Bug #668
openmb/asus/p8x7x-series abuild broken
abuild for this family of boards breaks if CONFIG_BOOTBLOCK_CONSOLE is disabled.
The error is:
/usr/src/coreboot/util/crossgcc/xgcc/bin/i386-elf-ld.bfd: coreboot-builds/ASUS_P8Z77_V_LE_PLUS/bootblock/superio/nuvoton/common/early_serial.o: in function `nuvoton_enable_serial':
/usr/src/coreboot/src/superio/nuvoton/common/early_serial.c:17:(.text.nuvoton_enable_serial+0xf): undefined reference to `console_serial_enabled'
It looks like a link time error, because console/serial_console.c is not being compiled into bootblock in this case. This unit is a new addition of commit 605cba2fd137 ("console: allow enabling serial console at runtime").
To reproduce, from root of coreboot source tree:
- Create a text file
nobootconsolewith this content:
CONFIG_BOOTBLOCK_CONSOLE=n
- Run
util/abuild/abuild -p none -c 8 -t asus/p8x7x-series -S -K nobootconsole
This error isn't immediately obvious because CONFIG_BOOTBLOCK_CONSOLE defaults to enabled (for good reasons), but it is a user Kconfig option so none can guarantee it's always enabled.
Whether CONFIG_SEPARATE_ROMSTAGE is chosen or not does not seem to matter. Build still fails.
I should check with Matt before I start working around this by deferring nuvoton_enable_serial() to romstage at mainboard level, as my workaround plan can be tricky as I need to find a romstage hook before console init to make this call in.
Ideally, if a board has serial console support and bootblock console is disabled, no serial and console init should happen in bootblock and should instead happen early in romstage.
No data to display
