Bug #80
openScreen garbled in Seabios, does not boot, Kernel panic (X60)
I tried updating from Coreboot-4.4 to current HEAD on my Thinkpad X60. The build went fine, but afterwards:
- screen was partly disorted / garbled (big green artifacts in the bottom part)
- first attempt to boot resulted in kernel panic
- could get machine to boot only after rebooting and then it booted normally
Downgraded now to 4.4, and things are working okay again.
Files
DK Updated by Daniel Kulesz about 10 years ago
I had the same issue with the official 4.5 release. Then I switched off the following option:
Display => Keep VESA framebuffer
Since then, everything is back to normal. However, in 4.4 it used to work with the option enabled (just double-checked), so I would consider this a regression.
AH Updated by Arthur Heymans about 10 years ago
Could you see if commit 9c5fc62f9 "nb/i945/gma.c: use IS_ENABLED instead of #if, #endif" was in your git tree that you flashed? This breaks native graphic init, but is fixed in https://review.coreboot.org/#/c/17075/ .
DK Updated by Daniel Kulesz almost 10 years ago
Sorry, didn't see your comment. Since the commit is merged, I will try with the current master and report back.
- File IMG_20161118_161249.jpg IMG_20161118_161249.jpg added
I retried in master as of cd2afc0df034670a83479aded514b22b99124cf5. Here is what changed:
- again, first attempt to boot after flashing resulted in kernel panic (blinking scroll lock led)
- the issue that the device does not boot up at the first time got better. Lockup during boot happens only occasionally but is not easily reproducible.
- however, the device sometimes does not init correctly (empty screen, backlight on)
- when using the "Keep VESA framebuffer" option, the screen is still garbled during bootup, and also when booting into text-based Payloads such as meminfo or memtest86+. Memtest86+ itself does not report any memory issues (when running coreboot without the VESA option since no output is visible when activated).
I am attaching pictures for some of the symptoms.
- File IMG_20161118_132934.jpg IMG_20161118_132934.jpg added
- File IMG_20161118_142310.jpg IMG_20161118_142310.jpg added
- File IMG_20161118_161220.jpg IMG_20161118_161220.jpg added
Btw.: It's a X60s, not a regular X60.
AH Updated by Arthur Heymans almost 10 years ago
I don't seem to have these issues on my x60. Linux can be unhappy if gpu was not initiated properly.
Could you include a cblog?
Would also be nice if you could bisect this issue, if you say this is a regression.
DK Updated by Daniel Kulesz over 9 years ago
I tried on current master, and there the issue is still present. I am trying to recover from this issue - until then, I will not be able to provide cblog.
- File cbfs.txt cbfs.txt added
- File config.short.txt config.short.txt added
- File config.txt config.txt added
- File coreboot_console.txt coreboot_console.txt added
- File coreboot_timestamps.txt coreboot_timestamps.txt added
- File kernel_log.txt kernel_log.txt added
- File payload_config.txt payload_config.txt added
- File revision.txt revision.txt added
- File rom_checksum.txt rom_checksum.txt added
Here are the logs.
One more thing I noticed in the VESA "broken" Mode:
If I hit "Esc" in Seabios after cold boot and choose the boot device, the system will always hang. If I do not hit Esc but let it continue booting, the Linux kernel will succeed in initializing the graphics most of the time. Some timing issue?
