Bug #81
closed
PS PS
Unable to build coreboot with any payload other than SeaBIOS
Bug #81: Unable to build coreboot with any payload other than SeaBIOS
Added by Philipp Stanner over 9 years ago. Updated over 6 years ago.
Closed
Documentation
10/22/2016
Hi.
After compiling (worked) I can successfully build a coreboot.rom for qemu (x86 i440fx) - as long as I use the standard-payload.
Any other payload (Grub, filo, linux kernel, u-boat etc.) results in a demolition.
I proceeded as descripted in https://www.coreboot.org/Lesson1, one time with, one time without building the payload manually.
Files
errors-filo (14 KB) errors-filo Philipp Stanner, 10/22/2016 10:44 AM
errors-grub (12.1 KB) errors-grub Philipp Stanner, 10/22/2016 10:44 AM
DK Updated by Daniel Kulesz over 9 years ago Actions #1
I just tried this on Debian Jessie and everything worked fine with filo for me. However, I had to install the package
dh-autoreconf
before compiling.
HT Updated by HCL technologies over 6 years ago Actions #2
As this issue is submitted almost 3 years ago, but status is still "New" and it is now no longer valid, hence can be closed.
Please change status for this issue as "Closed".
PM Updated by Paul Menzel over 6 years ago Actions #3
  • Category set to Documentation
In contrast to the other payloads, SeaBIOS does not use Autotools.
The GRUB build failed with the error below.
./autogen.sh: line 86: autoreconf: command not found
So not all required packages were installed, which is a user error. In Debian that program is in the package autoconf. You probably should install build-essential.
Philipp, it’d be great if you updated the coreboot documentation. I’ll close the report nevertheless.
