Bug #656
open
ET
Usb 3.0 external hdd encolusures still do not work on ivybridge thinkpads unless uas is dissabled
Bug #656:
07/09/2026
Thinkpad T430
Artix Linux
I see that this was an issue years ago https://ticket.coreboot.org/issues/175
The drive spins up and mounts properly by all appearances, but when I try to copy anything to it, the transfer speed plummets to ~200kB/s and I get all these error messages in dmesg.
I'm on coreboot version 26.03-1125
Artix Linux Kernel 7.0.13
I'm using a Seagate 8TB SRD0NF2 drive
I can only get the drive to work by disabling uas, but then performance (speed) drops.
[ 2910.263664] usb 3-3: new SuperSpeed USB device number 3 using xhci_hcd
[ 2910.276106] usb 3-3: New USB device found, idVendor=0bc2, idProduct=331a, bcdDevice= 9.15
[ 2910.276121] usb 3-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2910.276126] usb 3-3: Product: Expansion Desk
[ 2910.276130] usb 3-3: Manufacturer: Seagate
[ 2910.276133] usb 3-3: SerialNumber: NAAA63A6
[ 2910.278716] scsi host8: uas
[ 2910.279220] scsi 8:0:0:0: Direct-Access Seagate Expansion Desk 0915 PQ: 0 ANSI: 6
[ 2910.282482] sd 8:0:0:0: [sdc] Spinning up disk...
[ 2911.319557] ............ready
[ 2922.610135] sd 8:0:0:0: [sdc] 15628053167 512-byte logical blocks: (8.00 TB/7.28 TiB)
[ 2922.610186] sd 8:0:0:0: [sdc] 4096-byte physical blocks
[ 2922.610453] sd 8:0:0:0: [sdc] Write Protect is off
[ 2922.610465] sd 8:0:0:0: [sdc] Mode Sense: 53 00 00 08
[ 2922.610938] sd 8:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2922.635527] sd 8:0:0:0: [sdc] Preferred minimum I/O size 4096 bytes
[ 2922.635542] sd 8:0:0:0: [sdc] Optimal transfer size 33553920 bytes not a multiple of preferred minimum block size (4096 bytes)
[ 2922.699885] sdc: sdc1
[ 2922.700174] sd 8:0:0:0: [sdc] Attached SCSI disk
[ 2990.828560] ntfs3: Enabled Linux POSIX ACLs support
[ 2990.828565] ntfs3: Read-only LZX/Xpress compression included
[ 3108.385619] sd 8:0:0:0: [sdc] tag#5 uas_eh_abort_handler 0 uas-tag 6 inflight: CMD OUT
[ 3108.385636] sd 8:0:0:0: [sdc] tag#5 CDB: Write(16) 8a 00 00 00 00 02 5c 77 bf 00 00 00 04 00 00 00
[ 3108.385713] sd 8:0:0:0: [sdc] tag#4 uas_eh_abort_handler 0 uas-tag 5 inflight: CMD OUT
[ 3108.385720] sd 8:0:0:0: [sdc] tag#4 CDB: Write(16) 8a 00 00 00 00 02 5c 77 bb 00 00 00 04 00 00 00
[ 3108.385761] sd 8:0:0:0: [sdc] tag#3 uas_eh_abort_handler 0 uas-tag 4 inflight: CMD OUT
[ 3108.385767] sd 8:0:0:0: [sdc] tag#3 CDB: Write(16) 8a 00 00 00 00 02 5c 77 b7 00 00 00 04 00 00 00
[ 3108.385801] sd 8:0:0:0: [sdc] tag#2 uas_eh_abort_handler 0 uas-tag 3 inflight: CMD OUT
[ 3108.385806] sd 8:0:0:0: [sdc] tag#2 CDB: Write(16) 8a 00 00 00 00 02 5c 77 b3 00 00 00 04 00 00 00
[ 3108.385848] sd 8:0:0:0: [sdc] tag#1 uas_eh_abort_handler 0 uas-tag 2 inflight: CMD OUT
[ 3108.385853] sd 8:0:0:0: [sdc] tag#1 CDB: Write(16) 8a 00 00 00 00 00 00 fc 3f 20 00 00 00 08 00 00
[ 3108.385936] sd 8:0:0:0: [sdc] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD OUT
[ 3108.385943] sd 8:0:0:0: [sdc] tag#0 CDB: Write(16) 8a 00 00 00 00 00 00 fc 29 b8 00 00 00 10 00 00
[ 3108.391649] scsi host8: uas_eh_device_reset_handler start
[ 3108.391693] usb 3-3: cmd cmplt err -2
[ 3108.391768] usb 3-3: cmd cmplt err -2
[ 3108.505120] usb 3-3: reset SuperSpeed USB device number 3 using xhci_hcd
[ 3108.518945] scsi host8: uas_eh_device_reset_handler success
[ 3138.732942] sd 8:0:0:0: [sdc] tag#29 uas_eh_abort_handler 0 uas-tag 11 inflight: CMD OUT
[ 3138.732962] sd 8:0:0:0: [sdc] tag#29 CDB: Write(16) 8a 00 00 00 00 02 5c 77 d3 30 00 00 04 00 00 00
[ 3138.733146] sd 8:0:0:0: [sdc] tag#24 uas_eh_abort_handler 0 uas-tag 10 inflight: CMD OUT
[ 3138.733160] sd 8:0:0:0: [sdc] tag#24 CDB: Write(16) 8a 00 00 00 00 02 5c 77 cf 30 00 00 04 00 00 00
[ 3138.733318] sd 8:0:0:0: [sdc] tag#23 uas_eh_abort_handler 0 uas-tag 7 inflight: CMD OUT
[ 3138.733331] sd 8:0:0:0: [sdc] tag#23 CDB: Write(16) 8a 00 00 00 00 02 5c 77 c3 30 00 00 04 00 00 00
[ 3138.733487] sd 8:0:0:0: [sdc] tag#22 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD OUT
[ 3138.733500] sd 8:0:0:0: [sdc] tag#22 CDB: Write(16) 8a 00 00 00 00 02 5c 77 c3 00 00 00 00 30 00 00
[ 3138.733625] sd 8:0:0:0: [sdc] tag#21 uas_eh_abort_handler 0 uas-tag 9 inflight: CMD OUT
[ 3138.733632] sd 8:0:0:0: [sdc] tag#21 CDB: Write(16) 8a 00 00 00 00 02 5c 77 cb 30 00 00 04 00 00 00
[ 3138.733707] sd 8:0:0:0: [sdc] tag#20 uas_eh_abort_handler 0 uas-tag 8 inflight: CMD OUT
[ 3138.733713] sd 8:0:0:0: [sdc] tag#20 CDB: Write(16) 8a 00 00 00 00 02 5c 77 c7 30 00 00 04 00 00 00
[ 3138.733769] sd 8:0:0:0: [sdc] tag#11 uas_eh_abort_handler 0 uas-tag 19 inflight: CMD OUT
[ 3138.733774] sd 8:0:0:0: [sdc] tag#11 CDB: Write(16) 8a 00 00 00 00 02 5c 77 f3 50 00 00 04 00 00 00
[ 3138.733828] sd 8:0:0:0: [sdc] tag#10 uas_eh_abort_handler 0 uas-tag 18 inflight: CMD OUT
[ 3138.733832] sd 8:0:0:0: [sdc] tag#10 CDB: Write(16) 8a 00 00 00 00 02 5c 77 f3 30 00 00 00 20 00 00
[ 3138.733955] sd 8:0:0:0: [sdc] tag#9 uas_eh_abort_handler 0 uas-tag 21 inflight: CMD OUT
[ 3138.733980] sd 8:0:0:0: [sdc] tag#9 CDB: Write(16) 8a 00 00 00 00 02 5c 77 fb 50 00 00 04 00 00 00
[ 3138.734048] sd 8:0:0:0: [sdc] tag#8 uas_eh_abort_handler 0 uas-tag 20 inflight: CMD OUT
[ 3138.734054] sd 8:0:0:0: [sdc] tag#8 CDB: Write(16) 8a 00 00 00 00 02 5c 77 f7 50 00 00 04 00 00 00
[ 3138.734105] sd 8:0:0:0: [sdc] tag#7 uas_eh_abort_handler 0 uas-tag 15 inflight: CMD OUT
[ 3138.734111] sd 8:0:0:0: [sdc] tag#7 CDB: Write(16) 8a 00 00 00 00 02 5c 77 e7 30 00 00 04 00 00 00
[ 3138.734192] sd 8:0:0:0: [sdc] tag#6 uas_eh_abort_handler 0 uas-tag 14 inflight: CMD OUT
[ 3138.734198] sd 8:0:0:0: [sdc] tag#6 CDB: Write(16) 8a 00 00 00 00 02 5c 77 e3 30 00 00 04 00 00 00
[ 3138.734243] sd 8:0:0:0: [sdc] tag#5 uas_eh_abort_handler 0 uas-tag 17 inflight: CMD OUT
[ 3138.734248] sd 8:0:0:0: [sdc] tag#5 CDB: Write(16) 8a 00 00 00 00 02 5c 77 ef 30 00 00 04 00 00 00
[ 3138.734290] sd 8:0:0:0: [sdc] tag#4 uas_eh_abort_handler 0 uas-tag 16 inflight: CMD OUT
[ 3138.734295] sd 8:0:0:0: [sdc] tag#4 CDB: Write(16) 8a 00 00 00 00 02 5c 77 eb 30 00 00 04 00 00 00
[ 3138.734336] sd 8:0:0:0: [sdc] tag#3 uas_eh_abort_handler 0 uas-tag 13 inflight: CMD OUT
[ 3138.734341] sd 8:0:0:0: [sdc] tag#3 CDB: Write(16) 8a 00 00 00 00 02 5c 77 df 30 00 00 04 00 00 00
[ 3138.734381] sd 8:0:0:0: [sdc] tag#2 uas_eh_abort_handler 0 uas-tag 2 inflight: CMD OUT
[ 3138.734386] sd 8:0:0:0: [sdc] tag#2 CDB: Write(16) 8a 00 00 00 00 02 5c 77 db 30 00 00 04 00 00 00
[ 3138.734424] sd 8:0:0:0: [sdc] tag#1 uas_eh_abort_handler 0 uas-tag 12 inflight: CMD OUT
[ 3138.734429] sd 8:0:0:0: [sdc] tag#1 CDB: Write(16) 8a 00 00 00 00 02 5c 77 d7 30 00 00 04 00 00 00
[ 3138.742965] scsi host8: uas_eh_device_reset_handler start
[ 3138.743073] usb 3-3: cmd cmplt err -2
[ 3138.743213] usb 3-3: cmd cmplt err -2
[ 3138.743347] usb 3-3: cmd cmplt err -2
[ 3138.743481] usb 3-3: cmd cmplt err -2
[ 3138.743614] usb 3-3: cmd cmplt err -2
[ 3138.743754] usb 3-3: cmd cmplt err -2
[ 3138.745532] sd 8:0:0:0: [sdc] tag#27 uas_zap_pending 0 uas-tag 4 inflight: CMD
[ 3138.745546] sd 8:0:0:0: [sdc] tag#27 CDB: Write(16) 8a 00 00 00 00 02 5c 77 b3 00 00 00 04 00 00 00
[ 3138.745552] sd 8:0:0:0: [sdc] tag#28 uas_zap_pending 0 uas-tag 5 inflight: CMD
[ 3138.745556] sd 8:0:0:0: [sdc] tag#28 CDB: Write(16) 8a 00 00 00 00 00 00 fc 3f 20 00 00 00 08 00 00
[ 3138.745560] sd 8:0:0:0: [sdc] tag#0 uas_zap_pending 0 uas-tag 6 inflight: CMD
[ 3138.745564] sd 8:0:0:0: [sdc] tag#0 CDB: Write(16) 8a 00 00 00 00 00 00 fc 29 b8 00 00 00 10 00 00
[ 3138.857548] usb 3-3: reset SuperSpeed USB device number 3 using xhci_hcd
[ 3138.871158] scsi host8: uas_eh_device_reset_handler success
[ 3169.307866] scsi host8: uas_eh_device_reset_handler start
[ 3169.307975] usb 3-3: cmd cmplt err -2
[ 3169.308105] usb 3-3: cmd cmplt err -2
[ 3169.308233] usb 3-3: cmd cmplt err -2
[ 3169.308361] usb 3-3: cmd cmplt err -2
[ 3169.308492] usb 3-3: cmd cmplt err -2
[ 3169.311075] sd 8:0:0:0: [sdc] tag#3 uas_zap_pending 0 uas-tag 4 inflight: CMD
[ 3169.311088] sd 8:0:0:0: [sdc] tag#3 CDB: Write(16) 8a 00 00 00 00 02 5c 77 d3 30 00 00 04 00 00 00
[ 3169.311094] sd 8:0:0:0: [sdc] tag#4 uas_zap_pending 0 uas-tag 5 inflight: CMD
[ 3169.311098] sd 8:0:0:0: [sdc] tag#4 CDB: Write(16) 8a 00 00 00 00 02 5c 77 cf 30 00 00 04 00 00 00
[ 3169.311102] sd 8:0:0:0: [sdc] tag#5 uas_zap_pending 0 uas-tag 6 inflight: CMD
[ 3169.311105] sd 8:0:0:0: [sdc] tag#5 CDB: Write(16) 8a 00 00 00 00 02 5c 77 c3 30 00 00 04 00 00 00
[ 3169.311109] sd 8:0:0:0: [sdc] tag#6 uas_zap_pending 0 uas-tag 7 inflight: CMD
[ 3169.311113] sd 8:0:0:0: [sdc] tag#6 CDB: Write(16) 8a 00 00 00 00 02 5c 77 c3 00 00 00 00 30 00 00
[ 3169.311117] sd 8:0:0:0: [sdc] tag#7 uas_zap_pending 0 uas-tag 8 inflight: CMD
[ 3169.311120] sd 8:0:0:0: [sdc] tag#7 CDB: Write(16) 8a 00 00 00 00 02 5c 77 cb 30 00 00 04 00 00 00
[ 3169.311124] sd 8:0:0:0: [sdc] tag#8 uas_zap_pending 0 uas-tag 9 inflight: CMD
[ 3169.311127] sd 8:0:0:0: [sdc] tag#8 CDB: Write(16) 8a 00 00 00 00 02 5c 77 c7 30 00 00 04 00 00 00
[ 3169.311132] sd 8:0:0:0: [sdc] tag#9 uas_zap_pending 0 uas-tag 10 inflight: CMD
[ 3169.311135] sd 8:0:0:0: [sdc] tag#9 CDB: Write(16) 8a 00 00 00 00 02 5c 77 f3 50 00 00 04 00 00 00
[ 3169.311139] sd 8:0:0:0: [sdc] tag#10 uas_zap_pending 0 uas-tag 11 inflight: CMD
[ 3169.311143] sd 8:0:0:0: [sdc] tag#10 CDB: Write(16) 8a 00 00 00 00 02 5c 77 f3 30 00 00 00 20 00 00
[ 3169.311147] sd 8:0:0:0: [sdc] tag#11 uas_zap_pending 0 uas-tag 12 inflight: CMD
[ 3169.311150] sd 8:0:0:0: [sdc] tag#11 CDB: Write(16) 8a 00 00 00 00 02 5c 77 fb 50 00 00 04 00 00 00
[ 3169.311154] sd 8:0:0:0: [sdc] tag#12 uas_zap_pending 0 uas-tag 13 inflight: CMD
[ 3169.311157] sd 8:0:0:0: [sdc] tag#12 CDB: Write(16) 8a 00 00 00 00 02 5c 77 f7 50 00 00 04 00 00 00
[ 3169.311161] sd 8:0:0:0: [sdc] tag#13 uas_zap_pending 0 uas-tag 14 inflight: CMD
[ 3169.311164] sd 8:0:0:0: [sdc] tag#13 CDB: Write(16) 8a 00 00 00 00 02 5c 77 e7 30 00 00 04 00 00 00
[ 3169.311168] sd 8:0:0:0: [sdc] tag#14 uas_zap_pending 0 uas-tag 15 inflight: CMD
[ 3169.311171] sd 8:0:0:0: [sdc] tag#14 CDB: Write(16) 8a 00 00 00 00 02 5c 77 e3 30 00 00 04 00 00 00
[ 3169.311176] sd 8:0:0:0: [sdc] tag#15 uas_zap_pending 0 uas-tag 16 inflight: CMD
[ 3169.311179] sd 8:0:0:0: [sdc] tag#15 CDB: Write(16) 8a 00 00 00 00 02 5c 77 ef 30 00 00 04 00 00 00
[ 3169.311183] sd 8:0:0:0: [sdc] tag#16 uas_zap_pending 0 uas-tag 17 inflight: CMD
[ 3169.311186] sd 8:0:0:0: [sdc] tag#16 CDB: Write(16) 8a 00 00 00 00 02 5c 77 eb 30 00 00 04 00 00 00
[ 3169.311190] sd 8:0:0:0: [sdc] tag#17 uas_zap_pending 0 uas-tag 18 inflight: CMD
[ 3169.311193] sd 8:0:0:0: [sdc] tag#17 CDB: Write(16) 8a 00 00 00 00 02 5c 77 df 30 00 00 04 00 00 00
[ 3169.311197] sd 8:0:0:0: [sdc] tag#18 uas_zap_pending 0 uas-tag 19 inflight: CMD
[ 3169.311200] sd 8:0:0:0: [sdc] tag#18 CDB: Write(16) 8a 00 00 00 00 02 5c 77 db 30 00 00 04 00 00 00
[ 3169.311204] sd 8:0:0:0: [sdc] tag#19 uas_zap_pending 0 uas-tag 20 inflight: CMD
[ 3169.311208] sd 8:0:0:0: [sdc] tag#19 CDB: Write(16) 8a 00 00 00 00 02 5c 77 d7 30 00 00 04 00 00 00
[ 3169.423254] usb 3-3: reset SuperSpeed USB device number 3 using xhci_hcd
[ 3169.436437] scsi host8: uas_eh_device_reset_handler success
[ 3201.570249] sd 8:0:0:0: [sdc] tag#29 uas_eh_abort_handler 0 uas-tag 18 inflight: CMD OUT
[ 3201.570273] sd 8:0:0:0: [sdc] tag#29 CDB: Write(16) 8a 00 00 00 00 02 5c 79 c7 00 00 00 04 00 00 00
[ 3201.673489] sd 8:0:0:0: [sdc] tag#28 uas_eh_abort_handler 0 uas-tag 10 inflight: CMD OUT
[ 3201.673506] sd 8:0:0:0: [sdc] tag#28 CDB: Write(16) 8a 00 00 00 00 02 5c 79 c3 00 00 00 04 00 00 00
[ 3201.673660] sd 8:0:0:0: [sdc] tag#26 uas_eh_abort_handler 0 uas-tag 3 inflight: CMD OUT
[ 3201.673673] sd 8:0:0:0: [sdc] tag#26 CDB: Write(16) 8a 00 00 00 00 02 5c 79 e7 00 00 00 04 00 00 00
[ 3201.673806] sd 8:0:0:0: [sdc] tag#25 uas_eh_abort_handler 0 uas-tag 2 inflight: CMD OUT
[ 3201.673814] sd 8:0:0:0: [sdc] tag#25 CDB: Write(16) 8a 00 00 00 00 02 5c 79 e3 00 00 00 04 00 00 00
[ 3201.673940] sd 8:0:0:0: [sdc] tag#24 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD OUT
[ 3201.673947] sd 8:0:0:0: [sdc] tag#24 CDB: Write(16) 8a 00 00 00 00 02 5c 79 df 00 00 00 04 00 00 00
[ 3201.674060] sd 8:0:0:0: [sdc] tag#15 uas_eh_abort_handler 0 uas-tag 17 inflight: CMD OUT
[ 3201.674067] sd 8:0:0:0: [sdc] tag#15 CDB: Write(16) 8a 00 00 00 00 02 5c 7a 13 00 00 00 04 00 00 00
[ 3201.674196] sd 8:0:0:0: [sdc] tag#14 uas_eh_abort_handler 0 uas-tag 8 inflight: CMD OUT
[ 3201.674201] sd 8:0:0:0: [sdc] tag#14 CDB: Write(16) 8a 00 00 00 00 02 5c 79 cf 00 00 00 04 00 00 00
[ 3201.674367] sd 8:0:0:0: [sdc] tag#13 uas_eh_abort_handler 0 uas-tag 16 inflight: CMD OUT
[ 3201.674381] sd 8:0:0:0: [sdc] tag#13 CDB: Write(16) 8a 00 00 00 00 02 5c 7a 0f 00 00 00 04 00 00 00
[ 3201.674495] sd 8:0:0:0: [sdc] tag#12 uas_eh_abort_handler 0 uas-tag 15 inflight: CMD OUT
[ 3201.674501] sd 8:0:0:0: [sdc] tag#12 CDB: Write(16) 8a 00 00 00 00 02 5c 7a 0b 00 00 00 04 00 00 00
[ 3201.674609] sd 8:0:0:0: [sdc] tag#11 uas_eh_abort_handler 0 uas-tag 14 inflight: CMD OUT
[ 3201.674615] sd 8:0:0:0: [sdc] tag#11 CDB: Write(16) 8a 00 00 00 00 02 5c 7a 07 00 00 00 04 00 00 00
[ 3201.674718] sd 8:0:0:0: [sdc] tag#10 uas_eh_abort_handler 0 uas-tag 13 inflight: CMD OUT
[ 3201.674723] sd 8:0:0:0: [sdc] tag#10 CDB: Write(16) 8a 00 00 00 00 02 5c 7a 03 00 00 00 04 00 00 00
[ 3201.674823] sd 8:0:0:0: [sdc] tag#9 uas_eh_abort_handler 0 uas-tag 12 inflight: CMD OUT
[ 3201.674828] sd 8:0:0:0: [sdc] tag#9 CDB: Write(16) 8a 00 00 00 00 02 5c 79 ff 00 00 00 04 00 00 00
[ 3201.674932] sd 8:0:0:0: [sdc] tag#8 uas_eh_abort_handler 0 uas-tag 11 inflight: CMD OUT
[ 3201.674936] sd 8:0:0:0: [sdc] tag#8 CDB: Write(16) 8a 00 00 00 00 02 5c 79 fb 00 00 00 04 00 00 00
[ 3201.675021] sd 8:0:0:0: [sdc] tag#7 uas_eh_abort_handler 0 uas-tag 7 inflight: CMD OUT
[ 3201.675026] sd 8:0:0:0: [sdc] tag#7 CDB: Write(16) 8a 00 00 00 00 02 5c 79 f7 00 00 00 04 00 00 00
[ 3201.675147] sd 8:0:0:0: [sdc] tag#6 uas_eh_abort_handler 0 uas-tag 6 inflight: CMD OUT
[ 3201.675151] sd 8:0:0:0: [sdc] tag#6 CDB: Write(16) 8a 00 00 00 00 02 5c 79 f3 00 00 00 04 00 00 00
[ 3201.675255] sd 8:0:0:0: [sdc] tag#5 uas_eh_abort_handler 0 uas-tag 5 inflight: CMD OUT
[ 3201.675261] sd 8:0:0:0: [sdc] tag#5 CDB: Write(16) 8a 00 00 00 00 02 5c 79 ef 00 00 00 04 00 00 00
[ 3201.675378] sd 8:0:0:0: [sdc] tag#4 uas_eh_abort_handler 0 uas-tag 4 inflight: CMD OUT
[ 3201.675383] sd 8:0:0:0: [sdc] tag#4 CDB: Write(16) 8a 00 00 00 00 02 5c 79 eb 00 00 00 04 00 00 00
[ 3201.675499] sd 8:0:0:0: [sdc] tag#3 uas_eh_abort_handler 0 uas-tag 22 inflight: CMD OUT
[ 3201.675503] sd 8:0:0:0: [sdc] tag#3 CDB: Write(16) 8a 00 00 00 00 02 5c 79 db 00 00 00 04 00 00 00
[ 3201.675616] sd 8:0:0:0: [sdc] tag#2 uas_eh_abort_handler 0 uas-tag 21 inflight: CMD OUT
[ 3201.675621] sd 8:0:0:0: [sdc] tag#2 CDB: Write(16) 8a 00 00 00 00 02 5c 79 d7 00 00 00 04 00 00 00
[ 3201.675696] sd 8:0:0:0: [sdc] tag#1 uas_eh_abort_handler 0 uas-tag 20 inflight: CMD OUT
[ 3201.675701] sd 8:0:0:0: [sdc] tag#1 CDB: Write(16) 8a 00 00 00 00 02 5c 79 d3 00 00 00 04 00 00 00
[ 3201.675741] sd 8:0:0:0: [sdc] tag#0 uas_eh_abort_handler 0 uas-tag 19 inflight: CMD OUT
[ 3201.675746] sd 8:0:0:0: [sdc] tag#0 CDB: Write(16) 8a 00 00 00 00 02 5c 79 cb 00 00 00 04 00 00 00
[ 3201.683333] scsi host8: uas_eh_device_reset_handler start
[ 3201.797714] usb 3-3: reset SuperSpeed USB device number 3 using xhci_hcd
[ 3201.811241] scsi host8: uas_eh_device_reset_handler success
Files
ET Updated by Ezra Taylor 4 months ago
- File cbmem.txt cbmem.txt added
- File usb-controllers.txt usb-controllers.txt added
