.14 and get a bootable, working 4.14 ROM for the T440p. FWIW my T440p doesn't have a dGPU.
Side note: Flashing only the 4MB chip seems to work (for me, anyway) to get the system booting again.
AP Updated by Angel Pons over 5 years ago Actions #2
A coreboot log would tell what exactly is going on. You can use flashconsole (CONSOLE_SPI_FLASH Kconfig option) to retrieve one. I think I know what's going on, though: the straps on the mainboard enable PEG x8/x8 bifurcation, which means there's a PCI device at 00:01.0 (Bus:Dev.Func) where the dGPU would be connected to, and another unused PCI device at 00:01.1 which is not present in the devicetree. The config_of() function call added in that commit makes coreboot die when it runs for PCI device 00:01.1 because the device node isn't linked to any chip.
AP Updated by Angel Pons over 5 years ago Actions #3
  • Status changed from New to Response Needed
  • Assignee set to Angel Pons
https://review.coreboot.org/q/topic:%22haswell-peg-woes%22 should fix booting on T440p. The three T440p changes alone should be enough to fix booting, but the other three address issues in northbridge code, including the one that led to the breakage.
Updated by Anonymous over 5 years ago Actions #4
I can confirm adding device pci 01.1 off end # Unused PCIe Bridge to devicetree.cb resolves the issue for me. I can now build (and boot!) master. Thanks so much Angel!
DH Updated by David Hoelscher over 5 years ago Actions #5
Yes, I also can confirm that your patches resolve this issue. Thank you very much!
DK Updated by Daniel Kulesz about 5 years ago Actions #6
I can confirm this issue and I can confirm as well that current master works (opposed to 4.14).
AP Updated by Angel Pons about 4 years ago Actions #7
  • Status changed from Response Needed to Resolved
  • Affected hardware set to ThinkPad T440p
  • Affected OS set to All (coreboot bug)
