Bug #107
closed
DK
X60 / Regression: Trackpoints is broken on current master
Bug #107: X60 / Regression: Trackpoints is broken on current master
Added by Daniel Kulesz over 9 years ago. Updated over 9 years ago.
Closed
04/14/2017
It was working in Coreboot 4.5 - please find the logs attached.
Files
cbfs.txt (1020 Bytes) cbfs.txt Daniel Kulesz, 04/14/2017 01:05 PM
config.short.txt (444 Bytes) config.short.txt Daniel Kulesz, 04/14/2017 01:05 PM
coreboot_console.txt (36 Bytes) coreboot_console.txt Daniel Kulesz, 04/14/2017 01:05 PM
config.txt (18.8 KB) config.txt Daniel Kulesz, 04/14/2017 01:05 PM
coreboot_timestamps.txt (39 Bytes) coreboot_timestamps.txt Daniel Kulesz, 04/14/2017 01:05 PM
payload_config.txt (1.59 KB) payload_config.txt Daniel Kulesz, 04/14/2017 01:05 PM
kernel_log.txt (61.1 KB) kernel_log.txt Daniel Kulesz, 04/14/2017 01:05 PM
revision.txt (173 Bytes) revision.txt Daniel Kulesz, 04/14/2017 01:05 PM
rom_checksum.txt (53 Bytes) rom_checksum.txt Daniel Kulesz, 04/14/2017 01:05 PM
AH Updated by Arthur Heymans over 9 years ago Actions #1
Enabling trackpoint is an RTC cmos option. Some things were moved in the layout of the nvram which can cause this. Using nvramtool you can enable it again.
This was announced on mailing list with some instructions: https://mail.coreboot.org/pipermail/coreboot/2017-January/082945.html
DK Updated by Daniel Kulesz over 9 years ago Actions #2
I must have overlooked this announcement. Enabling the trackpoint via nvramtool did the trick - many thanks!
AC Updated by Alexander Couzens over 9 years ago Actions #3
