Bug #145
closed
PM PG
Building vboot or its components on non-x86 fails
Bug #145: Building vboot or its components on non-x86 fails
Added by Paul Menzel almost 9 years ago. Updated over 6 years ago.
Resolved
build system
10/23/2017
Building the board Google Elm on a ppc64le system fails with the error below. coreboot toolchain 1.50 from October 15th, 2017 is used.
    CC            gen/futility_cmds.o
make[1]: *** No rule to make target '/dev/shm/coreboot/build/util/futility/build/host/arch/ppc64le/lib/crossystem_arch.o', needed by '/dev/shm/coreboot/build/util/futility/build/libvboot_util.a'.  Stop.
util/futility/Makefile.inc:4: recipe for target 'build/util/futility/build/futility/futility' failed
make: *** [build/util/futility/build/futility/futility] Error 2
The problem is that ppc64le is not listed in 3rdparty/vboot/Makefile.
Related issues 1 (0 open — 1 closed)
Has duplicate coreboot - Bug #263: coreboot build failure on ARM device (due to vboot)ClosedPatrick Georgi06/18/2020
MR Updated by Martin Roth almost 9 years ago Actions #1
  • Assignee changed from Martin Roth to Stefan Reinauer
PG Updated by Patrick Georgi over 6 years ago Actions #2
  • Has duplicate Bug #263: coreboot build failure on ARM device (due to vboot) added
PG Updated by Patrick Georgi over 6 years ago Actions #3
  • Subject changed from Cross-building *futility* on ppc64le fails to Building vboot or its components on non-x86 fails
  • Category set to build system
  • Assignee changed from Stefan Reinauer to Patrick Georgi
Similar issues also pop up when building on ARM, but it's all the same root cause. Will dig into it.
PG Updated by Patrick Georgi over 6 years ago Actions #4
