Bug #27
closed
PG
Windows doesn't like references in ACPI to objects that are only defined later
Bug #27: Windows doesn't like references in ACPI to objects that are only defined later
Added by Patrick Georgi almost 11 years ago. Updated almost 4 years ago.
Closed
01/29/2016
There is some concern about Windows not liking ASL structured like in https://review.coreboot.org/#/c/13506/ because NVSA is defined "after" the OpRegion that uses it.
Needs testing and potentially a tree-wide solution
TP Updated by Timothy Pearson almost 11 years ago Actions #1
Out of curiosity, what does "Not like" mean here? Hang or BSOD?
MR Updated by Martin Roth almost 11 years ago Actions #2
It gives a BSOD. I don't recall the values. I'll see if I can get that information and update the bug.
MR Updated by Martin Roth almost 4 years ago Actions #3
Marking as closed due to the last update being 7 years old. Please reopen if we have a new update.
