Bug #175
openMost USB3 external disk enclosures do not work with coreboot on X230
I would like to report issues with USB3 external disk enclosures and coreboot on the Lenovo X230.
I have several enclosures, and only one works without issues: Toshiba Stor E Alu 2.5. Every other one will cause the following messages in dmesg over USB3 (USB2 is fine):
[ 73.788819] usb 4-2: new SuperSpeed USB device number 3 using xhci_hcd
[ 73.809949] usb 4-2: New USB device found, idVendor=0080, idProduct=a001
[ 73.809955] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 73.809958] usb 4-2: Product: External USB 3.0
[ 73.809961] usb 4-2: Manufacturer: TOSHIBA
[ 73.809964] usb 4-2: SerialNumber: 201503310007F
[ 73.813049] scsi host8: uas
[ 73.813861] scsi 8:0:0:0: Direct-Access TO Exter nal USB 3.0 0204 PQ: 0 ANSI: 6
[ 73.814609] sd 8:0:0:0: Attached scsi generic sg4 type 0
[ 73.815157] sd 8:0:0:0: [sde] 156301488 512-byte logical blocks: (80.0 GB/74.5 GiB)
[ 73.815161] sd 8:0:0:0: [sde] 4096-byte physical blocks
[ 73.815326] sd 8:0:0:0: [sde] Write Protect is off
[ 73.815330] sd 8:0:0:0: [sde] Mode Sense: 53 00 00 08
[ 73.815659] sd 8:0:0:0: [sde] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 73.819382] sde: sde1
[ 73.820711] sd 8:0:0:0: [sde] Attached SCSI disk
[ 105.329243] sd 8:0:0:0: [sde] tag#3 uas_eh_abort_handler 0 uas-tag 4 inflight: CMD IN
[ 105.329252] sd 8:0:0:0: [sde] tag#3 CDB: Read(10) 28 00 00 00 00 80 00 01 80 00
[ 105.329334] sd 8:0:0:0: [sde] tag#2 uas_eh_abort_handler 0 uas-tag 3 inflight: CMD IN
[ 105.329342] sd 8:0:0:0: [sde] tag#2 CDB: Read(10) 28 00 00 00 00 40 00 00 38 00
[ 105.345200] scsi host8: uas_eh_device_reset_handler start
[ 105.345276] usb 4-2: cmd cmplt err -2
[ 105.473565] usb 4-2: reset SuperSpeed USB device number 3 using xhci_hcd
[ 105.495210] scsi host8: uas_eh_device_reset_handler success
[ 138.096012] sd 8:0:0:0: [sde] tag#5 uas_eh_abort_handler 0 uas-tag 6 inflight: CMD IN
[ 138.096016] sd 8:0:0:0: [sde] tag#5 CDB: Read(10) 28 00 09 50 f5 d8 00 00 28 00
[ 138.096184] sd 8:0:0:0: [sde] tag#4 uas_eh_abort_handler 0 uas-tag 5 inflight: CMD IN
[ 138.096187] sd 8:0:0:0: [sde] tag#4 CDB: Read(10) 28 00 09 50 f5 28 00 00 a8 00
[ 138.116005] scsi host8: uas_eh_device_reset_handler start
[ 138.116027] usb 4-2: cmd cmplt err -2
[ 138.244231] usb 4-2: reset SuperSpeed USB device number 3 using xhci_hcd
[ 138.265440] scsi host8: uas_eh_device_reset_handler success
[ 168.816132] sd 8:0:0:0: [sde] tag#4 uas_eh_abort_handler 0 uas-tag 5 inflight: CMD IN
[ 168.816138] sd 8:0:0:0: [sde] tag#4 CDB: Read(10) 28 00 09 50 f7 b8 00 00 48 00
[ 168.816174] sd 8:0:0:0: [sde] tag#3 uas_eh_abort_handler 0 uas-tag 4 inflight: CMD IN
[ 168.816177] sd 8:0:0:0: [sde] tag#3 CDB: Read(10) 28 00 09 50 f7 28 00 00 80 00
[ 168.816208] sd 8:0:0:0: [sde] tag#2 uas_eh_abort_handler 0 uas-tag 3 inflight: CMD IN
[ 168.816212] sd 8:0:0:0: [sde] tag#2 CDB: Read(10) 28 00 09 50 f6 68 00 00 b8 00
[ 168.832129] scsi host8: uas_eh_device_reset_handler start
[ 168.832153] usb 4-2: cmd cmplt err -2
[ 168.960341] usb 4-2: reset SuperSpeed USB device number 3 using xhci_hcd
[ 168.981496] scsi host8: uas_eh_device_reset_handler success
[ 201.583792] sd 8:0:0:0: [sde] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD IN
[ 201.583796] sd 8:0:0:0: [sde] tag#0 CDB: Read(10) 28 00 00 00 10 00 00 00 08 00
[ 201.599793] scsi host8: uas_eh_device_reset_handler start
[ 201.599817] usb 4-2: cmd cmplt err -2
[ 201.728046] usb 4-2: reset SuperSpeed USB device number 3 using xhci_hcd
[ 201.749283] scsi host8: uas_eh_device_reset_handler success
[ 234.351266] sd 8:0:0:0: [sde] tag#3 uas_eh_abort_handler 0 uas-tag 4 inflight: CMD IN
[ 234.351270] sd 8:0:0:0: [sde] tag#3 CDB: Read(10) 28 00 00 00 08 80 00 01 80 00
[ 234.351343] sd 8:0:0:0: [sde] tag#2 uas_eh_abort_handler 0 uas-tag 3 inflight: CMD IN
[ 234.351345] sd 8:0:0:0: [sde] tag#2 CDB: Read(10) 28 00 00 00 08 40 00 00 38 00
[ 234.375267] scsi host8: uas_eh_device_reset_handler start
[ 234.375319] usb 4-2: cmd cmplt err -2
[ 234.503509] usb 4-2: reset SuperSpeed USB device number 3 using xhci_hcd
[ 234.524774] scsi host8: uas_eh_device_reset_handler success
[ 267.118802] sd 8:0:0:0: [sde] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD IN
[ 267.118810] sd 8:0:0:0: [sde] tag#0 CDB: Read(10) 28 00 00 00 0a 00 00 02 00 00
[ 267.138781] scsi host8: uas_eh_device_reset_handler start
[ 267.138872] usb 4-2: cmd cmplt err -2
[ 267.267064] usb 4-2: reset SuperSpeed USB device number 3 using xhci_hcd
[ 267.288888] scsi host8: uas_eh_device_reset_handler success
[ 297.838883] sd 8:0:0:0: [sde] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD IN
[ 297.838890] sd 8:0:0:0: [sde] tag#0 CDB: Read(10) 28 00 00 60 08 00 00 00 08 00
[ 297.854785] scsi host8: uas_eh_device_reset_handler start
[ 297.854827] usb 4-2: cmd cmplt err -2
[ 297.983104] usb 4-2: reset SuperSpeed USB device number 3 using xhci_hcd
[ 298.004091] scsi host8: uas_eh_device_reset_handler success
Note that it says it's a Toshiba enclosure but it's not the Stor E Alu 2.5, it's from an Orico 2588US3-V1-BK-PRO with a 2.5" Intel X25M SSD in it.
If I use Lenovo's BIOS, then I don't have any errors at all in dmesg, and I'm able to use the disk normally. With coreboot, I can't mount the disk at all and dmesg gets these error messages continuously.
Files
TG Updated by Tobis Greer about 8 years ago
Here is what happens with another enclosure from Amazon (Cateck brand) with a 120GB PNY SSD:
[ 2238.693339] usb 4-2: new SuperSpeed USB device number 8 using xhci_hcd
[ 2238.714317] usb 4-2: New USB device found, idVendor=152d, idProduct=0578
[ 2238.714322] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2238.714325] usb 4-2: Product: JMS579
[ 2238.714328] usb 4-2: Manufacturer: JMicron
[ 2238.714331] usb 4-2: SerialNumber: 0E914110000457951707
[ 2238.716588] scsi host8: uas
[ 2238.717470] scsi 8:0:0:0: Direct-Access SSD2SC12 0G3LA726B087-370 0104 PQ: 0 ANSI: 6
[ 2238.718778] sd 8:0:0:0: Attached scsi generic sg4 type 0
[ 2238.719360] sd 8:0:0:0: [sde] 234441648 512-byte logical blocks: (120 GB/112 GiB)
[ 2238.719362] sd 8:0:0:0: [sde] 4096-byte physical blocks
[ 2238.719518] sd 8:0:0:0: [sde] Write Protect is off
[ 2238.719520] sd 8:0:0:0: [sde] Mode Sense: 53 00 00 08
[ 2238.719839] sd 8:0:0:0: [sde] Disabling FUA
[ 2238.719841] sd 8:0:0:0: [sde] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2238.932634] sde: sde1
[ 2238.934070] sd 8:0:0:0: [sde] Attached SCSI disk
[ 2270.045106] sd 8:0:0:0: [sde] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD IN
[ 2270.045114] sd 8:0:0:0: [sde] tag#0 CDB: Read(10) 28 00 00 00 02 00 00 02 00 00
[ 2270.065133] scsi host8: uas_eh_device_reset_handler start
[ 2270.065187] usb 4-2: cmd cmplt err -2
[ 2270.193469] usb 4-2: reset SuperSpeed USB device number 8 using xhci_hcd
[ 2270.215218] scsi host8: uas_eh_device_reset_handler success
[ 2300.764956] sd 8:0:0:0: [sde] tag#3 uas_eh_abort_handler 0 uas-tag 4 inflight: CMD IN
[ 2300.764961] sd 8:0:0:0: [sde] tag#3 CDB: Read(10) 28 00 00 00 08 80 00 01 80 00
[ 2300.788966] scsi host8: uas_eh_device_reset_handler start
[ 2300.789029] usb 4-2: cmd cmplt err -2
[ 2300.917219] usb 4-2: reset SuperSpeed USB device number 8 using xhci_hcd
[ 2300.938307] scsi host8: uas_eh_device_reset_handler success
[ 2333.532856] sd 8:0:0:0: [sde] tag#2 uas_eh_abort_handler 0 uas-tag 3 inflight: CMD IN
[ 2333.532864] sd 8:0:0:0: [sde] tag#2 CDB: Read(10) 28 00 0d f9 47 e8 00 00 10 00
[ 2333.548875] scsi host8: uas_eh_device_reset_handler start
[ 2333.548929] usb 4-2: cmd cmplt err -2
[ 2333.677072] usb 4-2: reset SuperSpeed USB device number 8 using xhci_hcd
[ 2333.698560] scsi host8: uas_eh_device_reset_handler success
[ 2366.300753] sd 8:0:0:0: [sde] tag#1 uas_eh_abort_handler 0 uas-tag 2 inflight: CMD IN
[ 2366.300761] sd 8:0:0:0: [sde] tag#1 CDB: Read(10) 28 00 01 bf 30 28 00 00 20 00
[ 2366.300889] sd 8:0:0:0: [sde] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD IN
[ 2366.300896] sd 8:0:0:0: [sde] tag#0 CDB: Read(10) 28 00 00 00 10 00 00 00 08 00
[ 2366.316698] scsi host8: uas_eh_device_reset_handler start
[ 2366.316757] usb 4-2: cmd cmplt err -2
[ 2366.444918] usb 4-2: reset SuperSpeed USB device number 8 using xhci_hcd
[ 2366.466164] scsi host8: uas_eh_device_reset_handler success
[ 2399.068499] sd 8:0:0:0: tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD
[ 2399.068506] sd 8:0:0:0: tag#0 CDB: Test Unit Ready 00 00 00 00 00 00
[ 2404.700459] sd 8:0:0:0: [sde] tag#1 uas_eh_abort_handler 0 uas-tag 2 inflight: CMD IN
[ 2404.700467] sd 8:0:0:0: [sde] tag#1 CDB: Read(10) 28 00 00 00 08 10 00 00 08 00
[ 2404.716460] scsi host8: uas_eh_device_reset_handler start
[ 2404.716493] usb 4-2: cmd cmplt err -2
[ 2404.844698] usb 4-2: reset SuperSpeed USB device number 8 using xhci_hcd
[ 2404.865991] scsi host8: uas_eh_device_reset_handler success
This one is able to mount the disk but doing so takes minutes, and reading or writing operations are also very slow to complete (even a simple ls or touch)
- File cb_inteltool.txt cb_inteltool.txt added
- File lenovo_inteltool.txt lenovo_inteltool.txt added
Finally, here are the inteltool dumps from running the Lenovo 2.68 bios and from running the coreboot built off the .config file attached to the ticket. Dumped with inteltool -a.
PR Updated by Patrick Rudolph over 7 years ago
The RCBA register for USB seems fine, but we don't do that much xhci initialisation in coreboot.
From the error description I guess it's related to over-current or transmitter margins.
RA Updated by Robert Alessi about 3 years ago
Patrick Rudolph wrote in #note-3:
Does this mean the situation is hopeless? As it stands, the problem seems to persist under both
Linux and OpenBSD, which seems to indicate that neither kernel can complete the xhci initialitation.
More information here: https://codeberg.org/libreboot/lbmk/issues/120
And here (please read the whole thread): https://marc.info/?t=151482563500001&r=1&w=2
Thank you!
