Bug #72
open
Provide better a error message when trying to use missing blobs in a non-git tree
Added by Patrick Georgi over 9 years ago. Updated over 9 years ago.
New
09/17/2016
When building a blobby board using the release tarballs (but missing the blob files), we simply fail out with something like "make: *** No rule to make target '3rdparty/blobs/cpu/intel/model_1067x/microcode.bin' ..."
We should provide a proper error message for USE_BLOBS=y and missing blobs.
Actions #1
Updated by Martin Roth over 9 years ago
What about adding an integer "REQUIRES_BLOBS" kconfig option that can be set in chipsets or boards that have blobby requirements.
0 = No blobs required
1 = Builds with no blobs, but requires blobs that are not in the blob repo to boot
2 = Requires blobs in the blobs repo to build
This can help us do a few things:
A) We can add text saying "Now BLOB Free!" to blobless boards when they boot
B) We can easily identify all of the blob-free boards in abuild, and publish those binaries if desired.
D) We can easily error out if the the board requires blobs but is being built without the blobs repo.
Also available in: Atom PDF
