Feature #210
open
PG PG
Improve board-status
Feature #210: Improve board-status
Added by Patrick Georgi over 7 years ago. Updated over 7 years ago.
New
infrastructure
It's tedious to use, it has various short-comings, it doesn't store enough signal, it requires stuff that shouldn't be required (e.g. downloading big git repos), it requires a build tree that matches the target.
Work out what we want it to be and get there.
Related issues 6 (6 open — 0 closed)
Blocked by coreboot - Feature #198: board_status replacementNew02/14/2019
Blocked by coreboot - Bug #49: board_status.sh does not check git identityNew04/30/2016
Blocked by coreboot - Feature #28: board-status should reject duplicate uploadsNew02/03/2016
Blocked by coreboot - Bug #30: board-status allows invalid uploadsNew02/04/2016
Blocked by coreboot - Feature #29: board-status should reject uploads with incorrect DMI stringNew02/03/2016
Blocked by coreboot - Bug #15: board-status uploads incorrect reports if config not foundIn ProgressPatrick Georgi12/01/201512/02/2015
PG Updated by Patrick Georgi over 7 years ago Actions #1
  • Category set to infrastructure
PG Updated by Patrick Georgi over 6 years ago Actions #2
PG Updated by Patrick Georgi over 6 years ago Actions #3
  • Blocked by Bug #49: board_status.sh does not check git identity added
PG Updated by Patrick Georgi over 6 years ago Actions #4
  • Blocked by Feature #28: board-status should reject duplicate uploads added
PG Updated by Patrick Georgi over 6 years ago Actions #5
  • Blocked by Bug #30: board-status allows invalid uploads added
PG Updated by Patrick Georgi over 6 years ago Actions #6
  • Blocked by Feature #29: board-status should reject uploads with incorrect DMI string added
PG Updated by Patrick Georgi over 6 years ago Actions #7
  • Blocked by Bug #15: board-status uploads incorrect reports if config not found added
