Feature #644
opensupport for ideapad 330 15ikbr
this is a requeset for ideapad 330 in supported devices of corbeoot and the anexed file have the things to do that and look the lspci -tnnv -[0000:00]-+-00.0 Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers [8086:5914]
+-02.0 Intel Corporation Kaby Lake-R GT2 [UHD Graphics 620] [8086:5917]
+-14.0 Intel Corporation Sunrise Point-LP USB 3.0 xHCI Controller [8086:9d2f]
+-14.2 Intel Corporation Sunrise Point-LP Thermal subsystem [8086:9d31]
+-15.0 Intel Corporation Sunrise Point-LP Serial IO I2C Controller #0 [8086:9d60]
+-17.0 Intel Corporation Sunrise Point-LP SATA Controller [AHCI mode] [8086:9d03]
+-1c.0-[01]----00.0 NVIDIA Corporation GP108M [GeForce MX150] [10de:1d10]
+-1c.4-[02]----00.0 Realtek Semiconductor Co., Ltd. RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet Controller [10ec:8168]
+-1c.5-[03]----00.0 Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter [168c:0042]
+-1f.0 Intel Corporation Sunrise Point LPC/eSPI Controller [8086:9d4e]
+-1f.2 Intel Corporation Sunrise Point-LP PMC [8086:9d21]
+-1f.3 Intel Corporation Sunrise Point-LP HD Audio [8086:9d71]
-1f.4 Intel Corporation Sunrise Point-LP SMBus [8086:9d23] but im not dev so i need help but i will try my best to this work but if nobody help i will try and the board is LNVNB161216 but i dont have the eletric scheme from the board LNVNB161216 but im disposed to do this work and problems i dont have a ch programmer and the 0x13a msr register reports 0 so i have zero boot guard and i have vbt.bin and i will try like a dev
Files
HA Updated by heitor ramos assunção 6 months ago
- File lenovo_330_coreboot_all.tar.zst added
- Tracker changed from Support to Feature
- Description updated (diff)
- Due date set to 06/05/2026
- Affected OS changed from all to all linux and macos hackintosh
- File deleted (
lenovo_330_coreboot_all.tar.zst)
- Due date changed from 06/05/2026 to 06/26/2026
- Due date changed from 06/26/2026 to 07/31/2026
- % Done changed from 100 to 0
NC Updated by Nicholas Chin 6 months ago
It would be useful if you collected some more information as described on https://aprilthe.pink/coreboot.html under the "Getting dumps from stock firmware" and "Getting dumps from stock firmware - Integrated GPU" headers (those should all be run with sudo/root)
I'd also recommend collecting the output of lspci -tnnv as it's easier to parse certain information from that compared to the full verbose lspci log.
Just a note, generally the best way to get a board supported by coreboot is to either port it yourself or pay someone to do it.
- File lenovo_330_coreboot-bios_all.tar.zst lenovo_330_coreboot-bios_all.tar.zst added
note:im not a dev but ok i will try port but if dont work in qemu i call help from a dev
- File deleted (
heitor ramos assunção wrote in #note-7:
coreboot ports are board specific; a rom built for your board will never work in QEMU. That page I linked does have some information about porting, though it isn't a detailed step by step guide for any particular platform.
If you are looking for help, feel free to join one of the real time chat options: https://doc.coreboot.org/community/forums.html#real-time-chat
I'd be willing to take a look at porting this once you post more logs though I won't promise anything. Porting is also generally easier when you have physical access to the device.
System Details:
Manufacturer: LENOVO
Product Name: 81FE (IdeaPad 330-15IKB)
Firmware Version: 8TCN61WW (Release Date: 05/19/2021)
Embedded Controller Version: 1.61.results of dmidecode:osty@void ~> sudo dmidecode -t 0
dmidecode 3.7¶
Getting SMBIOS data from sysfs.
SMBIOS 3.0.0 present.
Handle 0x0000, DMI type 0, 24 bytes
Platform Firmware Information
Vendor: LENOVO
Version: 8TCN61WW
Address: 0xE0000
Runtime Size: 128 KiB
ROM Size: 6080 KiB
Characteristics:
PCI is supported
Firmware is upgradeable
Firmware shadowing is allowed
Boot from CD is supported
Selectable boot is supported
EDD is supported
Japanese floppy for NEC 9800 1.2 MB is supported (int 13h)
Japanese floppy for Toshiba 1.2 MB is supported (int 13h)
5.25"/360 kB floppy services are supported (int 13h)
5.25"/1.2 MB floppy services are supported (int 13h)
3.5"/720 kB floppy services are supported (int 13h)
3.5"/2.88 MB floppy services are supported (int 13h)
8042 keyboard services are supported (int 9h)
CGA/mono video services are supported (int 10h)
ACPI is supported
USB legacy is supported
BIOS boot specification is supported
Targeted content distribution is supported
UEFI is supported
Platform Firmware Revision: 1.61
Embedded Controller Firmware Revision: 1.61
osty@void ~> sudo dmidecode -t 1
dmidecode 3.7¶
Handle 0x0001, DMI type 1, 27 bytes
System Information
Product Name: 81FE
Version: Lenovo ideapad 330-15IKB
Serial Number: PE0411VB
UUID: 95b8a7d4-d55c-11e8-3391-641c679fa1d7
Wake-up Type: Power Switch
SKU Number: LENOVO_MT_81FE_BU_idea_FM_ideapad 330-15IKB
Family: ideapad 330-15IKB
osty@void ~>
- File gpio_ideapad.c gpio_ideapad.c added
- File acpidump.txt acpidump.txt added
Atualizado por heitor ramos assunção há menos de um minuto
#13
System Details:
dmidecode 3.7
Vendor: LENOVO
Version: 8TCN61WW
Address: 0xE0000
ROM Size: 6080 KiB
Characteristics:
PCI is supported
EDD is supported
ACPI is supported
UEFI is supported
dmidecode 3.7
System Information
Product Name: 81FE
osty@void ~>
yes i destroyed my inteltool but i have gpio for my board and this is acpidump txt
osty@void ~> sudo xbps-install -S coreboot-utils
Senha:
[] Updating repository https://void.voidbr.org/voidlinux/current/x86_64-repodata' ... x86_64-repodata: 2137KB [avg rate: 8102KB/s] [*] Updating repository https://void.voidbr.org/voidlinux/current/multilib/nonfree/x86_64-repodata' ...
x86_64-repodata: 7501B [avg rate: 163MB/s]
[] Updating repository https://void.voidbr.org/voidlinux/current/multilib/x86_64-repodata' ... x86_64-repodata: 706KB [avg rate: 12GB/s] [*] Updating repository https://void.voidbr.org/voidlinux/current/nonfree/x86_64-repodata' ...
x86_64-repodata: 16KB [avg rate: 288MB/s]
Name Action Version New version Download size
coreboot-utils install - 24.08_1 395KB
Size to download: 395KB
Size required on disk: 5054KB
Space available on disk: 211GB
Do you want to continue? [Y/n] y
[*] Downloading packages
coreboot-utils-24.08_1.x86_64.xbps.sig2: 512B [avg rate: 10MB/s]
coreboot-utils-24.08_1.x86_64.xbps: 395KB [avg rate: 4432MB/s]
coreboot-utils-24.08_1: verifying RSA signature...
[*] Collecting package files
coreboot-utils-24.08_1: collecting files...
[*] Unpacking packages
coreboot-utils-24.08_1: unpacking ...
[*] Configuring unpacked packages
coreboot-utils-24.08_1: configuring ...
coreboot-utils-24.08_1: installed successfully.
1 downloaded, 1 installed, 0 updated, 1 configured, 0 removed, 0 on hold.
osty@void ~> inteltool
iopl: Operation not permitted
You need to be root.
osty@void ~ [1]> sudo inteltool
CPU: ID 0x806ea, Processor Type 0x0, Family 0x6, Model 0x8e, Stepping 0xa
Northbridge: 8086:5914 (7th generation (Kaby Lake family) Core Processor (Mobile))
Southbridge: 8086:9d4e (Sunrise Point-LP U iHDCP 2.2 Premium/Kabylake)
IGD: 8086:5917 (Intel(R) UHD Graphics 620)
osty@void ~>
- Priority changed from Normal to Immediate
